NRF52840 DK
S140
SDK 15.3
#ifndef COMPONENTS_BOARD_UTIL_H_
#define COMPONENTS_BOARD_UTIL_H_
#include <stdbool.h>
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include "app_error.h"
#include "app_timer.h"
#include "app_uart.h"
#include "app_util.h" //add
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_hci.h"
#include "ble_nus.h"
#include "boards.h"
#include "bsp_btn_ble.h"
#include "compiler_abstraction.h" //add
#include "nordic_common.h"
#include "nrf.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_delay.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_timer.h"
#include "nrf_drv_twi.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_gpio.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
/*lint -save -e689 */ /* Apparent end of comment ignored */
#include "arm_const_structs.h"
/*lint -restore */
//* ble *//
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "blinky_new" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED /**< The advertising duration Unlimited advertising in general discoverable mode. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(20000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
/* saadc */
#define FLAME_PIN NRF_SAADC_INPUT_AIN1 /**< The hadware pin for flame detect sensor */
#define BAT_PIN NRF_SAADC_INPUT_AIN0
#define SAMPLES_IN_BUFFER 2
typedef enum _BLE_EVT {
BAT = 0,
FLAME,
TEMP,
HUMI,
BLE_EVT_COUNT
} BLE_EVT;
typedef enum _SAADC_CHANNEL {
BAT_CHANNEL = 0,
FLAME_CHANNEL
} SAADC_CHANNEL;
#endif // COMPONENTS_BOARD_UTIL_H_
static nrf_saadc_channel_config_t ch_config_flame = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(FLAME_PIN); /**< The saadc cnannel configuration of flame detect sensor. */
static nrf_saadc_channel_config_t ch_config_bat = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(BAT_PIN); /**< The saadc cnannel configuration of battery(vdd). */
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(3);
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t m_ppi_channel;
#define who 5
#define me 0
/* dht 22 */
#define MAX_TIMINGS 85
#define DHT_PIN 33
int data_th[5] = { 0, 0, 0, 0, 0 };
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
APP_TIMER_DEF(m_repeated_timer_id);
static int batlevel=0;
static int acccount=0;
/**@brief Function for controlling current event.
* @param[in] control_evt current event.
static void sendBle(int control_evt, int value)
char msg[6];
uint8_t control_msg[6];
switch (control_evt)
case BAT:
sprintf(msg, "%d %d", BAT, value);
case FLAME:
sprintf(msg, "%d %d", FLAME, value);
case TEMP:
sprintf(msg, "%d %d", TEMP, value);
case HUMI:
sprintf(msg, "%d %d", HUMI, value);
case who:
sprintf(msg, "%d%d", who, me);
memcpy(control_msg, msg, sizeof(msg));
uint16_t length = sizeof(control_msg);
ble_nus_data_send(&m_nus, control_msg, &length, m_conn_handle);
//printf("message = %s\n", control_msg);
memset(control_msg, 0, sizeof(msg));
void read_dht_data()
uint8_t laststate = 1;
uint8_t counter = 0;
uint8_t j = 0, i;
data_th[0] = data_th[1] = data_th[2] = data_th[3] = data_th[4] = 0;
/* pull pin down for 18 milliseconds */
nrf_gpio_cfg_output(DHT_PIN);
nrf_gpio_pin_write(DHT_PIN, 0 );
nrf_delay_ms(18);
/* prepare to read the pin */
nrf_gpio_cfg_input(DHT_PIN, NRF_GPIO_PIN_NOPULL);
/* detect change and read data */
for ( i = 0; i < MAX_TIMINGS; i++ )
counter = 0;
while ( nrf_gpio_pin_read(DHT_PIN) == laststate )
counter++;
nrf_delay_us(1);
if ( counter == 255 )
laststate = nrf_gpio_pin_read(DHT_PIN);
/* ignore first 3 transitions */
if ( (i >= 4) && (i % 2 == 0) )
/* shove each bit into the storage bytes */
data_th[j / 8] <<= 1;
if ( counter > 16 )
data_th[j / 8] |= 1;
j++;
* check we read 40 bits (8bit x 5 ) + verify checksum in the last byte
* print it out if data is good
if ( (j >= 40) &&
(data_th[4] == ( (data_th[0] + data_th[1] + data_th[2] + data_th[3]) & 0xFF) ) )
float h = (float)((data_th[0] << 8) + data_th[1]) / 10;
if ( h > 100 )
h = data_th[0]; // for DHT11
float c = (float)(((data_th[2] & 0x7F) << 8) + data_th[3]) / 10;
if ( c > 125 )
c = data_th[2]; // for DHT11
if ( data_th[2] & 0x80 )
c = -c;
float f = c * 1.8f + 32;
printf( "Humidity = %.1f %% Temperature = %.1f *C (%.1f *F)\n", h, c, f );
}else {
printf( "Data not good, skip\n" );
//* saadc *//
void timer_handler(nrf_timer_event_t event_type, void * p_context)
ret_code_t err_code;
/* setup m_timer for compare event every 250ms */
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 11000);
/* NRF_TIMER_CC_CHANNEL0 is used by Softdevice so, we should use other channel instead of channel 0 */
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
timer_compare_event_addr,
saadc_sample_task_addr);
nrf_saadc_value_t bat_result;
uint16_t batt_lvl_in_milli_volts;
uint8_t percentage_batt_lvl;
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
bat_result = p_event->data.done.p_buffer[BAT_CHANNEL];
uint16_t flame = p_event->data.done.p_buffer[FLAME_CHANNEL];
sendBle(FLAME, flame);
nrf_delay_ms(500);
printf("\nflame: %d\n", flame);
// printf(" batlevel : %d\n",batlevel);
/**@brief Function for initializing the saadc
void saadc_init(void)
nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
ch_config_flame.gain = NRF_SAADC_GAIN1_4;
ch_config_flame.reference = NRF_SAADC_REFERENCE_INTERNAL;
ch_config_bat.gain = NRF_SAADC_GAIN1_6;
ch_config_bat.reference = NRF_SAADC_REFERENCE_INTERNAL;
err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
err_code = nrf_drv_saadc_channel_init(FLAME_CHANNEL, &ch_config_flame);
err_code = nrf_drv_saadc_channel_init(BAT_CHANNEL, &ch_config_bat);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
//* ble things *//
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
uint32_t err_code;
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
do
err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
NRF_LOG_INFO("Disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_SHORT_NAME;
init.advdata.short_name_len = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE; // change mode : limited->general
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
int8_t tx_power_level = -40; //add
init.advdata.p_tx_power_level = &tx_power_level; //add
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
static void repeated_timer_handler(void * p_context)
read_dht_data();
nrf_delay_ms(2000);
static void create_timers()
err_code = app_timer_create(&m_repeated_timer_id,
APP_TIMER_MODE_REPEATED,
repeated_timer_handler);
static void start_repeated_timer()
err_code = app_timer_start(m_repeated_timer_id, APP_TIMER_TICKS(15000), NULL); //1020000(17min)
/**@brief Application main function.
bool erase_bonds;
// Initialize.
uart_init();
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
saadc_init();
saadc_sampling_event_init();
create_timers();
start_repeated_timer();
advertising_start();
nrf_delay_ms(3000);
// Enter main loop.
for (;;)
Hello
I want to read the value of dht22 at regular intervals using the _timer_handle.
But I can't read the value.
i read this and this of DEVZONE, failed to resolve.
How can I get the value?
