Thingy52 CSCS shows no measurement values.
So I am expanding the Thingy to have a CSCS, I have the service visible in nRF Connect with the only problem being that CSC Measurement is reporting no values (see image below). The code I use for the CSCS is just a copy paste of the example in the nRF5 v1300 SDK, as can be seen below. I do leave out a bunch of the code so there might be something missing. In main.c I simply call rowing_init() after thingy_init(). The simulated values are being passed into cscs_measurement correctly (as far as I can see), I tested it with RTT.
 This is the first time I am working with BLE so I might be doing something stupid.
#include <string.h>
#include "rowing.h"
#include "ble_cscs.h"
#include "ble_srv_common.h"
#include "stddef.h"
#include "app_error.h"
#include "app_timer.h"
#include "sensorsim.h"
//TODO remove this when done
#include "nrf_log.h"
APP_TIMER_DEF(m_csc_meas_timer_id);
static uint32_t m_cumulative_wheel_revs;
static bool     m_auto_calibration_in_progress;
//TODO FOr sim
#define SPEED_AND_CADENCE_MEAS_INTERVAL 1000                                        /**< Speed and cadence measurement interval (milliseconds). */
#define WHEEL_CIRCUMFERENCE_MM          2100                                        /**< Simulated wheel circumference in millimeters. */
#define KPH_TO_MM_PER_SEC               278                                         /**< Constant to convert kilometers per hour into millimeters per second. */
#define MIN_SPEED_KPH                   10                                          /**< Minimum speed in kilometers per hour for use in the simulated measurement function. */
#define MAX_SPEED_KPH                   40                                          /**< Maximum speed in kilometers per hour for use in the simulated measurement function. */
#define SPEED_KPH_INCREMENT             1                                           /**< Value by which speed is incremented/decremented for each call to the simulated measurement function. */
#define DEGREES_PER_REVOLUTION          360                                         /**< Constant used in simulation for calculating crank speed. */
#define RPM_TO_DEGREES_PER_SEC          6                                           /**< Constant to convert revolutions per minute into degrees per second. */
#define MIN_CRANK_RPM                   20                                          /**< Minimum cadence in RPM for use in the simulated measurement function. */
#define MAX_CRANK_RPM                   110                                         /**< Maximum cadence in RPM for use in the simulated measurement function. */
#define CRANK_RPM_INCREMENT             3                                           /**< Value by which cadence is incremented/decremented in the simulated measurement function. */
static sensorsim_cfg_t   m_speed_kph_sim_cfg;                                       /**< Speed simulator configuration. */
static sensorsim_state_t m_speed_kph_sim_state;                                     /**< Speed simulator state. */
static sensorsim_cfg_t   m_crank_rpm_sim_cfg;                                       /**< Crank simulator configuration. */
static sensorsim_state_t m_crank_rpm_sim_state;                                     /**< Crank simulator state. */
static ble_sensor_location_t supported_locations[] = {BLE_SENSOR_LOCATION_FRONT_WHEEL,
                                                      BLE_SENSOR_LOCATION_LEFT_CRANK,
                                                      BLE_SENSOR_LOCATION_RIGHT_CRANK,
                                                      BLE_SENSOR_LOCATION_LEFT_PEDAL,
                                                      BLE_SENSOR_LOCATION_RIGHT_PEDAL,
                                                      BLE_SENSOR_LOCATION_FRONT_HUB,
                                                      BLE_SENSOR_LOCATION_REAR_DROPOUT,
                                                      BLE_SENSOR_LOCATION_CHAINSTAY,
                                                      BLE_SENSOR_LOCATION_REAR_WHEEL,
                                                      BLE_SENSOR_LOCATION_REAR_HUB}; /**< supported location for the sensor location. */
static ble_cscs_t  m_cscs;  //CSCS reference
/**@brief Function for handling Speed and Cadence Control point events
 * @details Function for handling Speed and Cadence Control point events.
