nRF52832: Frequency tolerance requirement for ANT stack for an extern 32.768kHz crystal oscillator
The frequency tolerance for ANT stack for an external 32.768 kHz crystal oscillator should be +/- 50 ppm max.
Does it mean over temperature range?
There was the same question for an BLE stack, and I understand that the tolerance is over temperature. For BLE  the required tolerance is +/- 250ppm.
But  to find a crystal +/- 50ppm for a Temperature until 85°C is not possible, because the 'Parabolic coefficient' is about 0,035 ppm/°C^2.
And from 25°C to 85°C there are a delta of 60°C (85-25=60), and it menas 60°C x 60°C x 0,035 = 126ppm.
126ppm is much greater than 50ppm.
So it seems there can not be find a crystal to use the  nRF52832 for ANT, because there is always a requirement for a device over Temperature..
I sit true?
best regards
Josef
