usbd_ble_uart(peripheral) example in the 17.0.2 SDK, LED_0 not working intended
I am currently going through the usbd_ble_uart example and understanding what states make which LED's active,
Within the example, LED_BLE_NUS_CONN  is defined as BSP_BOARD_LED_0, which is the single green LED (LD1) on the dongle.
In the below code snippet taken from the example (I have only added comments), LED_BLE_NUS_CONN should be blinking when advertising,
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            err_code = app_timer_start(m_blink_ble,
                                       APP_TIMER_TICKS(LED_BLINK_INTERVAL),
                                       (void *) LED_BLE_NUS_CONN); // this should blink when the dongle is advertising but it doesnt?
and upon connecting to a peer, the LED should stop blinking, and turn on, as seen in the below snippet:
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("BLE NUS connected");
            err_code = app_timer_stop(m_blink_ble); // this should stop LED_0 from blinking
            bsp_board_led_on(LED_BLE_NUS_CONN); // this should stay on when connected but doesnt?
There is no other code in the example that affects that LED.
However, the behaviour I am seeing is:
- Upon powering the dongle LED_0 will flash on once, and then turn off
- Upon a connection event, LED_0 will flash on once and then turn off.
I am unsure why the LED is ever turning off as I cant see any code to indicate that it should be in any other state than blinking, or solid on.
I do not believe this is a hardware issue as I have two dongles both with the same results, and I am able to run a modified blinky example to control the same LED at my will.
Any insight into why this could be happening is appreciated.
Luke
  • To add, I have also tried to add code to turn LED_0 on in other parts of the code, and it seems like something is turning it off.
    Not sure if you have seen this one:
    https://devzone.nordicsemi.com/nordic/short-range-guides/b/getting-started/posts/nrf52840-dongle-programming-tutorial
    By default the example you are looking is not made for the nRF52840 USB dongle, it is made for the nRF52840-DK. For instance you will need to set BOARD_PCA10059 (dongle) in preprocessor symbols instead of BOARD_PCA10056 (DK), this will make sure the right board file is loaded in board.h. I suspect the problem may also be related to other states are controlling these LED's (e.g. from a timer):
    https://infocenter.nordicsemi.com/topic/sdk_nrf5_v17.0.2/examples_bsp.html
    I recommend to order an nRF52840-DK if you haven't already, since the example will work out of the box then and it will also include a debugger you can use. There is no need to use the board support package, it was mainly developed to make it easy to run code for different DK's, you can remove it and control the pins directly.
    Kenneth
  • Hi, thanks for the reply
    I should have added that I have adapted the example to work for the dongle by setting BOARD_PCA10059 in the preprocessor defines, sorry about that.
    Upon further looking it seems that a bsp_init() with the BSP_INIT_LEDS flag creates an app timer like you said which ends up calling the bsp_led_indication() function which sets the LED's depending on states such as advertising and connecting - at least from my understanding.
    However, it is not only LED_0 that is set by this function, but LED_1 is set in some states such as send and recieve events - I have not noticed LED_1 changing outside of what it should do as per the example.
    As for not using the BSP, from the programming tutorial it states that the:
    "The firmware must set REGOUT0 to 3 V in order to allow it to be debugged from a DK"
    Would I therefore still be able to program the dongle from my PC using nRF Connect's Programmer app?
    Also, would I still be able to put the dongle in DFU mode by pressing the reset button without the BSP?
    With a nRF52840-DK you can both program and debug the nRF52840 Dongle over the SWD interface. Since the nRF52840-DK is fixed 3V, it may not be able to program and debug the nRF52840 Dongle if the REGOUT0 is not set to 3V. If you by accident don't set this register, you may need to un-connect the Dongle from the PC and power the Dongle with 3V to VDD directly during programming and debugging (until you load firmware that have set REGOUT0 again).
    If you program firmware to the nRF52840 Dongle that does not contain the bootloader that is required by the nRF Connect Programmers to be programmed over USB, then it may not be able to program it through USB. In such case you will need to program firmware from the nRF52840-DK that include the bootloader again for it to work as today.
    Kenneth
