Is there an NCS sample for storing updates in external flash?
I'm working on an nRF5340 based design and using the nRF5240DK to get started.
I would like to have an immutable first stage boot loader, an updatable MCUBoot boot loader, an updatable application (with BLE Host) on the application processor, and an updatable BLE Controller on the network processor.  I've added CONFIG_SECURE_BOOT=y and CONFIG_BOOTLOADER_MCUBOOT=y to get started (and that seems to be working for some of this, but is storing updates in internal flash for now).  I'm unclear if this setup so far includes update capability for the BLE Controller on the network processor.  What is needed to add that capability?
I would like to store all updates in external flash.  I see that there is a way to define partitions for internal and external flash using the DTS overlay.  However, it appears that those are not used when doing a multi-image build - so they end up being ignored and the partition manager python script is used instead to generate the partitions.  I've added CONFIG_PM_EXTERNAL_FLASH=y, etc, to the prj.conf.  Then the NCS documentation says "Now partitions can be placed in the external flash:"  but no indication of where that information should go and no example of what they would look like for the update images...  Are there any samples showing how to do this?  And/or pointers to more documentation?
I will have my own custom application code to store the update images into the external flash.  Is there an API to find the partition information for those update areas?  It seems like the flash map api only uses info from DTS (which is ignored)?  Ideally an API that will work even if I don't have CONFIG_SECURE_BOOT=y and CONFIG_BOOTLOADER_MCUBOOT=y defined - so that I can debug the application code that transfers the firmware easily without any boot loaders present to confuse SES?
