DFU gcc linker setting
I have a question regarding linker file in case of gcc make. I need to create a DFU package and program the it on a bootloader.
Here is my linker file:
/* Linker script to configure memory regions. */
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
  FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0x5a000
  RAM (rwx) :  ORIGIN = 0x20002bf0, LENGTH = 0xd410
SECTIONS
SECTIONS
  . = ALIGN(4);
  .mem_section_dummy_ram :
  .cli_sorted_cmd_ptrs :
    PROVIDE(__start_cli_sorted_cmd_ptrs = .);
    KEEP(*(.cli_sorted_cmd_ptrs))
    PROVIDE(__stop_cli_sorted_cmd_ptrs = .);
  } > RAM
  .fs_data :
    PROVIDE(__start_fs_data = .);
    KEEP(*(.fs_data))
    PROVIDE(__stop_fs_data = .);
  } > RAM
  .log_dynamic_data :
    PROVIDE(__start_log_dynamic_data = .);
    KEEP(*(SORT(.log_dynamic_data*)))
    PROVIDE(__stop_log_dynamic_data = .);
  } > RAM
  .log_filter_data :
    PROVIDE(__start_log_filter_data = .);
    KEEP(*(SORT(.log_filter_data*)))
    PROVIDE(__stop_log_filter_data = .);
  } > RAM
} INSERT AFTER .data;
SECTIONS
  .mem_section_dummy_rom :
  .sdh_soc_observers :
    PROVIDE(__start_sdh_soc_observers = .);
    KEEP(*(SORT(.sdh_soc_observers*)))
    PROVIDE(__stop_sdh_soc_observers = .);
  } > FLASH
  .sdh_ble_observers :
    PROVIDE(__start_sdh_ble_observers = .);
    KEEP(*(SORT(.sdh_ble_observers*)))
    PROVIDE(__stop_sdh_ble_observers = .);
  } > FLASH
  .pwr_mgmt_data :
    PROVIDE(__start_pwr_mgmt_data = .);
    KEEP(*(SORT(.pwr_mgmt_data*)))
    PROVIDE(__stop_pwr_mgmt_data = .);
  } > FLASH
    .nrf_queue :
    PROVIDE(__start_nrf_queue = .);
    KEEP(*(.nrf_queue))
    PROVIDE(__stop_nrf_queue = .);
  } > FLASH
  .sdh_req_observers :
    PROVIDE(__start_sdh_req_observers = .);
    KEEP(*(SORT(.sdh_req_observers*)))
    PROVIDE(__stop_sdh_req_observers = .);
  } > FLASH
  .sdh_state_observers :
    PROVIDE(__start_sdh_state_observers = .);
    KEEP(*(SORT(.sdh_state_observers*)))
    PROVIDE(__stop_sdh_state_observers = .);
  } > FLASH
  .sdh_stack_observers :
    PROVIDE(__start_sdh_stack_observers = .);
    KEEP(*(SORT(.sdh_stack_observers*)))
    PROVIDE(__stop_sdh_stack_observers = .);
  } > FLASH
    .nrf_balloc :
    PROVIDE(__start_nrf_balloc = .);
    KEEP(*(.nrf_balloc))
    PROVIDE(__stop_nrf_balloc = .);
  } > FLASH
    .cli_command :
    PROVIDE(__start_cli_command = .);
    KEEP(*(.cli_command))
    PROVIDE(__stop_cli_command = .);
  } > FLASH
  .crypto_data :
    PROVIDE(__start_crypto_data = .);
    KEEP(*(SORT(.crypto_data*)))
    PROVIDE(__stop_crypto_data = .);
  } > FLASH
  .log_const_data :
    PROVIDE(__start_log_const_data = .);
    KEEP(*(SORT(.log_const_data*)))
    PROVIDE(__stop_log_const_data = .);
  } > FLASH
  .log_backends :
    PROVIDE(__start_log_backends = .);
    KEEP(*(SORT(.log_backends*)))
    PROVIDE(__stop_log_backends = .);
  } > FLASH
} INSERT AFTER .text
INCLUDE "nrf_common.ld"
I know that I should define  the location where bootloader start address is stored in this file. But I have not found any example.
My second question is that how I can find this address in my bootloader file?
Thanks
    Take a look at the gcc linker setting in SDK_folder\examples\ble_peripheral\ble_app_buttonless_dfu\pca10040\s132\armgcc\ble_app_buttonless_dfu_gcc_nrf52.ld
    The bootloader linker script will write the bootloader start address to the UICR register. This value will be written in the bootloader HEX file and thus written to UICR when the bootloader is flashed into the chip. See the file nrf_bootloader_info.c
  • thanks for your reply.
    so if I replace the linker file by ble_app_buttonless_dfu_gcc_nrf52.ld and modify  FLASH (rx) and RAM (rwx) it should work?
     Yes, I think that should be enough. If you are using the bottonless DFU service, then you might need to call ble_dfu_buttonless_async_svci_init() in your main function as well.
  • I am going to try it.
    But know I have another question. I used hrs example and then I added ble_dfu_buttonless_async_svci_init() to it in Keil. DFU seems to work correctly. I wonder if there I correctly configured everything. For example Flash length is different in gcc linker file.
  • I tryed to change the flash and ram size to
    MEMORY
      FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0x52000
      uicr_bootloader_start_address (r) : ORIGIN = 0x10001014, LENGTH = 0x4
    SECTIONS
      . = ALIGN(4);
      .uicr_bootloader_start_address :
        PROVIDE(__start_uicr_bootloader_start_address = .);
        KEEP(*(SORT(.uicr_bootloader_start_address*)))
        PROVIDE(__stop_uicr_bootloader_start_address = .);
      } > uicr_bootloader_start_address
    I could compile and link and creat the package. But when I tryed to program the package via DFU, the connection stoped and the package did not upload.