 *          This function parses the event and in case the "set cumulative value" event is received,
 *          sets the wheel cumulative value to the received value.
ble_scpt_response_t sc_ctrlpt_event_handler(ble_sc_ctrlpt_t     * p_sc_ctrlpt,
                                            ble_sc_ctrlpt_evt_t * p_evt){
    switch (p_evt->evt_type)
        case BLE_SC_CTRLPT_EVT_SET_CUMUL_VALUE:
            m_cumulative_wheel_revs = p_evt->params.cumulative_value;
        case BLE_SC_CTRLPT_EVT_START_CALIBRATION:
            m_auto_calibration_in_progress = true;
            // No implementation needed.
    return (BLE_SCPT_SUCCESS);
//TODO FOr sim
static void csc_sim_measurement(ble_cscs_meas_t * p_measurement)
    static uint16_t cumulative_crank_revs = 0;
    static uint16_t event_time            = 0;
    static uint16_t wheel_revolution_mm   = 0;
    static uint16_t crank_rev_degrees     = 0;
    uint16_t mm_per_sec;
    uint16_t degrees_per_sec;
    uint16_t event_time_inc;
    // Per specification event time is in 1/1024th's of a second.
    event_time_inc = (1024 * SPEED_AND_CADENCE_MEAS_INTERVAL) / 1000;
    // Calculate simulated wheel revolution values.
    p_measurement->is_wheel_rev_data_present = true;
    mm_per_sec = KPH_TO_MM_PER_SEC * sensorsim_measure(&m_speed_kph_sim_state,
                                                       &m_speed_kph_sim_cfg);
    wheel_revolution_mm     += mm_per_sec * SPEED_AND_CADENCE_MEAS_INTERVAL / 1000;
    m_cumulative_wheel_revs += wheel_revolution_mm / WHEEL_CIRCUMFERENCE_MM;
    wheel_revolution_mm     %= WHEEL_CIRCUMFERENCE_MM;
    p_measurement->cumulative_wheel_revs = m_cumulative_wheel_revs;
    p_measurement->last_wheel_event_time =
        event_time + (event_time_inc * (mm_per_sec - wheel_revolution_mm) / mm_per_sec);
    // Calculate simulated cadence values.
    p_measurement->is_crank_rev_data_present = true;
    degrees_per_sec = RPM_TO_DEGREES_PER_SEC * sensorsim_measure(&m_crank_rpm_sim_state,
        &m_crank_rpm_sim_cfg);
    crank_rev_degrees     += degrees_per_sec * SPEED_AND_CADENCE_MEAS_INTERVAL / 1000;
    cumulative_crank_revs += crank_rev_degrees / DEGREES_PER_REVOLUTION;
    crank_rev_degrees     %= DEGREES_PER_REVOLUTION;
    p_measurement->cumulative_crank_revs = cumulative_crank_revs;
    p_measurement->last_crank_event_time =
        event_time + (event_time_inc * (degrees_per_sec - crank_rev_degrees) / degrees_per_sec);
    event_time += event_time_inc;
//TODO FOr sim
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
    m_speed_kph_sim_cfg.min          = MIN_SPEED_KPH;
    m_speed_kph_sim_cfg.max          = MAX_SPEED_KPH;
    m_speed_kph_sim_cfg.incr         = SPEED_KPH_INCREMENT;
    m_speed_kph_sim_cfg.start_at_max = false;
    sensorsim_init(&m_speed_kph_sim_state, &m_speed_kph_sim_cfg);
    m_crank_rpm_sim_cfg.min          = MIN_CRANK_RPM;
    m_crank_rpm_sim_cfg.max          = MAX_CRANK_RPM;
    m_crank_rpm_sim_cfg.incr         = CRANK_RPM_INCREMENT;
    m_crank_rpm_sim_cfg.start_at_max = false;
    sensorsim_init(&m_crank_rpm_sim_state, &m_crank_rpm_sim_cfg);
    m_cumulative_wheel_revs        = 0;
    m_auto_calibration_in_progress = false;
/**@brief Function for handling the Cycling Speed and Cadence measurement timer timeouts.
 * @details This function will be called each time the cycling speed and cadence
 *          measurement timer expires.
 * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
 *                       app_start_timer() call to the timeout handler.
static void csc_meas_timeout_handler(void * p_context){
    uint32_t        err_code;
    ble_cscs_meas_t cscs_measurement;
    UNUSED_PARAMETER(p_context);
    //TODO Build cscs_measurement
    //TODO FOr sim
    csc_sim_measurement(&cscs_measurement);
    err_code = ble_cscs_measurement_send(&m_cscs, &cscs_measurement);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
    if (m_auto_calibration_in_progress)
        err_code = ble_sc_ctrlpt_rsp_send(&(m_cscs.ctrl_pt), BLE_SCPT_SUCCESS);
            (err_code != NRF_ERROR_RESOURCES)
        if (err_code != NRF_ERROR_RESOURCES)
static void rowing_timers_start(void){
    ret_code_t err_code;
    uint32_t csc_meas_timer_ticks;
    // Start rowing timers.
    csc_meas_timer_ticks = APP_TIMER_TICKS(SPEED_AND_CADENCE_MEAS_INTERVAL);
    err_code = app_timer_start(m_csc_meas_timer_id, csc_meas_timer_ticks, NULL);
static void rowing_timers_init(void){
    // Create timers.
    err_code = app_timer_create(&m_csc_meas_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                csc_meas_timeout_handler);
    NRF_LOG_INFO(NRF_LOG_COLOR_CODE_GREEN"Rowing timer initiated:\r\n");
static void rowing_service_init(void){
    uint32_t              err_code;
    ble_cscs_init_t       cscs_init;
    ble_sensor_location_t sensor_location;
    // Initialize Cycling Speed and Cadence Service.
    memset(&cscs_init, 0, sizeof(cscs_init));
    cscs_init.evt_handler = NULL;
    cscs_init.feature     = BLE_CSCS_FEATURE_WHEEL_REV_BIT | BLE_CSCS_FEATURE_CRANK_REV_BIT |
                            BLE_CSCS_FEATURE_MULTIPLE_SENSORS_BIT;
    // Here the sec level for the Cycling Speed and Cadence Service can be changed/increased.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cscs_init.csc_meas_attr_md.cccd_write_perm);   // for the measurement characteristic, only the CCCD write permission can be set by the application, others are mandated by service specification
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cscs_init.csc_feature_attr_md.read_perm);      // for the feature characteristic, only the read permission can be set by the application, others are mandated by service specification
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cscs_init.csc_ctrlpt_attr_md.write_perm);      // for the SC control point characteristic, only the write permission and CCCD write can be set by the application, others are mandated by service specification
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cscs_init.csc_ctrlpt_attr_md.cccd_write_perm); // for the SC control point characteristic, only the write permission and CCCD write can be set by the application, others are mandated by service specification
    cscs_init.ctrplt_supported_functions = BLE_SRV_SC_CTRLPT_CUM_VAL_OP_SUPPORTED
                                           | BLE_SRV_SC_CTRLPT_SENSOR_LOCATIONS_OP_SUPPORTED
                                           | BLE_SRV_SC_CTRLPT_START_CALIB_OP_SUPPORTED;
    cscs_init.ctrlpt_evt_handler            = sc_ctrlpt_event_handler;
    cscs_init.list_supported_locations      = supported_locations;
    cscs_init.size_list_supported_locations = sizeof(supported_locations) /
                                              sizeof(ble_sensor_location_t);
    sensor_location           = BLE_SENSOR_LOCATION_FRONT_WHEEL;                 // initializes the sensor location to add the sensor location characteristic.
    cscs_init.sensor_location = &sensor_location;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cscs_init.csc_sensor_loc_attr_md.read_perm); // for the sensor location characteristic, only the read permission can be set by the application, others are mendated by service specification
    err_code = ble_cscs_init(&m_cscs, &cscs_init);
void rowing_init(){
  //TODO for sim
  sensor_simulator_init();
  rowing_service_init();
  rowing_timers_init();
  rowing_timers_start();
  return;
  • Ok I was indeed doing something stupid. I did not add the cscs's ble event to the ble event dispatch.
    For anyone interested, on the Thingy this is located in m_ble.c. I had to add line 15:
    static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
        ble_conn_state_on_ble_evt(p_ble_evt);
        ble_conn_params_on_ble_evt(p_ble_evt);
        for (uint32_t i = 0; i < m_service_num; i++)
            if (m_service_handles[i].ble_evt_cb != NULL)
                m_service_handles[i].ble_evt_cb(p_ble_evt);
        //Rowing handler
        ble_cscs_on_ble_evt(&m_cscs, p_ble_evt);
        ble_tcs_on_ble_evt(&m_tcs, p_ble_evt);
    #ifdef BLE_DFU_APP_SUPPORT
        ble_dfu_on_ble_evt(&m_dfus, p_ble_evt);
    #endif // BLE_DFU_APP_SUPPORT
        ble_advertising_on_ble_evt(p_ble_evt);
