Sending data while there is frequent ble connection and disconnection due to week signal causes wdog reset
Hi, we are using nrf sdk15.0.0 in the application. There are two nrf devices 52840. one is central, other is peripheral. Continuously data is sent from one device to another as notification. When the distance between the two devices are increased after some distance of greater than 10 meters frequent connection disconnection happens and there is packets loss. During such scenario the firmware seems to be stuck and causes wdog reset. What are the conditions that could trigger wdog reset in such scenarios?
When wdog is set to high priority, the reset did not occur, but device is continuously advertising and other low priority tasks are blocked.
Please clarify
    How long have you defined your connections timeout parameter to? If you are expecting packet loss due to long distance / noisy environment, you may want to increase the timeout to reduce the frequent disconnections and reconnections.
    Are there any errors being returned, or other indication of something going wrong during the reconnection?
    The SoftDevice takes priority over any application-layer process, and it will do so whenever a timing-critical BLE task needs handling. In the case of rapid disconnections and reconnection, the SoftDevice will spend more time actively controlling the radio.
    However, it does not take very long to establish these connections, or handle the disconnects, so I am thinking that your watchdog timeout might be too short. What do you mean when you say that the firmware gets 'stuck' - how long specifically is the device seemingly doing nothing?
    What priority did you set the to, and why would you raise its priority? Raising the priority of the watchdog somewhat defeats its purpose.
    The watchdog only has a single condition for triggering a reset, and that is if it stops being fed.
    The watchdog is usually fed in the main context, to ensure that the application does not get stuck somewhere in an infinite / very long interrupt handling. What is your current watchdog timeout set to? It sounds to me like you should increase the watchdog timeout, if it keeps triggering because the SoftDevice has to keep reconnecting to the other device.
    The lowest possible advertising interval is 10 ms + a random delay of 0 - 10 ms. You should therefore have ample time between advertisements to process other events. What else is your application doing in between advertisements? Could it be that you have a higher-priority task that does not return, and therefore the low-priority tasks does not get to run?
    Looking forward to resolving this issue together!
    Karl
  • Thanks for response. Supervision timeout is set to 4sec. Today we could narrow down the scenario causing the issue. The issue occurs when there is data to be transmitted and a sudden disconnect happens.
    A periodic function is called to transmit multiple packets of data in a loop in the application while the p_ctx->busy is false. p_ctx->busy is set when sd-ble-gatts-hvx returns error code NRF_ERROR_RESOURCES.
    The wdog timeout is set to 20sec. If the device gets connected before wdog reset occurs then the application resumes and does not reset. However if it is not connected within this time, then wdog reset occurs.
    Any suggestions on the cause of reset would be helpful
  • Hi Karl, issue still exists. The softdevice seems to  hang after disconnect and never returns to application.
  • Can the transmit buffer in soft device be cleared so that execution returns back to application?
    No problem at all, I am happy to help!
    Thank you for clarifying - this is very helpful information!
    This sounds a lot like a application-layer logic issue. Could you elaborate thoroughly or share a code snippet of the section in which this conditioned p_ctx->busy loop is taking place?
    How is this looping implemented? I imagine that the SoftDevice disconnects and finishes all its processes here, but the application is still trying to send data and is thus stuck in this loop. Since no data is being sent, the loop never ends, and then the watchdog resets the device.
    Could you perhaps try to clear your p_ctx flag as part of the ble_evt_handler's disconnect event handling?
    I suppose you should also have the disconnect event start with placing un-transmitted data back in the buffer/queue for future transmits, to avoid loosing the data.
    Please keep in mind that I have not actually seen any code for this section, so this is just my initial thoughts and speculations based on the information in your previous answer.
    Karl
