nrf9160-dk getting value from switches
This compiles with warnings and the value always comes back as 0
#define SW1_NODE DT_ALIAS(sw1)
#if DT_NODE_HAS_STATUS(SW1_NODE, okay)
#define SW1 DT_GPIO_LABEL(SW1_NODE, gpios)
#define SW1_PIN DT_GPIO_PIN(SW1_NODE, gpios)
#define SW1_FLAGS DT_GPIO_FLAGS(SW1_NODE, gpios)
#else
#error "Unsupported board: sw1 devicetree alias is not defined"
const struct device *sw1 = device_get_binding(SW1);
if (sw1 != NULL) {
  printk("Found device \"%s\"\n", SW1);
} else {
  printk("No \"%s\" found; is it connected?\n", SW1);
gpio_pin_configure(sw1, GPIO_INPUT, GPIO_PULL_DOWN);
while (1) {
  int sw1_val = gpio_pin_get(sw1,SW1_PIN);
  printk("Switch: %d\n", sw1_val);
  k_msleep(1000);
The warnings are:
warning: conversion from 'unsigned int' to 'gpio_pin_t' {aka 'unsigned char'} changes value from '256' to '0' [-Woverflow]
43 | #define GPIO_INPUT              (1U << 8)
../src/main.c:749:26: note: in expansion of macro 'GPIO_INPUT'
  749 |  gpio_pin_configure(sw1, GPIO_INPUT, GPIO_PULL_DOWN);
I checked that GPIO_INPUT is correct for gpio_pin_configure in zephyr docs.
Presumably the nrfConnect SDK is the same in this regard?
    Can you please elaborate on what you are trying to achieve? What version of NCS are you working on?
    What pin number are you trying to configure?
    //This is you function call
    //From what I can see, you should change it to the following:
    gpio_pin_configure(sw1, SW1_PIN, GPIO_PULL_DOWN);
    Looking at how gpio_pin_configure() is configured in e.g. http_update sample:
    #define SW1_PIN (DT_GPIO_PIN(DT_ALIAS(sw1), gpios))
    #define SW1_FLAGS (DT_GPIO_FLAGS(DT_ALIAS(sw1), gpios))
    static int button_init(void)
    	int err;
    	gpiob = device_get_binding(DT_GPIO_LABEL(DT_ALIAS(sw1), gpios));
    	if (gpiob == 0) {
    		printk("Nordic nRF GPIO driver was not found!\n");
    		return 1;
    	err = gpio_pin_configure(gpiob, SW1_PIN, GPIO_INPUT | SW1_FLAGS);
    	if (err == 0) {
    		gpio_init_callback(&gpio_cb, fmfu_button_pressed, BIT(SW1_PIN));
    		err = gpio_add_callback(gpiob, &gpio_cb);
    	if (err == 0) {
    		fmfu_button_irq_enable();
    	if (err != 0) {
    		printk("Unable to configure SW1 GPIO pin!\n");
    		return 1;
    	return 0;
    From zephyr\include\drivers\gpio.h
     * @brief Configure a single pin.
     * @param port Pointer to device structure for the driver instance.
     * @param pin Pin number to configure.
     * @param flags Flags for pin configuration: 'GPIO input/output configuration
     *        flags', 'GPIO drive strength flags', 'GPIO pin drive flags', 'GPIO pin
     *        bias flags', GPIO_INT_DEBOUNCE.
     * @retval 0 If successful.
     * @retval -ENOTSUP if any of the configuration options is not supported
     *                  (unless otherwise directed by flag documentation).
     * @retval -EINVAL Invalid argument.
     * @retval -EIO I/O error when accessing an external GPIO chip.
     * @retval -EWOULDBLOCK if operation would block.
    static inline int gpio_pin_configure(const struct device *port,
    				     gpio_pin_t pin,
    				     gpio_flags_t flags)
    Please provide full build output.
    Øyvind
  • Hi @Øyvind
    On the 9160dk the default for Switch 1 is pin 8 with alias sw1.
    I'm using ncs 2.4.  It seems it doesn't include an http_update sample.  (I could not find any example of polling a switch.)
    I just want to be able to poll the switch to get its value.
