Unable to set GPIO P0.17 as GPIO OUT pin.
Hi ,
I tried following steps to configure and toggle GPIO pins.
I have also set CONFIG_GPIO=y in your prj.conf file. ,referring to https://devzone.nordicsemi.com/f/nordic-q-a/44940/simple-gpio-example---nrf9160-dk-2
static void led_test(void)
int cnt = 0;
struct device *dev;
        dev = device_get_binding("GPIO_0");
        /* Set LED pin as output */
        gpio_pin_configure(dev, 2, GPIO_OUTPUT); //p0.03 == LED2
        gpio_pin_configure(dev, 3, GPIO_OUTPUT); //p0.04 == LED3
        gpio_pin_configure(dev, 4, GPIO_OUTPUT); //p0.03 == LED2
        gpio_pin_configure(dev, 5, GPIO_OUTPUT); //p0.04 == LED3
        gpio_pin_configure(dev, 17, GPIO_OUTPUT_ACTIVE); //p0.17
        gpio_pin_configure(dev, 18, GPIO_OUTPUT); //p0.18
        gpio_pin_configure(dev, 19, GPIO_OUTPUT_ACTIVE); //p0.19
        while (1)
        /* Set pin to HIGH/LOW every 1 second */
        gpio_pin_set_raw(dev, 2, cnt % 2); //p0.03 == LED2
        gpio_pin_set_raw(dev, 3, cnt % 2); //p0.04 == LED3
        gpio_pin_set_raw(dev, 4, cnt % 2); //p0.03 == LED2
        gpio_pin_set_raw(dev, 5, cnt % 2); //p0.04 == LED3
        gpio_pin_set_raw(dev, 17, cnt % 2); //p0.17 Toggling pin 17
        gpio_pin_set_raw(dev, 18, cnt % 2); //18
        gpio_pin_set_raw(dev, 19, cnt % 2); //19
        cnt++;
        k_sleep(K_MSEC(5000));
The Led1,2,3,4 will on/off in 5s, but P0.17 P0.18 P0.19 didnt change !!
Something else do we need to setup?
Do we have to make changes in dts file?
