Extended advertising fails with zephyr Host - Controller configuration
Hi, I'm using nRF9160 as host and nRF52833 as a controller with NCS 1.5.0 SDK. On nRF52833 LPUART sample runs, I have added needed configurations for extended advertising there. On nRF9160 periodic_adv sample runs however system resets after waiting semaphore for HCI_CMD_TIMEOUT seconds in bt_hci_cmd_send_sync. (bt_le_ext_adv_start -> bt_le_ext_adv_set_data -> le_adv_update -> bt_hci_cmd_send_sync). Here is what get in the terminal:
 *** Booting Zephyr OS build v2.4.99-ncs1  ***
 Starting Periodic Advertising Demo
 [00:00:02.259,429] <wrn> bt_hci_core: opcode 0x0000 pool id 2 pool 0x200103fc != &hci_cmd_pool 0x200103d4
 [00:00:02.289,672] <inf> bt_hci_core: Identity: F7:90:8F:C8:9C:F6 (random)
 [00:00:02.289,672] <inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0000, manufacturer 0x05f1
 [00:00:02.289,672] <inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0xffff
 ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:333
   k_sem_take failed with err -11
 [00:00:12.293,212] <err> os: r0/a1:  0x00000003  r1/a2:  0x20014118  r2/a3:  0x200104e8
 [00:00:12.293,212] <err> os: r3/a4:  0x00000002 r12/ip:  0x0a31312d r14/lr:  0x0000fc39
 [00:00:12.293,243] <err> os:  xpsr:  0x41000000
 [00:00:12.293,243] <err> os: Faulting instruction address (r15/pc): 0x0000fc44
 [00:00:12.293,243] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
 [00:00:12.293,243] <err> os: Current thread: 0x20010428 (unknown)
 [00:00:12.576,446] <err> fatal_error: Resetting system
With the same Host - Controller configuration I tried to run ibeacon sample which uses legacy advertising and it ran without errors. Also periodic_sync example runs as expected too, only problem is in extended advertising. What steps should be followed for this problem?
  • Hi Simon,
    I am using 1.5.0 SDK and can confirm these PRs are already applied.
    Safa
  • I guess this is related to https://devzone.nordicsemi.com/f/nordic-q-a/72923/nrf-connect-mobile-app-doesn-t-show-advertising-nrfxlib. Are you able to use extended advertising with the Zephyr BLE controller?
    Some developers are currently looking into this, and I'll keep you updated.
    Simon
  • I think to run periodic advertising sample, using Zephyr controller is necessary so all aforementioned problems occurred while CONFIG_BT_LL_SW_SPLIT=y
    Safa
  • Sorry for the delay on this. I will look into it on Friday/Monday.
    Simon
  • Update 29/04/2021: Added strikethrough over false statement
    Have you made any progress on this lately?
    It seems like this is related to the 52833 specifically.
    In zephyr\samples\bluetooth\periodic_adv\prj.conf (NCS v1.5.0) I added CONFIG_BT_LL_SW_SPLIT=y, then I built and flashed the example for respectively the nrf52833dk_nrf52833 and the nrf52840dk_nrf52840 (host and controller on the same chip).
    For the nrf52840dk_nrf52840 I got the following output:
    [00]*** Booting Zephyr OS build v2.4.99-ncs1  ***
    [00:00:00.601,562] [1B][0m<inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)[1B][0m
    [00:00:00.601,562] [1B][0m<inf> bt_hci_core: HW Variant: nRF52x (0x0002)[1B][0m
    [00:00:00.601,562] [1B][0m<inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 2.4 Build 99[1B][0m
    [00:00:00.602,142] [1B][0m<inf> bt_hci_core: Identity: CB:89:22:18:D8:D0 (random)[1B][0m
    [00:00:00.602,142] [1B][0m<inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0000, manufacturer 0x05f1[1B][0m
    [00:00:00.602,142] [1B][0m<inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0xffff[1B][0m
    Set Periodic Advertising Data...done.
    For the nrf52833dk_nrf52833 I got this output:
    Failed to create advertising set (err -5)
    [00:00:00.258,361] [1B][0m<inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)[1B][0m
    [00:00:00.258,361] [1B][0m<inf> bt_hci_core: HW Variant: nRF52x (0x0002)[1B][0m
    [00:00:00.258,361] [1B][0m<inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 2.4 Build 99[1B][0m
    [00:00:00.258,911] [1B][0m<inf> bt_hci_core: Identity: E1:73:76:DD:47:2A (random)[1B][0m
    [00:00:00.258,941] [1B][0m<inf> bt_hci_core: HCI: version 5.2 (0x0b) revision 0x0000, manufacturer 0x05f1[1B][0m
    [00:00:00.258,941] [1B][0m<inf> bt_hci_core: LMP: version 5.2 (0x0b) subver 0xffff[1B][0m
    [00:00:00.259,033] [1B][1;33m<wrn> bt_hci_core: opcode 0x2036 status 0x01[1B][0m
    Have you tested using an nrf52840dk as the controller? Does it work then.
    I will due some more investigations and get back to you with clearer answers.
    Simon
  • Forget the last reply. The reason it didn't work for the nrf52833 was because there were no nrf52833.conf file in the folder zephyr/samples/bluetooth/periodic_adv/boards.
    I was trying to set everything up to reproduce your problem, and thought I would start with the ibeacon sample, to make sure I got it right. However, I encountered some problems (I've don't have too much experience with BLE host controller on separate chips). Would you be able to upload the ibeacon sample as well as the periodic_adv sample you used on the nRF9160 DK, and the lpuart sample (if modified) you used on the nRF52833 DK?
