RSRQ Values
in documentation of nRF9160 RSRQ is defined for 0..34 and 255.
What about values 35..254? Is it possible to get these values from the chip?
I have to know, if these values are error or valid data (RSRQ> -3dB).
thank you for help
best regards
Adrian Frick
  • Hello Mr. Frick,
    Currently it is only possible to read the values given by 0 - 34, and 255. Is there a reason for why you need the values between? For question regarding the road map of the modem FW, please contact your local RSM.
    The RSRQ values are given by 3GPP TS 36.133 - chapter 9.1.7 RSRQ Measurement Report Mapping
    The reporting range of RSRQ is defined from -34 dB to 2.5 dB with 0.5 dB resolution.
    The mapping of measured quantity is defined in table 9.1.7-1. The range in the signalling may be larger than the guaranteed accuracy range.
    Table 9.1.7-1: RSRQ measurement report mapping
    Reported value Measured quantity value Unit
    RSRQ_-30 RSRQ < -34 dB
    RSRQ_-29 -34 £ RSRQ < -33.5 dB
    RSRQ_-02 -20.5 £ RSRQ < -20 dB
    RSRQ_-01 -20 £ RSRQ < -19.5 dB
    RSRQ_00 RSRQ < -19.5 dB
    RSRQ_01 -19.5 £ RSRQ < -19 dB
    RSRQ_02 -19 £ RSRQ < -18.5 dB
    RSRQ_32 -4 £ RSRQ < -3.5 dB
    RSRQ_33 -3.5 £ RSRQ < -3 dB
    RSRQ_34 -3 £ RSRQ dB
    RSRQ_35 -3 £ RSRQ < -2.5 dB
    RSRQ_36 -2.5 £ RSRQ < -2 dB
    RSRQ_45 2 £ RSRQ < 2.5 dB
    RSRQ_46 2.5 £ RSRQ
    dB
    Note: The ranges from RSRQ_-30 to RSRQ_-01 and from RSRQ_35 to RSRQ_46 apply for the UE who can support extended RSRQ range in [31].
    This is the extended range. Earlier spec versions had the normal range from RSRQ_0 ... RSRQ_34
    Øyvind
  • I dont't need values between 34 to 255. But I wanted to know, if the chip sends these values. We want to output the RSRQ value in dB. So we need to know, if we have to handle the values. I think, we output -3dB for values between 34 and 254. Thank you!
  • You're welcome.
    Let me know if you need any further assistance.
    Øyvind
