I have both an installation of NCS v1.5.0 from Toolchain Manager (TM) and from the Getting Started Assistant (GSA) on Macbook running macOS High Sierra. The TM SDK when building from the terminal is working fine but when I try to open a standard terminal and go to my GSA install I am getting an error "No such file or directory: 'git''. This error does not occur if I include the option to not use the Toolchain that was installed by the TM. Can someone help me understand why this is the case?
Build fails with west build -b nrf9160dk_nrf9160ns -p
Akashs-MacBook-Air:asset_tracker akash$ west build -b nrf9160dk_nrf9160ns -p
-- west build: making build dir /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build pristine
Including boilerplate (Zephyr base): /Users/akash/Documents/ncs/zephyr/cmake/app/boilerplate.cmake
-- Application: /Users/akash/Documents/ncs/nrf/applications/asset_tracker
-- Using NCS Toolchain 1.5.0 for building. (/opt/nordic/ncs/v1.5.0/toolchain/cmake)
-- Zephyr version: 2.4.99 (/Users/akash/Documents/ncs/zephyr)
-- Found Python3: /opt/nordic/ncs/v1.5.0/toolchain/bin/python3 (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
CMake Error at /Users/akash/Documents/ncs/zephyr/cmake/zephyr_module.cmake:61 (message):
File "/Users/akash/Documents/ncs/zephyr/scripts/zephyr_module.py", line 378, in <module>
main()
File "/Users/akash/Documents/ncs/zephyr/scripts/zephyr_module.py", line 283, in main
manifest = Manifest.from_file()
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/west/manifest.py", line 1084, in from_file
return Manifest(**kwargs)
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/west/manifest.py", line 1273, in __init__
self._load(source_data['manifest'],
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/west/manifest.py", line 1527, in _load
self._load_projects(manifest, url_bases, defaults, ctx)
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/west/manifest.py", line 1859, in _load_projects
self._import_from_project(project, imp, ctx)
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/west/manifest.py", line 2047, in _import_from_project
self._import_path_from_project(project, imap.file,
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/west/manifest.py", line 2059, in _import_path_from_project
imported = self._import_content_from_project(project, path)
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/west/manifest.py", line 2105, in _import_content_from_project
project.is_cloned():
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/west/manifest.py", line 850, in is_cloned
res = self.git('rev-parse --show-cdup', check=False, cwd=cwd,
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/west/manifest.py", line 747, in git
popen = subprocess.Popen(
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/subprocess.py", line 854, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "/opt/nordic/ncs/v1.5.0/toolchain/Cellar/[email protected]/3.8.2/Frameworks/Python.framework/Versions/3.8/lib/python3.8/subprocess.py", line 1702, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'git'
/Users/akash/Documents/ncs/zephyr/cmake/app/boilerplate.cmake:183 (include)
/Users/akash/Documents/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
/Users/akash/Documents/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
CMakeLists.txt:13 (find_package)
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -DWEST_PYTHON=/usr/local/opt/[email protected]/bin/python3.9 -B/Users/akash/Documents/ncs/nrf/applications/asset_tracker/build -S/Users/akash/Documents/ncs/nrf/applications/asset_tracker -GNinja -DBOARD=nrf9160dk_nrf9160ns
Build succeeds with west build -b nrf9160dk_nrf9160ns -p -- -DNCS_TOOLCHAIN_VERSION=NONE
Akashs-MacBook-Air:asset_tracker akash$ west build -b nrf9160dk_nrf9160ns -p -- -DNCS_TOOLCHAIN_VERSION=NONE
-- Found Python3: /usr/local/bin/python3.9 (found suitable exact version "3.9.1") found components: Interpreter
-- Board: nrf9160dk_nrf9160ns, Revision: 0.7.0
-- Cache files will be written to: /Users/akash/Library/Caches/zephyr
-- Found dtc: /usr/local/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (/usr/local/opt/gnuarmemb)
-- Found BOARD.dts: /Users/akash/Documents/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
nrf9160dk_nrf9160ns.dts.pre.tmp:366.32-370.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property
nrf9160dk_nrf9160ns.dts.pre.tmp:59.42-71.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
nrf9160dk_nrf9160ns.dts.pre.tmp:311.19-317.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
-- Generated zephyr.dts: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/zephyr/include/generated/device_extern.h
Parsing /Users/akash/Documents/ncs/nrf/applications/asset_tracker/Kconfig
Loaded configuration '/Users/akash/Documents/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
Merged configuration '/Users/akash/Documents/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_0_7_0.conf'
Merged configuration '/Users/akash/Documents/ncs/nrf/applications/asset_tracker/prj.conf'
Configuration saved to '/Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/zephyr/.config'
Kconfig header saved to '/Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 8.3.1
-- The CXX compiler identification is GNU 8.3.1
-- Found assembler: /usr/local/opt/gnuarmemb/bin/arm-none-eabi-gcc
Changed board to secure nrf9160dk_nrf9160 (NOT NS)
=== child image spm - begin ===
-- Application: /Users/akash/Documents/ncs/nrf/samples/spm
-- Board: nrf9160dk_nrf9160, Revision: 0.7.0
-- Found BOARD.dts: /Users/akash/Documents/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
-- Found devicetree overlay: /Users/akash/Documents/ncs/nrf/samples/spm/nrf9160dk_nrf9160.overlay
nrf9160dk_nrf9160.dts.pre.tmp:59.42-71.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@50000000/kmu@39000)
nrf9160dk_nrf9160.dts.pre.tmp:311.19-317.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000)
-- Generated zephyr.dts: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/spm/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/spm/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/spm/zephyr/include/generated/device_extern.h
Parsing /Users/akash/Documents/ncs/zephyr/Kconfig
Loaded configuration '/Users/akash/Documents/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
Merged configuration '/Users/akash/Documents/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_0_7_0.conf'
Merged configuration '/Users/akash/Documents/ncs/nrf/applications/asset_tracker/child_image/spm/prj.conf'
Merged configuration '/Users/akash/Documents/ncs/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration '/Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/spm/zephyr/.config'
Kconfig header saved to '/Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/spm/zephyr/include/generated/autoconf.h'
CMake Deprecation Warning at /Users/akash/Documents/ncs/modules/lib/civetweb/CMakeLists.txt:2 (cmake_minimum_required):
Compatibility with CMake < 2.8.12 will be removed from a future version of
CMake.
