Porting nRF52833 code to BL653
I have a firmware that runs well on nRF52833 dev kit (SDK 17.02) and I am trying to port it to a Laird BL653 dev kit.
The firmware has a bootloader and it can perform DFU over Bluetooth.
The main difference between the nRF52833DK and the BL653 board is that the BL653 module does not use a crystal so I changed the following in sdk_config.h:
NRF_SDH_CLOCK_LF_SRC 0
NRF_SDH_CLOCK_LF_RC_CTIV 16
NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
NRF_SDH_CLOCK_LF_ACCURACY 1
NRFX_CLOCK_CONFIG_LF_SRC 0
If I apply these changes to the nRF52833DK it works fine.
After loading bootloader and softdevice on BL653, I can connect to DFU_Targ and send the ZIP package.
It all works fine until I power cycle the board, then Bluetooth stops advertising (but the microcontroller still executes my code).
The only way to restore the Bluetooth is by pressing the reset button.
Can anyone suggest where I should focus my attention?
I am quite new to Nordic devices so for this first project I hired a developer which did a good job but has not been able to help me with this issue.
  • Can anyone suggest where I should focus my attention?
    Use the debugger to step through your code and see where it's going wrong.
    As you have a working and a non-working version, you can compare the two - see where they differ...
    Have you checked that it isn't still actually using the crystal ?
  • Hi awneil, thanks for your answer.
    As soon as I start the debug session, Bluetooth comes back to life.
    So I decided to save the err_code generated by nrf_sdh_enable_request()
    static void ble_stack_init(void) {
      ret_code_t err_code;
      ERROR_LOG = err_code; // Storing err_code in a global variable
    And send it out trough the serial port
    NRF_LOG_RAW_INFO("%d", ERROR_LOG)
    When I power the board, this is what comes out from the serial: 0000000000
  • Have you checked that it isn't still actually using the crystal ?
    INTERESTING UPDATE:
    I checked the pca10100 schematic and noticed that the LF crystal is connected through two solderbridges (SB1, SB2) that are normally closed.
    You can disconnect the LF crystal by cutting the track on SB1 and SB2.
    The BL653 dev kit is similar but the solder bridges are normally open.
    Instead of cutting tracks on the pca10100, I decided to connect the LF crystal on the BL653 dev kit.
    Both boards can now use the LF crystal oscillator.
    This is the result of my testing:
    1) Before changing the firmware settings, I checked the crystal signal with a scope on both boards.
    - The crystal is not oscillating
    - pca10100 works fine
    - No changes to the behaviour of BL653. Bluetooth works only after pushing the reset button (or starting a debug session)
    2) Restored "standard" (see below) clock settings on bootloader and loaded bootloader + softdevice S140
    - The LF crystal is oscillating at ~32.76kHz on both boards
    - Bluetooth is advertising as DFUTarg on both boards.
    NRF_SDH_CLOCK_LF_SRC 1
    NRF_SDH_CLOCK_LF_RC_CTIV 0
    NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0
    NRF_SDH_CLOCK_LF_ACCURACY 7
    NRFX_CLOCK_CONFIG_LF_SRC 1
    3) Compiled firmware with "standard" clock settings, generated Zip file and performed DFU over Bluetooth.
    - The LF crystal is oscillating at ~32.76kHz on both boards.
    - No changes to the behavior of BL653. Bluetooth only works after pushing the reset button (or starting a debug session)
  • Hi Francesco,
    In your case, the module BL653 should have a 32MHz crystal included already (To be able to use the radio the board needs 32MHz crystal anyway). It only missing the LFCLK 32kHz crystal. You should modify
    Try to fully erase the chip. Open a terminal (cmd) and write: nrfjprog --eraseall
    What is your updated application? Does it able to run before/without DFU? If not, are you able to make other ble applications run on BL653 dev kit, like the ble_app_uart?
    -Amanda H.
  • Hi Amanda, thanks for your answer.
    I have modified those parameters but I had no luck.
    Then I connected the LFCLK crystal and reverted the parameters (see my post above) but the problem is still present. My code is executed but Bluetooth does not advertise until I push the reset button.
    I have also tried erasing the chip, no luck.
    The only way to get it working are:
    - pressing the reset button
    or
    - running a debug session
    or
    - after loading the code via DFU_Targ
    All the actions above are in fact resetting the chip, so I started thinking it could be something related to noise or voltage rise time at power up so I tried to power the board while holding the reset button.
    Even in this case I had no success.
    - The BL653 dev kit works well as DFU_Targ but it shows problem when I load my firmware.
    - The same code works great on nRF52833DK
    - Examples provided by Nordic (EG: ble_app_uart) work perfectly on BL653 dev kit
    What could be the problem with this BL653 dev kit? Now that I have connected the LFCLK it should work exactly as the nRF52833DK. Am I missing something?
