SDK 14.2, S140, NRF52840
I was trying to use the low_power_pwm library but upon copying the code from the lpp example, I get this:
Linking ble_bse_pca10056_s40.elf, 4 errors
"C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30/gcc/arm-none-eabi/bin/ld" -X --omagic -eReset_Handler --defsym=__vfprintf=__vfprintf_long --defsym=__vfscanf=__vfscanf_int -EL --gc-sections "-TC:/<path to project folder>/Output/ble_bse_pca10056_s140 Debug/Obj/ble_bse_pca10056_s140.ld" -Map Output/Debug/Exe/ble_bse_pca10056_s140.map -u_vectors -o Output/Debug/Exe/ble_bse_pca10056_s140.elf --emit-relocs --start-group "@C:/<path to project folder>/Output/ble_bse_pca10056_s140 Debug/Obj/ble_bse_pca10056_s140.ind" --end-group
even though I have specified #include "low_power_pwm.h" at the top of the file. Any ideas why this is happening? All my other #includes work.
PWM code below, where LED_GREEN is the GPIO pin number for the green LED.
static low_power_pwm_t low_power_pwm_green;
* @brief Function to be called in timer interrupt.
* @param[in] p_context General purpose pointer (unused).
static void pwm_handler(void * p_context)
uint8_t new_duty_cycle;
static uint16_t led_0, led_1;
uint32_t err_code;
UNUSED_PARAMETER(p_context);
low_power_pwm_t * pwm_instance = (low_power_pwm_t*)p_context;
NRF_LOG_INFO("<in PWM handler>"); // placeholder to make sure function works
* @brief Function to initalize low_power_pwm instances.
static void pwm_init(void)
uint32_t err_code;
low_power_pwm_config_t low_power_pwm_config;
APP_TIMER_DEF(pwm_timer_green);
low_power_pwm_config.active_high = false;
low_power_pwm_config.period = 220;
low_power_pwm_config.bit_mask = 1 << LED_GREEN;
low_power_pwm_config.p_timer_id = &pwm_timer_green;
low_power_pwm_config.p_port = NRF_GPIO;
err_code = low_power_pwm_init((&low_power_pwm_green), &low_power_pwm_config, pwm_handler);
err_code = low_power_pwm_duty_set(&low_power_pwm_green, 20);
err_code = low_power_pwm_start((&low_power_pwm_green), low_power_pwm_green.bit_mask);
pwm_init(); is called in main() after services_init(), advertising_init(), etc.
I have tried rebuilding the solution, cleaning & rebuilding the solution. Nothing solves the compilation error. The file low_power_pwm.h is unmodified. The error persists after I add the low_power_pwm.c file to the project via these instructions from Segger. I added it as an existing file, then I dragged it to the nrf_Libraries folder within the project.
