Unable to perform nRF9160DK Full Modem Firmware Update using SMP Server
I am trying to use the `fmfu_smp_svr` sample project, as described in nRF9160: Full modem firmware update using SMP Server, to perform a full modem firmware update.
The target device is a nRF9160DK, PCA100090 0.9.0, using the built-in J-Link.
So far, all my attempts have failed, with the device returning an error part way through, and the update timing out. I have attempted the update under MacOS 10.15.7 and Ubuntu 20.04 LTS with the result. It appears that the bootloader is being transferred successfully, but the application portion is failing part way through.
I've built the `fmfu_smp_svr` sample from the v1.5.0 tag of the nRF Connect SDK. No changes to it or the `update_modem.py` script. I'm using the latest pynrfjprog.
I am able to update the Modem Firmware successfully using nRF Connect Desktop, and `fmfu_smp_svr` reports the expected version. However, we need to update nRF9160 devices in manufacturing under automation, and the desktop application is not viable. The new full modem firmware update feature via SMP looks like a solution for us, but so far it's not working.
Thanks for your support,
Jeremy Wood
See the attached file for the log of an attempted update:
(venv) jerwood@jerBookBCD ~/n/n/n/s/n/fmfu_smp_svr ((v1.5.0))> python update_modem.py ./mfwnrf9160110.zip /dev/cu.usbmodem0009600136971 115200
# modem firmware upgrade over serial port example started.
    "duration": 425,
    "error_code": "Ok",
    "operation": "open_uart",
    "outcome": "success",
    "progress_percentage": 100
Programming modem bootloader.
    "duration": 0,
    "message": "Calculating image size",
    "operation": "upload_image",
    "progress_percentage": 5
    "duration": 0,
    "message": "Uploading image to device",
    "duration": 51,
    "progress_percentage": 15
    "duration": 104,
    "progress_percentage": 21
    "duration": 157,
    "progress_percentage": 27
    "duration": 210,
    "progress_percentage": 33
    "duration": 263,
    "progress_percentage": 40
    "duration": 316,
    "progress_percentage": 46
    "duration": 369,
    "progress_percentage": 52
    "duration": 422,
    "progress_percentage": 58
    "duration": 475,
    "progress_percentage": 64
    "duration": 528,
    "progress_percentage": 71
    "duration": 581,
    "progress_percentage": 77
    "duration": 634,
    "progress_percentage": 83
    "duration": 687,
    "progress_percentage": 89
    "duration": 740,
    "progress_percentage": 95
    "duration": 833,
Programming file 1 of 2 files.
    "duration": 0,
    "duration": 0,
    "duration": 51,
    "progress_percentage": 20
    "duration": 104,
    "duration": 157,
    "duration": 209,
    "duration": 262,
    "duration": 315,
    "progress_percentage": 84
    "duration": 368,
    "progress_percentage": 97
    "duration": 389,
Finished with file.
Programming file 2 of 2 files.
    "duration": 0,
    "duration": 0,
    "duration": 3899,
    "progress_percentage": 11
    "duration": 6456,
    "error_code": "BadState",
    "message": "Image upload failed. Bad response from device",
    "outcome": "fail",
b'An error was reported by NRFJPROG DLL: -2 INVALID_OPERATION.'
    "duration": 3,
    "error_code": "Ok",
    "operation": "close_uart",
  File "/Users/jerwood/nrf9160_lte_update/ncs/nrf/samples/nrf9160/fmfu_smp_svr/update_modem.py", line 43, in <module>
    run(args.uart, args.firmware, args.baudrate)
  File "/Users/jerwood/nrf9160_lte_update/ncs/nrf/samples/nrf9160/fmfu_smp_svr/update_modem.py", line 26, in run
    modem_dfu_probe.program(modem_firmware_zip)
  File "/Users/jerwood/nrf9160_lte_update/ncs/nrf/samples/nrf9160/fmfu_smp_svr/venv/lib/python3.9/site-packages/pynrfjprog/HighLevel.py", line 350, in program
    raise APIError(result, log=self._logger.error)
pynrfjprog.APIError.APIError: An error was reported by NRFJPROG DLL: -2 INVALID_OPERATION.
