I have an evaluation board with a nRF52832 chip on it. I added some code to ble_app_uart example and flashed it on the evaluation board.
Here is my problem: I added a variable "length_array" (type: uint16_t) to the ble_app_uart example. When the program uses this variable for this first time, it crashes immediately without an error code. (DEBUG is set in the preprocessor defines)
When I built my program I got no errors or warnings.
After some debugging I figured the following out:
It says "Restricted memory range".
Here are my questions:
1. What causes this error?
2. Do you have any suggestions how to solve this issue?
Thank you very much in advance.
