How to set the date and time to the file on SD card or Flash disk on nRF52840
Hi
I'm trying to file open and write for logging temperature data and others on nRF52840.
I successfully open, read and write on SD card or flash in nRF52840.
I also have used  nrf_cal_set_time(year, month-1, day, hour, minute, second) in nrf_calendar.c successfully.
It's a great and file to display date and time.
But, after file creation using f_open(), f_write() and f_close(), I found that the default date&time of the file is always 01/01/2016.
I appreciate that if you let us know what is wrong from my side and how to change or set the date & time of file property.
Thanks
Minsoo Jang
  • Hi
    Seems like the time is called from somewhere else in your application, please try finding out where the time is called from, as it doesn't look like GET_FATTIME is able to provide the time of day.
    Simon
  • Hi Simonr
    I don't think you understand my situation fully. Sorry for my poor explanation. So, let me explain my program structure one by one.
    In brief, I open file and write it to flash memory area on nRF52840 DK
         1. ff_result = f_open(&file, TEMPERATURE_FILE, FA_CREATE_ALWAYS | FA_WRITE);
         2.ff_result = f_write(&file, temper_info, strlen(temper_info), (UINT *) &bytes_written);
         3. file's date is always 01/01/2016
         4. I found that const variable in ffconf.h. see ffconf.h
                                #define _FS_NORTC 1
                                #define _NORTC_MON 1
                                #define _NORTC_MDAY 1
                                #define _NORTC_YEAR 2016
         5. I found that "Timestamp" part in ff.c. See Timestamp in ff.c
                              /* Timestamp */
                             #if _FS_NORTC == 1
                             #define GET_FATTIME() ((DWORD)(_NORTC_YEAR - 1980) << 25 | (DWORD)_NORTC_MON << 21 |                                          (DWORD)_NORTC_MDAY << 16)
                            // #define GET_FATTIME() get_fattime() //Modified 210329
                            #else
         6. this has to do with f_open() in ff.c like follwoing. see dw=GET_FATTIME() of f_open() in ff.c
                           FRESULT f_open (
                                 FIL* fp, /* Pointer to the blank file object */
                                const TCHAR* path, /* Pointer to the file name */
                                 BYTE mode /* Access mode and file open mode flags */
                                  FRESULT res;
                            if (res == FR_OK && (mode & FA_CREATE_ALWAYS)) { /* Truncate it if overwrite mode */
                            dw = GET_FATTIME();
         7. It's certain that we have to change  "GET_FATTIME()" in ff.c to set the date and time of opened file
         8. That's reason why I change GET_FATTIME() in ff.c.
                                      f_open() => GET_FATTIME => "#define  #define _NORTC_MON 1 #define _NORTC_MDAY 1        #define _NORTC_YEAR 2016"
         9. When I changed GET_FATTIME() in ff.c to
                                           #define _NORTC_MON 3
                                           # define _NORTC_MDAY 30
                                           #define _NORTC_YEAR 2021
              it works well and successfully. But, the time of the file which is opened and written is always AM 12:00 like
                                            TEMPERATURE_FILE       2021-03-30 AM 12:00 17KB
         10. In conclusion, let me know the way to change the time of file from following '#define'
                in ff.c because there is no TIME related bit command(there are only YEAR, MON, DAY part).
          11. If you can let me know new #define command to set the time of GET_FATTIME(),  I will take care of others
    Thanks
    Michael Jang
  • Okay. I think I see now. In our SDK we don't use timestamps in the Fatfs library, and AFAIK we haven't done any testing with these timestamps either. This is an external library, and I have not been able to find where the time of day is set when _FS_NORTC is set to 1, so I'm afraid what help I can provide is rather limited...
    From ff.h: If the system does not have an RTC function or a valid timestamp is not needed, _FS_NORTC = 1 is set to disable the timestamp function (so you won't be able to get the current time like this). If _FS_NORTC = 1 all objects will have a fixed timestamp defined by the _NORTC_MON, _NORTC_MDAY and _NORTC_YEAR. To enable timestamp functionalities, the get_fattime() function needs to be added to the project and you'll have to get the current time from a real-time clock.
    Simon
  • Hi Simonr
    I got the solution by changing GET_FATTIME()  like following.
    Thanks.
     #define GET_FATTIME()   ((DWORD)(year - 1980) << 25 | (DWORD)month << 21 | day << 16 | hour << 11 | minute << 5)
