ADXL 345 SPI Master
Hello All, I have modifies the Spi Master code to communicate with an ADXL345 Accelerometer. I set up my powermode and the percesion in the setup phase. However, when I send my accelerometer 0X32 (the address of the register I want to read . Data sheet : www.analog.com/.../ADXL345.pdf) I receive nonsense on an oscilloscope. I am attaching the code so you could see. I appreciate your feedback. Milad
#include "nrf_delay.h"
#include "nrf_gpio.h"
#include "app_error.h"
#include "spi_master.h"
#include "bsp.h"
#include "app_timer.h"
#include "app_gpiote.h"
#include "nordic_common.h"
#define APP_TIMER_PRESCALER      0                      /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_MAX_TIMERS     BSP_APP_TIMERS_NUMBER  /**< Maximum number of simultaneously created timers. */
#define APP_TIMER_OP_QUEUE_SIZE  2                      /**< Size of timer operation queues. */
#define DELAY_MS                 1000                   /**< Timer Delay in milli-seconds. */
/** @def  TX_RX_MSG_LENGTH
 * number of bytes to transmit and receive. This amount of bytes will also be tested to see that
 * the received bytes from slave are the same as the transmitted bytes from the master */
#define TX_RX_MSG_LENGTH         6
#if defined(SPI_MASTER_0_ENABLE) || defined(SPI_MASTER_1_ENABLE)
typedef enum
    TEST_STATE_SPI0_LSB,    /**< Test SPI0, bits order LSB */
    TEST_STATE_SPI0_MSB,    /**< Test SPI0, bits order MSB */
} spi_master_ex_state_t;
static uint8_t m_tx_data_spi[TX_RX_MSG_LENGTH]; /**< SPI master TX buffer. */
static uint8_t m_rx_data_spi[TX_RX_MSG_LENGTH]; /**< SPI master RX buffer. */
static volatile bool m_transfer_completed = true;
static spi_master_ex_state_t m_spi_master_ex_state = TEST_STATE_SPI0_MSB;
/**@brief Function for error handling, which is called when an error has occurred.
 * @param[in] error_code  Error code supplied to the handler.
 * @param[in] line_num    Line number where the handler is called.
 * @param[in] p_file_name Pointer to the file name.
void app_error_handler(uint32_t error_code, uint32_t line_num, const uint8_t * p_file_name)
    UNUSED_VARIABLE(bsp_indication_set(BSP_INDICATE_FATAL_ERROR));
    for (;; )
        // No implementation needed.
/**@brief The function initializes TX buffer to values to be sent and clears RX buffer.
 * @note Function initializes TX buffer to values from 0 to (len - 1).
 *       and clears RX buffer (fill by 0).
 * @param[out] p_tx_data    A pointer to a buffer TX.
 * @param[out] p_rx_data    A pointer to a buffer RX.
 * @param[in] len           A length of the data buffers.
static void init_buf(uint8_t * const p_tx_buf,
                     uint8_t * const p_rx_buf,
                     const uint16_t  len)
    uint16_t i;
	       p_tx_buf[0] = 0;
	       p_tx_buf[1] = 0;
    for (i = 0; i < 6; i++)
        p_rx_buf[1] = 0;
/**@brief Function for checking if buffers are equal.
 * @note Function compares each element of p_tx_buf with p_rx_buf.
 * @param[in] p_tx_data     A pointer to a buffer TX.
 * @param[in] p_rx_data     A pointer to a buffer RX.
 * @retval true     Buffers are equal.
 * @retval false    Buffers are different.
static bool check_buf_equal(const uint8_t * const p_tx_buf,
                            const uint8_t * const p_rx_buf,
                            const uint16_t        len)
    uint16_t i;
    for (i = 0; i < len; i++)
        if (p_tx_buf[i] != p_rx_buf[i])
            return false;
    return true;
static void init_buf2(uint8_t * const p_tx_buf,
                     const uint16_t  len)
    uint16_t i;
	       p_tx_buf[0] = 0x32;
void spi_master_0_event_handler(spi_master_evt_t spi_master_evt)
    uint32_t err_code = NRF_SUCCESS;
    bool result = false;
    switch (spi_master_evt.evt_type)
        case SPI_MASTER_EVT_TRANSFER_COMPLETED:
            // Check if received data is correct.
            result = check_buf_equal(m_tx_data_spi, m_rx_data_spi, TX_RX_MSG_LENGTH);
            APP_ERROR_CHECK_BOOL(result);
            // Close SPI master.
            spi_master_close(SPI_MASTER_0);
            err_code = bsp_indication_set(BSP_INDICATE_RCV_OK);
/**@brief Function for initializing a SPI master driver.
