Hi, im running the sdk version 1.3.2 and Im experencing a system crash after calling
First, do you still see the problem if you use a newer version of the SDK, e.g. 1.5.0?
There has been several PRs that works around or reduces the likelyhood of this error happening.
Do you need the numbers to be cryptographically secure, or would the pseudorandom numbers from sys_rand32_get() be enough?
What else is happening in the system when you are requesting the random number?
Didrik
Hi Didrik, I hope you are having a great day
I need the numbers to be Cryptographically Secure because, Im using them for an Initialization Vector to encrypt data using AES in CTR mode.
I haven't tried upgrading the version of the SDK, I'm going to try and I let you know the results.
About other things that are happening in the system while I request the random numbers, I have another thread that only turns on and off an onboard LED, and also an interrupt handler that triggers when I press an external button. I already tried simply removing them, because I have read that the problem happens when the scheduler switches between a Secure and a Non Secure function, but the results are the same, it still crashes and reboots the System.
Emilio
