I am evaluating the SAADC options and I'm looking for sampling one input at fastest speed. Easy DMA looks promising, but my function for SAADC communication hangs, if I set
NRF_SAADC->RESULT.MAXCNT = 2;
With =1 everything works fine and I can get sample after sample. That is good for about 60kHz. When reading the specs it seems that you can set the pointer to an array of 16Bit integer and set MAXCNT to the desired amount of samples, but this does not work in my setup.
int16_t anaVal() // int16_t *values
// Serial.println("Inside hwCPUVoltage function.");
#if defined(NRF_SAADC)
// NRF52:
// Settings: 8Bit, AnalogInput4, 3us Time, internal ref., 1/6 gain, no oversample
// Serial.println("This is an NRF_SAADC.");
int32_t sample[5];
NRF_SAADC->ENABLE = SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos;
NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_8bit << SAADC_RESOLUTION_VAL_Pos;
NRF_SAADC->CH[0].PSELP = SAADC_CH_PSELP_PSELP_AnalogInput4 << SAADC_CH_PSELP_PSELP_Pos;
NRF_SAADC->CH[0].PSELN = SAADC_CH_PSELN_PSELN_NC << SAADC_CH_PSELN_PSELN_Pos;
NRF_SAADC->CH[0].CONFIG = (SAADC_CH_CONFIG_BURST_Disabled << SAADC_CH_CONFIG_BURST_Pos) |
(SAADC_CH_CONFIG_MODE_SE << SAADC_CH_CONFIG_MODE_Pos) |
(SAADC_CH_CONFIG_TACQ_3us << SAADC_CH_CONFIG_TACQ_Pos) |
(SAADC_CH_CONFIG_REFSEL_Internal << SAADC_CH_CONFIG_REFSEL_Pos) |
(SAADC_CH_CONFIG_GAIN_Gain1_6 << SAADC_CH_CONFIG_GAIN_Pos) |
(SAADC_CH_CONFIG_RESN_Bypass << SAADC_CH_CONFIG_RESN_Pos) |
(SAADC_CH_CONFIG_RESP_Bypass << SAADC_CH_CONFIG_RESP_Pos);
NRF_SAADC->OVERSAMPLE = SAADC_OVERSAMPLE_OVERSAMPLE_Bypass << SAADC_OVERSAMPLE_OVERSAMPLE_Pos;
NRF_SAADC->SAMPLERATE = SAADC_SAMPLERATE_MODE_Task << SAADC_SAMPLERATE_MODE_Pos;
NRF_SAADC->RESULT.MAXCNT = 1;
NRF_SAADC->RESULT.PTR = (int32_t)&sample[0];
NRF_SAADC->EVENTS_STARTED = 0;
NRF_SAADC->EVENTS_END = 0;
NRF_SAADC->TASKS_START = 1;
while (!NRF_SAADC->EVENTS_STARTED);
NRF_SAADC->TASKS_SAMPLE = 1;
while (!NRF_SAADC->EVENTS_END);
return sample[0];
#else
Serial.println("Unknown MCU!!");
// unknown MCU
return 0;