 * @param[in] spi_master_instance       An instance of SPI master module.
 * @param[in] spi_master_event_handler  An event handler for SPI master events.
 * @param[in] lsb                       Bits order LSB if true, MSB if false.
static void spi_master_init(spi_master_hw_instance_t   spi_master_instance,
                            spi_master_event_handler_t spi_master_event_handler,
                            const bool                 lsb)
    // Configure SPI master.
    spi_master_config_t spi_config = SPI_MASTER_INIT_DEFAULT;
    switch (spi_master_instance)
        case SPI_MASTER_0:
            spi_config.SPI_Pin_SCK  = 29;
            spi_config.SPI_Pin_MISO = 28;
            spi_config.SPI_Pin_MOSI = 25;
            spi_config.SPI_Pin_SS   = 23;
    spi_config.SPI_CONFIG_ORDER = (lsb ? SPI_CONFIG_ORDER_LsbFirst : SPI_CONFIG_ORDER_MsbFirst);
    err_code = spi_master_open(spi_master_instance, &spi_config);
    // Register event handler for SPI master.
    spi_master_evt_handler_reg(spi_master_instance, spi_master_event_handler);
/**@brief Function for sending and receiving data.
 * @param[in]   spi_master_hw_instance  SPI master instance.
static void spi_send_recv(const spi_master_hw_instance_t spi_master_hw_instance,
                          uint8_t * const                p_tx_data,
                          uint8_t * const                p_rx_data,
                          const uint16_t                 len)
    // Initalize buffers.
    init_buf(p_tx_data, p_rx_data, 6);
    // Start transfer.
    uint32_t err_code =
        spi_master_send_recv(spi_master_hw_instance, p_tx_data, len, p_rx_data, len);
/**@brief Function for executing and switching state.
static void switch_state(void)
    switch (m_spi_master_ex_state)
        case TEST_STATE_SPI0_MSB:
            spi_master_init(SPI_MASTER_0, spi_master_0_event_handler, false);
            spi_send_recv(SPI_MASTER_0, m_tx_data_spi, m_rx_data_spi, TX_RX_MSG_LENGTH);
    nrf_delay_ms(DELAY_MS);
#endif /* defined(SPI_MASTER_0_ENABLE) || defined(SPI_MASTER_1_ENABLE) */
/**@brief Function for initializing bsp module.
void bsp_configuration()
    NRF_CLOCK->LFCLKSRC            = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos);
    NRF_CLOCK->TASKS_LFCLKSTART    = 1;
    while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
        // Do nothing.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS, APP_TIMER_OP_QUEUE_SIZE, NULL);
    err_code = bsp_init(BSP_INIT_LED, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), NULL);
/** @brief Function for main application entry.
    // Setup bsp module.
    bsp_configuration();
//	  uint8_t OUT_X_L_addr = 0x28;       // The address of the register you want to write
    uint8_t tx_data[2] = {0x00, 0x00}; // Transmit register
    uint8_t rx_data[6] = {0x00}; // Receive register
    uint8_t Data_Format[2]={0x00,0x01};   // +-4g Range setting for ADXL. The register and the value
     uint8_t  Powermode_Set [2]= { 0x2D, 0x08 };
     spi_master_send_recv(SPI_MASTER_0, Data_Format, 2, tx_data, 2); // Setting ADXL345 Mode
     spi_master_send_recv(SPI_MASTER_0, Powermode_Set, 2, tx_data, 6); // Setting Power Mode
    for (;; )
			init_buf(tx_data,rx_data,2);
		//	init_buf2(&Start_Register_Address,rx_data,6);
      spi_master_send_recv(SPI_MASTER_0,  Data_Format,2 , rx_data,6 );
