CLI buffer problem
Hi everyone,
I'm using ble_app_interactive (SDK17.0.2) as a starting point for my application, which consists in sending commands from my PC to my nRF52DK, which is in charge to perform several BLE operations. I send the following commands to read some data from my BLE commercial device:
scan on
gatt services XX:XX:XX:XX:XX:XX
gatt characteristics XX:XX:XX:XX:XX:XX YYYY
gatt notification on XX:XX:XX:XX:XX:XX YYYY
It is all good until occur some problems with the buffering of the command that I sent. As echo messages, I sometimes get things such as:
gatt read D1:97:3C:2F:2F:C4 6f87:BF
where "87:BF" is a part of a previous command that I sent several seconds before the current command.
It seems there is a problem of buffering the command, so when this buffer is full, some parts of previous command appears concatenated with the current command. If I well understand, there is a ring buffer that implement the buffer for this commands, which seems to be initialized with:
NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 256, 256);
in the main file of the ble_app_interactive example. If it is responsible for this buffering, is there a way to reset it whenever I need, in order to avoid the above problem?
    It looks like the example uses the following define by default:
    NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
    Did you modify the buffer sizes? Have you seen the same issue with default settings?
    Are you using Putty with the recommended Terminal settings to test this?
    Jørgen
  • Hi Jorgen,
    I modified the example because that configuration sometimes determined error in the communication when I received too much data (in particular with the characteristic list). I solved that problem changing from:
    to:
    I want to obtain a simple communication with the PC (mantaining BLE connection capabilities) with the goal of developing a simple GUI that will send command to che nrf52DK and receive responses (about BLE data of other nearby devices: for this purpose, i simplified as much as possibile the CLI by removing logs and colors functionality and other configurations in the sdk_config.h, as follows:
    // <o> GATT_DATA_WRITE_SIZE - Maximum size of GATT data to write.
    #ifndef GATT_DATA_WRITE_SIZE
    #define GATT_DATA_WRITE_SIZE 64
    // <o> MAX_CHARACTERISTIC_COUNT - Maximum count of characteristics to find.
    #ifndef MAX_CHARACTERISTIC_COUNT
    #define MAX_CHARACTERISTIC_COUNT 20
    #ifndef UART_DEFAULT_CONFIG_IRQ_PRIORITY
    #define UART_DEFAULT_CONFIG_IRQ_PRIORITY 2
    #ifndef NRF_CLI_BUILD_IN_CMDS_ENABLED
    #define NRF_CLI_BUILD_IN_CMDS_ENABLED 0
    // <o> NRF_CLI_CMD_BUFF_SIZE - Maximum buffer size for a single command.
    #ifndef NRF_CLI_CMD_BUFF_SIZE
    #define NRF_CLI_CMD_BUFF_SIZE 512
    // <o> NRF_CLI_PRINTF_BUFF_SIZE - Maximum print buffer size.
    #ifndef NRF_CLI_PRINTF_BUFF_SIZE
    #define NRF_CLI_PRINTF_BUFF_SIZE 1024
    #ifndef NRF_CLI_VT100_COLORS_ENABLED
    #define NRF_CLI_VT100_COLORS_ENABLED 0
    #ifndef NRF_CLI_STATISTICS_ENABLED
    #define NRF_CLI_STATISTICS_ENABLED 0
    #ifndef NRF_CLI_LOG_BACKEND
    #define NRF_CLI_LOG_BACKEND 0
    #ifndef NRF_LOG_ENABLED
    #define NRF_LOG_ENABLED 0
    #ifndef NRF_LOG_STR_PUSH_BUFFER_SIZE
    #define NRF_LOG_STR_PUSH_BUFFER_SIZE 256
    So, I don't use anymore putty (which I tested in the first phase of the development), but I use an application written for the purpose above, which read/send data from/to serial port.
    Best regards and thanks for your help!
    Antonino
  • This kind of issue is typically caused by missing string termination character (\0) and/or '\r'/'\n'. Are you sure these are handled correctly in your application sending/receiving the commands?
    The CLI should have separate buffers for TX and RX, so I'm not sure how the command you send could get into the response. Are you using separate buffers for sending and receiving to/from the serial port in your application?
  • --"This kind of issue is typically caused by missing string termination character (\0) and/or '\r'/'\n'. Are you sure these are handled correctly in your application sending/receiving the commands?"
    Should I use both "\n" "\r"?
    I think in my application its all correct with termination characters, because the issue I tell you happen in a random manner, often the device communicate correctly all the information that I need, just sometimes the problem appear. If there would be a termination problem, it will appear in a sistematic manner, I think.
    --"The CLI should have separate buffers for TX and RX, so I'm not sure how the command you send could get into the response. Are you using separate buffers for sending and receiving to/from the serial port in your application?"
    The issue is in the echo that I receive from the nrf52DK, so I supposed that what I receive from the PC in the echo is equivalent to what the nrf52DK store in the receive buffer, so I think the problem is in the receive buffer and just replying the echo to the pc it appears in the trasmitting buffer. Another thing that confirm that the problem is in the receiving buffer, is that the nrf52DK reply (just when the problem occur) with the info: "command not found" or "Invalid parameter" and so on, depending in what particular command the error appear. It seems the receive buffer is full and start to overwrite on old data, what do you think? so I would reset the receive buffer, if possible.
    The serial communication from my app running on the PC to nrf52DK has been verified with a terminal monitor, and the commands are sent correctly.
    For UART, you should use "\r", see Usage.
    It could happen if you are using a circular buffer and reaches the end of the buffer, but miss the newline character when calculating the size of the string. A simple check regarding this could be to use a logic analyzer to see what is transmitted over the UART lines. Then you should see if all newline characters are sent correctly.
    It is possible. If there is an issue with the receive buffers, this should be reproducible with a given set of commands (a given number of received bytes). Could you try to find a set of commands that will reproduce the issue, that we can use to reproduce it on our side?
