secure_bootloader_uart_mbr_pca10056_debug questions
  • Shalom!
     I do not need to use uECC if it is not the best way. If you say the other way has hardware acceleration it makes no sense not to use!
    If I do not use uECC how can I change the pca10056_uart_debug_266089 project to work without it?
    In the project I have both enabled.
    #ifndef NRF_CRYPTO_BACKEND_NRF_SW_ENABLED
    #define NRF_CRYPTO_BACKEND_NRF_SW_ENABLED 1
    #ifndef NRF_CRYPTO_BACKEND_MICRO_ECC_ENABLED
    #define NRF_CRYPTO_BACKEND_MICRO_ECC_ENABLED 1
    What do I need to do to get the SDK pca10056_uart_debug proecjt to work without uECC (defines)?
    I thought I read that I need to change the start address in my application, is this true and how.
    Thank you very much
  • Rever back to the default setting:
    disable NRF_CRYPTO_BACKEND_NRF_SW_ENABLED (0) and  NRF_CRYPTO_BACKEND_NRF_SW_ENABLED (0), and enable NRF_CRYPTO_BACKEND_CC310_BL_ENABLED (1).
    Let me know that can fix the error or not. Thanks.
    -Amanda H.
  • I changed the defines not to use uECC and got passed sending the x.dat part of the update.
    Do I need to change the starting or other addresses in my Application to work with the non-uECC secure bootloader?
    I got from my host debug something that the offset and CRC are not correct.
    It looks like I have a bug in my code that I will now check as it seems that the program code sent is all 0xFFs.
    18/03/2021 14:31:36[dfu_serial.c: 216] SLIP: <-- [96, 3, 1, 0, 16, 1, 0, 234, 100, 197, 116]
    18/03/2021 14:31:36[dfu_serial.c: 494] Invalid offset (65536 -> 69632)!
    18/03/2021 14:31:36[dfu_serial.c: 500] Invalid CRC (0x34EF5950 -> 0x74C564EA)!
    Thank you
    ARM host
    18/03/2021 14:31:32[dfu_serial.c: 201] SLIP: --> [9, 5]
    18/03/2021 14:31:32[dfu_serial.c: 216] SLIP: <-- [96, 43, 2]
    18/03/2021 14:31:32[dfu_serial.c: 238] Invalid response!
    18/03/2021 14:31:34[ami_io.c:1141] ADC 2778 0 1 0 2
    18/03/2021 14:31:36[dfu_serial.c: 201] SLIP: --> [9, 6]
    18/03/2021 14:31:36[dfu_serial.c: 216] SLIP: <-- [96, 9, 1, 6]
    18/03/2021 14:31:36[dfu_serial.c: 281] Set Packet Receipt Notification 0
    18/03/2021 14:31:36[dfu_serial.c: 201] SLIP: --> [2, 0, 0]
    18/03/2021 14:31:36[dfu_serial.c: 216] SLIP: <-- [96, 2, 1]
    18/03/2021 14:31:36[dfu_serial.c: 201] SLIP: --> [7]
    18/03/2021 14:31:36[dfu_serial.c: 216] SLIP: <-- [96, 7, 1, 131, 0]
    18/03/2021 14:31:36[dfu_serial.c: 658] Sending init packet...
    18/03/2021 14:31:36[dfu_serial.c: 334] Selecting Object: type:1
    18/03/2021 14:31:36[dfu_serial.c: 201] SLIP: --> [6, 1]
    18/03/2021 14:31:36[dfu_serial.c: 216] SLIP: <-- [96, 6, 1, 0, 2, 0, 0, 141, 0, 0, 0, 173, 88, 200, 169]
    18/03/2021 14:31:36[dfu_serial.c: 353] Object selected:  max_size:512 offset:141 crc:0xA9C858AD
    18/03/2021 14:31:36[dfu_serial.c: 201] SLIP: --> [4]
    18/03/2021 14:31:36[dfu_serial.c: 216] SLIP: <-- [96, 4, 1]
    18/03/2021 14:31:36[dfu_serial.c: 717] Sending firmware file...
    18/03/2021 14:31:36[dfu_serial.c: 334] Selecting Object: type:2
    18/03/2021 14:31:36[dfu_serial.c: 201] SLIP: --> [6, 2]
    18/03/2021 14:31:36[dfu_serial.c: 216] SLIP: <-- [96, 6, 1, 0, 16, 0, 0, 0, 0, 1, 0, 254, 81, 122, 123]
    18/03/2021 14:31:36[dfu_serial.c: 353] Object selected:  max_size:4096 offset:65536 crc:0x7B7A51FE
    18/03/2021 14:31:36[dfu_serial.c: 201] SLIP: --> [1, 2, 0, 16, 0, 0]
    18/03/2021 14:31:36[dfu_serial.c: 216] SLIP: <-- [96, 1, 1]
    18/03/2021 14:31:36[dfu_serial.c: 479] Streaming Data: len:4096 offset:61440 crc:0x1F227120
    18/03/2021 14:31:36[dfu_serial.c: 201] SLIP: --> [8, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 2
    18/03/2021 14:31:36[dfu_serial.c: 201] SLIP: --> [3]
    RTT
    J-Link - Web control panel [RTT]
    General
    Settings
    Breakpoints
    RTT
    Log
    CPU Regs
    Target Power
    SWV
    RAWTrace
    STrace
    LiveTrace
    Flash
    Commander
    Help
    Status & Settings
    Control block address:
    (0 == Auto-detection)
    Status:
    Data rate:
    Total received:
    Buffered:
    Target -> Host
    Show data for channel:
    <info> nrf_dfu_serial_uart: Allocated buffer 20003788
    <info> nrf_dfu_req_handler: Invalid opcode received: 0x2B.