Update the VERSION argument <min> value or use a ...<max> suffix to tell
CMake that the project does not need compatibility with older versions.
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/spm
=== child image spm - end ===
=== child image mcuboot - begin ===
-- Application: /Users/akash/Documents/ncs/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: /Users/akash/Documents/ncs/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/mcuboot/zephyr/include/generated/device_extern.h
Parsing /Users/akash/Documents/ncs/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration '/Users/akash/Documents/ncs/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration '/Users/akash/Documents/ncs/nrf/applications/asset_tracker/child_image/mcuboot.conf'
Configuration saved to '/Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/mcuboot/zephyr/.config'
Kconfig header saved to '/Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/mcuboot/zephyr/include/generated/autoconf.h'
CMake.
CMake Warning at /Users/akash/Documents/ncs/zephyr/kernel/CMakeLists.txt:59 (message):
Single threaded mode (CONFIG_MULTITHREADING=n) is deprecated
MCUBoot bootloader key file: /Users/akash/Documents/ncs/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/akash/Documents/ncs/nrf/applications/asset_tracker/build/mcuboot
=== child image mcuboot - end ===
CMake Warning at /Users/akash/Documents/ncs/nrf/modules/mcuboot/CMakeLists.txt:151 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
CMake.
CMake Warning at /Users/akash/Documents/ncs/zephyr/CMakeLists.txt:1357 (message):
Dropping partition 'nrf_modem_lib_trace' since its size is 0.
-- Configuring done
-- Generating done
[1/273] Preparing syscall dependency handling
[11/273] Performing build step for 'spm_subimage'
[1/201] Preparing syscall dependency handling
[196/201] Linking C executable zephyr/zephyr_prebuilt.elf
Memory region Used Size Region Size %age Used
FLASH: 32256 B 48 KB 65.62%
SRAM: 8648 B 64 KB 13.20%
IDT_LIST: 72 B 2 KB 3.52%
[201/201] Linking C executable zephyr/zephyr.elf
[17/273] Performing build step for 'mcuboot_subimage'
[1/258] Preparing syscall dependency handling
[253/258] Linking C executable zephyr/zephyr_prebuilt.elf
FLASH: 38092 B 48 KB 77.50%
SRAM: 24216 B 178968 B 13.53%
IDT_LIST: 88 B 2 KB 4.30%
[258/258] Linking C executable zephyr/zephyr.elf
[263/273] Linking C executable zephyr/zephyr_prebuilt.elf
FLASH: 207320 B 409088 B 50.68%
SRAM: 74560 B 178968 B 41.66%
IDT_LIST: 152 B 2 KB 7.42%
[273/273] Generating zephyr/merged.hex
git and env
Akashs-MacBook-Air:asset_tracker akash$ git --version git version 2.17.2 (Apple Git-113) Akashs-MacBook-Air:asset_tracker akash$ env TERM_PROGRAM=Apple_Terminal SHELL=/bin/bash NRFJPROG_LIBRARY_PATH=/Applications/nRF Connect.app/Contents/Frameworks/nrfjprog TERM=xterm-256color GNUARMEMB_TOOLCHAIN_PATH=/usr/local/opt/gnuarmemb/ TMPDIR=/var/folders/vw/q4pwtsvn5dx8_y5qdyp0jz880000gn/T/ Apple_PubSub_Socket_Render=/private/tmp/com.apple.launchd.EhxEsdEA5U/Render TERM_PROGRAM_VERSION=404.1 TERM_SESSION_ID=4B4DFE7A-F4B6-4A1A-B6D7-35BD19B06B7E USER=akash SSH_AUTH_SOCK=/private/tmp/com.apple.launchd.s1YC0WbNzJ/Listeners PATH=/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin PWD=/Users/akash/Documents/ncs/nrf/applications/asset_tracker LANG=en_US.UTF-8 XPC_FLAGS=0x0 XPC_SERVICE_NAME=0 ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb HOME=/Users/akash SHLVL=2 LOGNAME=akash _=/usr/bin/env OLDPWD=/Users/akash/Documents/ncs/nrf Akashs-MacBook-Air:asset_tracker akash$
Akash
