driver = BLEDriver( NameError: name 'BLEDriver' is not defined
I am trying to run the heart_rate_collector.py example in Nordic's pc_ble_driver_py library. When I try to execute the program, I get the following error:
  File "/Users/elainechesoni/Dev/Nordic/pc-ble-driver-py/pc_ble_driver_py/examples/heart_rate_collector.py", line 234, in <module>
    main(serial_port)
  File "/Users/elainechesoni/Dev/Nordic/pc-ble-driver-py/pc_ble_driver_py/examples/heart_rate_collector.py", line 168, in main
    driver = BLEDriver(
Command used to run example:
python3 heart_rate_collector.py NRF52
(I have also tried running with python instead of python3)
I have modified the code in two places:
  • main function starting on Line 166 now reads:
    def main(selected_serial_port):
        print("Serial port used: {}".format(selected_serial_port))
        driver = BLEDriver(
            serial_port=selected_serial_port, auto_flash=False, baud_rate=1000000, log_severity_level="info"
        print("BLEDriver has been established...")
        adapter = BLEAdapter(driver)
        print("Adapter has been established...")
        collector = HRCollector(adapter)
        print("Collector has been established...")
        collector.open()
        print("Open to advertising devices...")
        # conn = collector.connect_and_discover()
        conn = None
        while conn == None:
            print(conn)
        if conn is not None:
            # time.sleep(10)
            # time.sleep(1000)
            while True:
                print("Connection not none")
        print("Closing collector...")
        collector.close()
        print("Collector has been closed.")
  • Line 216 now reads:
    if __name__ == "__main__":
         serial_port = #hard coded serial port
         main(serial_port)
         quit()
Things I have tried to resolve this issue:
  • Uninstalling Python3.9, and installing Python3.8.8
  • I have tried using different serial ports on my computer
The issue still exists.
Additionally, I am using a Mac, and have followed instructions here to properly disable MSD. I am able to verify that the board connects successfully via the serial port by opening nRF Connect and selecting the device.
My system Information:
OS: macOS Big Sur version 11.2.1
Python version 3.8.8
Connectivity firmware version: 4.2.1
SoftDevice API version 5
What am I unable to execute the pc_ble_driver_py example?
Please let me know if I can offer any additional information to help resolve this issue.