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x2
    <warning> nrf_dfu_serial: DFU request completed with result: 0x2
    <debug> nrf_dfu_serial: Sending Response: [0x2B, 0x2]
    <debug> nrf_dfu_serial: Received ping 6
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_PING
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_serial: Sending Response: [0x9, 0x1]
    <debug> nrf_dfu_serial: Set receipt notif target: 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
    <debug> nrf_dfu_serial: Sending Response: [0x2, 0x1]
    <debug> nrf_dfu_serial: Received serial mtu
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_MTU_GET
    <debug> nrf_dfu_serial: Sending Response: [0x7, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
    <debug> nrf_dfu_serial: Sending Response: [0x6, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
    <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
    <info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
    <debug> nrf_dfu_req_handler: Writing valid init command to flash.
    <debug> nrf_dfu_serial: Sending Response: [0x4, 0x1]
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
    <debug> nrf_dfu_req_handler: crc = 0x7B7A51FE, offset = 0x10000, max_size = 0x1000
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00037000, len=1 pages), queue usage: 0
    <debug> nrf_dfu_flash: Flash erase success: addr=0x00037000, pending 0
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00010000, CRC: 0x7B7A51FE
    <debug> nrf_dfu_serial: Sending Response: [0x1, 0x1]
    <info> nrf_dfu_serial_uart: Allocated buffer 2000380C
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037000, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037000, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037040, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037040, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037080, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037080, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000370C0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000370C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037100, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037100, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037140, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037140, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037180, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037180, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000371C0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000371C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037200, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037200, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037240, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037240, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037280, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037280, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000372C0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000372C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037300, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037300, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037340, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037340, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037380, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037380, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000373C0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000373C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037400, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037400, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037440, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037440, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037480, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037480, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000374C0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000374C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037500, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037500, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037540, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037540, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037580, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037580, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000375C0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000375C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037600, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037600, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037640, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037640, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037680, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037680, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000376C0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000376C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037700, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037700, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037740, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037740, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037780, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037780, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000377C0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000377C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037800, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037800, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037840, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037840, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037880, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037880, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000378C0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000378C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037900, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037900, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037940, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037940, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037980, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037980, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000379C0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x000379C0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037A00, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037A00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037A40, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037A40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037A80, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037A80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037AC0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037AC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037B00, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037B00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037B40, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037B40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037B80, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037B80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037BC0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037BC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037C00, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037C00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037C40, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037C40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037C80, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037C80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037CC0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037CC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037D00, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037D00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037D40, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037D40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037D80, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037D80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037DC0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037DC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037E00, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037E00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037E40, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037E40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037E80, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037E80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037EC0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037EC0, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037F00, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037F00, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037F40, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037F40, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037F80, src=0x2000378C, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037F80, pending 0
    <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00037FC0, src=0x20003810, len=64 bytes), queue usage: 1
    <debug> nrf_dfu_flash: Flash write success: addr=0x00037FC0, pending 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
    <debug> nrf_dfu_req_handler: Offset:69632, CRC:0x74C564EA
    <debug> nrf_dfu_serial: Sending Response: [0x3, 0x1]
    <debug> app: timer_stop (0x20000024)
    <debug> app: : Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_settings: Using settings page.
    <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <info> app: Boot validation failed. No valid app to boot.
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <debug> app: timer_activate (0x20000024)
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> nrf_dfu_validation: PB: Init packet data len: 64
    <debug> app: Enter main loop
    Host -> Target
    Send CR on <Return>
    Send LF on <Return>
    SEGGER Microcontroller GmbH || www.segger.com
  • Shalom!
     I am advancing it seems. This is my last log till next week as we work Sunday through Thursday.
    My host debug:
    18/03/2021 15:30:26[dfu_serial.c: 216] SLIP: <-- [96, 3, 1, 0, 0, 1, 0, 45, 33, 232, 235]
    18/03/2021 15:30:26[dfu_serial.c: 201] SLIP: --> [4]
    18/03/2021 15:30:26[dfu_serial.c: 216] SLIP: <-- [96, 4, 1]
    18/03/2021 15:30:26[dfu_serial.c: 201] SLIP: --> [1, 2, 0, 16, 0, 0]
    18/03/2021 15:30:26[dfu_serial.c: 216] SLIP: <-- [96, 1, 1]
    18/03/2021 15:30:26[dfu_serial.c: 479] Streaming Data: len:4096 offset:65536 crc:0xEBE82
    The RTT:
    <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00037000, len=1 pages), queue usage: 1
    <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00010000, CRC: 0xEBE8212D
    Thank you and have a good week end
    David Kaplan
    RTT3.txt
  • Hi David,
    Not sure the problem is in the bootloader or the host. Are you able to test the bootloader and application without updating via ARM host? To make sure this part can work without issue.
    You could upload the application by entering the following command to start the DFU process over the serial link, where package.zip is the name of the firmware package that you want to upload and COM_PORT is the COM port to which the device is connected:
    nrfutil dfu serial -pkg package.zip -p COM_PORT for UART transport
    Do you see any error from the RTT log? Could the nRF52840 boot up to the new application after updating?
    -Amanda H.