    The build output is:
    Including boilerplate (Zephyr base): /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/cmake/app/boilerplate.cmake -- Application: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp -- Zephyr version: 2.4.0 (/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr) -- Found Python3: /usr/local/bin/python3.7 (found suitable exact version "3.7.7") found components: Interpreter -- Found west (found suitable version "0.7.2", minimum required is "0.7.1") -- Board: nrf9160dk_nrf9160ns -- Cache files will be written to: /Users/paul_tanner/Library/Caches/zephyr -- Found dtc: /usr/local/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6") -- Found toolchain: gnuarmemb (/Applications/ARM) -- Found BOARD.dts: /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts -- Found devicetree overlay: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/boards/nrf9160dk_nrf9160ns.overlay nrf9160dk_nrf9160ns.dts.pre.tmp:357.32-361.5: Warning (simple_bus_reg): /soc/cryptocell-sw: missing or empty reg/ranges property nrf9160dk_nrf9160ns.dts.pre.tmp:601.12-606.4: Warning (spi_bus_reg): /soc/peripheral@40000000/spi@b000/bme280@13: SPI bus unit address format error, expected "0" nrf9160dk_nrf9160ns.dts.pre.tmp:56.42-68.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000) nrf9160dk_nrf9160ns.dts.pre.tmp:305.19-311.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000) warning: unit address and first address in 'reg' (0x0) don't match for /soc/peripheral@40000000/spi@b000/bme280@13 -- Generated zephyr.dts: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build/zephyr/include/generated/devicetree_unfixed.h Parsing /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/Kconfig Loaded configuration '/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig' Merged configuration '/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/prj.conf' Configuration saved to '/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build/zephyr/.config' Kconfig header saved to '/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 9.3.1 -- The CXX compiler identification is GNU 9.3.1 -- The ASM compiler identification is GNU -- Found assembler: /Applications/ARM/bin/arm-none-eabi-gcc Changed board to secure nrf9160dk_nrf9160 (NOT NS) === child image spm - begin === Including boilerplate (Zephyr base): /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/cmake/app/boilerplate.cmake -- Application: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/spm -- Zephyr version: 2.4.0 (/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr) -- Found Python3: /usr/local/bin/python3.7 (found suitable exact version "3.7.7") found components: Interpreter -- Found west (found suitable version "0.7.2", minimum required is "0.7.1") -- Board: nrf9160dk_nrf9160 -- Cache files will be written to: /Users/paul_tanner/Library/Caches/zephyr -- Found dtc: /usr/local/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6") -- Found toolchain: gnuarmemb (/Applications/ARM) -- Found BOARD.dts: /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts -- Found devicetree overlay: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/spm/nrf9160dk_nrf9160.overlay nrf9160dk_nrf9160.dts.pre.tmp:56.42-68.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@50000000/kmu@39000) nrf9160dk_nrf9160.dts.pre.tmp:305.19-311.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@50000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@50000000/power@5000) -- Generated zephyr.dts: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build/spm/zephyr/zephyr.dts -- Generated devicetree_unfixed.h: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build/spm/zephyr/include/generated/devicetree_unfixed.h Parsing /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/Kconfig Loaded configuration '/Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig' Merged configuration '/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/spm.conf' Merged configuration '/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build/spm/zephyr/misc/generated/extra_kconfig_options.conf' Configuration saved to '/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build/spm/zephyr/.config' Kconfig header saved to '/Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build/spm/zephyr/include/generated/autoconf.h' -- The C compiler identification is GNU 9.3.1 -- The CXX compiler identification is GNU 9.3.1 -- The ASM compiler identification is GNU -- Found assembler: /Applications/ARM/bin/arm-none-eabi-gcc -- Configuring done -- Generating done -- Build files have been written to: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build/spm === child image spm - end === CMake Warning at /Users/paul_tanner/Nordic/nrfsrc/ncs/zephyr/CMakeLists.txt:1331 (message): __ASSERT() statements are globally ENABLED -- Configuring done -- Generating done -- Build files have been written to: /Users/paul_tanner/Nordic/nrfsrc/ncs/nrf/samples/nrf9160/gps_udp/build -- west build: building application [1/266] Preparing syscall dependency handling [8/266] Performing build step for 'spm_subimage' [1/197] Preparing syscall dependency handling [192/197] Linking C executable zephyr/zephyr_prebuilt.elf Memory region Used Size Region Size %age Used FLASH: 32 KB 48 KB 66.67% SRAM: 5600 B 64 KB 8.54% IDT_LIST: 56 B 2 KB 2.73% [197/197] Linking C executable zephyr/zephyr.elf [260/266] Linking C executable zephyr/zephyr_prebuilt.elf Memory region Used Size Region Size %age Used FLASH: 149600 B 976 KB 14.97% SRAM: 37752 B 128 KB 28.80% IDT_LIST: 168 B 2 KB 8.20% [266/266] Generating zephyr/merged.hex
    You have Zephyr OS v2.4, assuming you are using NCS v1.4.x.
    Have you configured correct PIN as per my last comment? From gpio.h
     * @brief Get logical level of an input pin.
     * Get logical level of an input pin taking into account GPIO_ACTIVE_LOW flag.
     * If pin is configured as Active High, a low physical level will be interpreted
     * as logical value 0. If pin is configured as Active Low, a low physical level
     * will be interpreted as logical value 1.
     * Note: If pin is configured as Active High, the default, gpio_pin_get()
     *       function is equivalent to gpio_pin_get_raw().
     * @param port Pointer to the device structure for the driver instance.
     * @param pin Pin number.
     * @retval 1 If pin logical value is 1 / active.
     * @retval 0 If pin logical value is 0 / inactive.
    static inline int gpio_pin_get(const struct device *port, gpio_pin_t pin)
  • Sorry, I had not changed the configure line and that explains the error message.
    That fixed, I have a clean build but the program was not seeing switch 1.
    I tracked this down to  sw1 = &button3; in the <BOARD>_common.dts
    This translates to pin 7 which is wired to push button 2 on the DK board.
    So I changed the program to #define SW1_NODE DT_ALIAS(sw2)
    Which now picks up Switch 1.  I did not change the .dts file for the board in case it broke other stuff.
    So we can close this now.  Thx.
