UART data loss on nRF52840DK
Hi all,
Project description and what works:
in my project I have one nRF52840DK as central and three nRF52DK as peripheral. The code on the central is based on the "nrf52-ble-app-uart-c-multilink-master" example and the code on the peripherals is based on the "ble_app_uart" example. Each peripheral sends data with a data-rate of 5,125 kByte/s (41 kBit/s) to the central. To be more precise, each peripheral sends 205 Bytes of data every 40ms. This works like a charm, without errors. (:
Problem:
At the moment I am having trouble with the UART on the central side. The data of all three data links has to be written via UART to a PC (virtual COM port). So the UART has to handle 3*41kBit/s = 123kBit/s. The order or the exact time, when each NUS paket gets written into the virtual COM port does not matter. But no data should be lost in this process. The problem is that the UART dropps data at this data rate. The loss of data is very inconsistent and random.
Test Setup:
To verify the function of the UART each peripheral sends consistently a 205 byte long array (as a NUS-paket) to the central. The NUS paket of each peripheral contains different characters:
Peripheral 1:  !!!!!!!!!!!!!!!!!!!!!!! .... (205 elements)
Peripheral 2: """""""""""""""""" .... (205 elements)
Peripheral 3: ############ .... (205 elements)
I use Putty to view the data which is written in the virtual COM port.
Test Results:
As we can see, UART drops data. Normally I should see 205 elements of each character.
Questions
1. First of all, is the usage of putty in this case reliable? Or did just windows cant keep up with printing this chars in this console?
2. Is there a other/better way to evaluate this?
3. What are the correct parameters in this case for ...
3.1 ... UART_TX_BUF_SIZE and UART_RX_BUF_SIZE? (Actual: 32768)
3.2 ... priority in APP_UART_FIFO_INIT? (Actual: APP_IRQ_PRIORITY_MID)
3.3 ... baudrate in uart_init()? (Actual: UART_BAUDRATE_BAUDRATE_Baud460800)
4. Do I have to change the chosen baudrate in the windows device manager (COM) as well?
5. Can you please provide me any suggestions or help on how to solve this issue?
Any kind of feedback is appreciated. Thank you so much in advance.
Maria
  • Hello Maria,
    Have you tried to debug this issue? Can you see whether all the data is correctly received over BLE?
    There are several places the data can "get lost". UART -> peripheral -> BLE -> Central -> UART.
    Try to set a breakpoint, or to print only the length of the received data on the central. See if the length is what you expect. What you might see is that the data is lost either when the central tries to print the data on the UART, or on the peripheral when the UART tries to read all the data. If the cap is the UART speed,  you can try to use an even higher baudrate. Have you tried 1000000?
    BR,
    Edvin
  • Hello Edvin,
    thank you very much for your quick reply.
    I already tried to debug this issue. But until your answer I did not really know what I should debug.
    As you suggested, I checked the length of the received data on central. I added the following to the code to the central:
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
        //DEBUG
        if (data_len != 205)
            NRF_LOG_INFO("Too short");
    The "Too short" message gets never printed. So the length of the received data is correct.
    I figured also out that the printed data via Putty only gets messed up, if I do another heavy task on my pc. So maybe the data in the serial port is correct but putty cant print the data out properly, because it does not always get the required resources from windows. So maybe I have to use another data sink to receive my data from the virtual COM port. I think I have to use a software where I can set up a really large input buffer for the serial port (e.g. LabVIEW). What do you think about this?
    At the moment I am also struggeling with choosing the right baudrate. Which would be the correct baudrate when I want to transmit data with 123 kBit/s over it?
    And finally, does it even make sense to change the UART_TX_BUF_SIZE and UART_RX_BUF_SIZE on the central to their maximum value?
    Thank you very much in advance. Any kind of feedback is always appreciated.
    Maria
    #Edit: Is there a proper way to debug, if the central prints all the data correct on the UART?
    Thank you again very much.
  • Hello Maria,
    Ok, so I guess we can eliminate the data disappearing before reaching the central then.
     I guess it would make sense since the central is the one who has the must UART throughput.
     115200 is 115kbit/s, so that is too slow. 460800 should be enough for a steady 123000bit\s, but please be aware that you are not necessarily seeing a "steady" 123kbps. You get your data in chunks with size whatever your message size is.
    What function do you use to print your data? Are you using the unmodified ble_app_uart_c implementation? Perhaps you can zip it and upload it here, because you have at least made that sample support multiple connections, so you probably did some changes. Perhaps I can have a look.
    Your computer shouldn't struggle to keep up with a UART, but keep in mind that UART is a fairly slow protocol. Also, since your data is coming in bulks, I would try to increase the baudrate to 1000000, and increase the UART_TX_BUF_SIZE, but whether or not that helps depends on the rest of the implementation. What will happen if you get two interrupts fairly close (before the first is done printing)?
    BR,
    Edvin
  • Hello Edvin,
    thank you very much for your answer.
    115200 is 115kbit/s
    So it seems that my calculations were correct. However, I increased the baudrate to 1000000 to get the most performance out of it.
    I am using the default function for printing characters in the UART from the ble_app_uart_c example:
        ret_code_t ret_val;
        //DEBUG
        NRF_LOG_DEBUG("Receiving data.");
        NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
        for (uint32_t i = 0; i < data_len; i++)
            do
                ret_val = app_uart_put(p_data[i]);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                    APP_ERROR_CHECK(ret_val);
            } while (ret_val == NRF_ERROR_BUSY);
    Is there an alternative?
    No. The code is based on the nrf-52-ble-app-uart-c-multilink example (from here: github.com/.../nrf52-ble-app-uart-c-multilink). I also added the wireless timer synchronization functionality to it.
    But the way how the data gets printed on the UART is the same as in the original "ble_app_uart_c" example.
    nrf52-ble-app-uart-c-multilink-master_with_timesync_2.zip
    I am using pca10056.
    I increased this buffer to the maximum possible. (32768)
    To be honest, I do not really know that at the moment. But I will check that out.
    Current Status:
    I wrote a small application in LabVIEW which generates a message, when the received data over the COM-Port does not contain 205 same elements in a row.
    After 1-3 minutes I receive that messages and some data was lost. So it is definitely the UART on the Central which drops some bytes.
    Can you recommend me any settings of the UART which could fix that?
    Do you have suggestions?
    Thank you soo much in advance :)
    Maria
     Was this while using baudrate = 1 000 000?
    Is your only option to use UART? Is the product going to be communicating with a computer or another MCU?  If you are using another MCU, I would recommend SPI, as it is a lot faster.
     How is that data sent? from BLE interrupts, or are you generating this UART data from your central application?
    Can you try to use your RX events to just copy the data into separate buffers, and use some flag to print these buffers over UART and see if that helps on the situation?
    If that doesn't work, it may be that you need to look into flow control. Are you using the DKs programmer to transfer the UART data, or another external UART device?