  • FWIW, I also couldn't get the fmfu_smp_svr sample to work (Ubuntu 20.04.02 LTS; nrf sdk v1.5.0).  But I get a timeout error instead of "INVALID_OPERATION".
    ivo@system76-pc:~/src/nrf91-1.5.0/ncs/nrf/samples/nrf9160/fmfu_smp_svr$ python3 update_modem.py mfw_nrf9160_1.2.3.zip /dev/ttyACM0 115200
        "duration": 414,
        "error_code": "Ok",
        "duration": 0,
        "duration": 0,
        "duration": 51,
        "duration": 104,
        "duration": 157,
        "duration": 210,
        "duration": 262,
        "duration": 315,
        "duration": 368,
        "duration": 421,
        "duration": 474,
        "duration": 527,
        "duration": 580,
        "duration": 633,
        "duration": 686,
        "duration": 739,
        "duration": 832,
        "duration": 0,
        "duration": 0,
        "duration": 51,
        "duration": 104,
        "duration": 157,
        "duration": 210,
        "progress_percentage": 59
        "duration": 263,
        "progress_percentage": 72
        "duration": 316,
        "duration": 369,
        "duration": 388,
    Finished with file.
        "duration": 0,
        "duration": 0,
        "duration": 3839,
        "duration": 7686,
        "progress_percentage": 12
        "duration": 11618,
        "progress_percentage": 13
        "duration": 15404,
        "progress_percentage": 14
        "duration": 19358,
        "duration": 23318,
        "progress_percentage": 16
        "duration": 27274,
        "progress_percentage": 17
        "duration": 30871,
        "progress_percentage": 18
        "duration": 34829,
        "progress_percentage": 19
        "duration": 38787,
        "duration": 42576,
        "duration": 46535,
        "progress_percentage": 22
        "duration": 50494,
        "progress_percentage": 23
        "duration": 54335,
        "progress_percentage": 24
        "duration": 58240,
        "progress_percentage": 25
        "duration": 62201,
        "progress_percentage": 26
        "duration": 94006,
        "error_code": "Timeout",
        "outcome": "fail",
    b'An error was reported by NRFJPROG DLL: -220 TIME_OUT.'
        "duration": 1,
        "error_code": "Ok",
      File "update_modem.py", line 43, in <module>
      File "update_modem.py", line 26, in run
      File "/home/ivo/.local/lib/python3.8/site-packages/pynrfjprog/HighLevel.py", line 350, in program
    pynrfjprog.APIError.APIError: An error was reported by NRFJPROG DLL: -220 TIME_OUT.
    DEBUG log:
    fmfu_smp_svr-timeout-error-debug.txt
  • I'll look into this today/Monday
    Could you try to read through this ticket: https://devzone.nordicsemi.com/f/nordic-q-a/64656/thingy91-pynrfjprog-deadlocks-at-100-cpu-usage/264177#264177, where a customer encountered an INVALID_OPERATION error with pynrfjprog and while updating the modem firmware. The solution in that case wast to re-install pynrfjprog, could you try to do that?
    What JLink version are you using? Check it out by running nrfjprog -v. Try to install the latest one: https://www.nordicsemi.com/Software-and-tools/Development-Tools/nRF-Command-Line-Tools/Download#infotabs
    If the ticket, or any of the suggestions didn't fix the problem for you, please get back to me and I'll get in touch with some developers internally.
    Best regards.
    Simon
  • I believe that I'm using the lasted JLink and nrfjprog:
    nrfjprog version: 10.12.1
    JLinkARM.dll version: 6.98
    I reinstalled the tools as mentioned in that ticket, but I'm still seeing the same problem.
    If you and the team could look into this in more detail, I would appreciate it!
  • Could you try to set the logging level equal to logging.DEBUG in update_modem.py, and upload the log?
  • Here is a log capture with logging.DEBUG. In this instance, the failure was a timeout.
    2021.03.10_nrf9160_modem_update_timeout.txt
