Hi, I'm using nRF9160 as host and nRF52833 as a controller with NCS 1.5.0 SDK. On nRF52833 LPUART sample runs, I have added needed configurations for extended advertising there. On nRF9160 periodic_adv sample runs however system resets after waiting semaphore for HCI_CMD_TIMEOUT seconds in bt_hci_cmd_send_sync. (bt_le_ext_adv_start -> bt_le_ext_adv_set_data -> le_adv_update -> bt_hci_cmd_send_sync). Here is what get in the terminal:
*** Booting Zephyr OS build v2.4.99-ncs1 *** Starting Periodic Advertising Demo [00:00:02.259,429] <wrn> bt_hci_core: opcode 0x0000 pool id 2 pool 0x200103fc != &hci_cmd_pool 0x200103d4 [00:00:02.289,672] <inf> bt_hci_core: Identity: F7:90:8F:C8:9C:F6 (random) [00:00:02.289,672] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0000, manufacturer 0x05f1 [00:00:02.289,672] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0xffff ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:333 k_sem_take failed with err -11 [00:00:12.293,212] <err> os: r0/a1: 0x00000003 r1/a2: 0x20014118 r2/a3: 0x200104e8 [00:00:12.293,212] <err> os: r3/a4: 0x00000002 r12/ip: 0x0a31312d r14/lr: 0x0000fc39 [00:00:12.293,243] <err> os: xpsr: 0x41000000 [00:00:12.293,243] <err> os: Faulting instruction address (r15/pc): 0x0000fc44 [00:00:12.293,243] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0 [00:00:12.293,243] <err> os: Current thread: 0x20010428 (unknown) [00:00:12.576,446] <err> fatal_error: Resetting system
With the same Host - Controller configuration I tried to run ibeacon sample which uses legacy advertising and it ran without errors. Also periodic_sync example runs as expected too, only problem is in extended advertising. What steps should be followed for this problem?
