BLE connection with pin code
I'm using NRF52840 in order to connect to a mobile device, with PIN code.
Connection to Android is ok. The issue is with IOS.
IOS can't send the PIN code to my device, I understand that NRF device should transmit it's services so IOS will read it before sending the PIN code. Am I right?
Thanks!
Parents Reply
    The "insufficient authentication" error will be sent automatically by the Softdevice if the peer tries to read/write a characteristic that is configured to require a higher security level. So you need to configure the security level for the characteristic you want to " protect" by requiring pairing and entering a pin.
    From the heart rate example:
        // Here the sec level for the Heart Rate Service can be changed/increased.
        hrs_init.hrm_cccd_wr_sec = SEC_JUST_WORKS;
        hrs_init.bsl_rd_sec      = SEC_JUST_WORKS;
        err_code = ble_hrs_init(&m_hrs, &hrs_init);
    Notice that the required security level is just works in this case. You should probably require SEC_MITM since you are using a PIN.
