How to set the date and time to the file on SD card or Flash disk on nRF52840
Hi
I'm trying to file open and write for logging temperature data and others on nRF52840.
I successfully open, read and write on SD card or flash in nRF52840.
I also have used  nrf_cal_set_time(year, month-1, day, hour, minute, second) in nrf_calendar.c successfully.
It's a great and file to display date and time.
But, after file creation using f_open(), f_write() and f_close(), I found that the default date&time of the file is always 01/01/2016.
I appreciate that if you let us know what is wrong from my side and how to change or set the date & time of file property.
Thanks
Minsoo Jang
  • Hi
    I assume you have used the nrf5-calendar-example as reference for the nrf_cal_set_time() function? The nRF52840 will need to get the date/time from somewhere, and if you don't provide it, it seems like it falls back to the default 01/01/2016. In the default example, the application will wait for you to set the time over UART by entering the year, month, day, hour, minute and second in a terminal.
    Can you also provide some information on what SDK version you're using?
    Simon
  • Hi
    Thank you very much for your reply and sorry for my late response.
    I'm developing program on SDK 12.0.2 and already has been used nrf5-calendar-example.
    As I said, nrf_cal_set_time(year, month, day, hour, minute, second) and print_current_time() are no problem when it runs on program. My programs run and display like following successfully:
    NPC5,190,03/26/21 - 19:37:18,25.91 C ,59.62 %,1002,4.4V
    NPC5,191,03/26/21 - 19:37:19,25.88 C ,58.39 %,1019,4.4V
    However, although I created new file(temper.csv) and write on the that file after nrf_cal_set_time and nrf_cal_get_time usage on program, the file's date is always  01/01/2016 when I see that file via USB port like following:
    TEMPER.CSV 2016-01-01 AM 12:00 17KB
    I'm sure you must have simple solution for this matter.
    Thanks in advance
    Michael Jang
  • Hi
    It seems like you're calling the default time from the time.h library when you write to this file. Can you try setting a breakpoint at the point in time.h where the date 2016.01.01 is set to see where exactly it's called?
    Simon
  • Hi
    Thank you very much for your reply.
    I found Timestamp that there is function to set the date in ff.c like:
    ff.c
    /* Timestamp */
    #if _FS_NORTC == 1
    #if _NORTC_YEAR < 1980 || _NORTC_YEAR > 2107 || _NORTC_MON < 1 || _NORTC_MON > 12 || _NORTC_MDAY < 1 || _NORTC_MDAY > 31
    #error Invalid _FS_NORTC settings
    #define GET_FATTIME() ((DWORD)(_NORTC_YEAR - 1980) << 25 | (DWORD)_NORTC_MON << 21 | (DWORD)_NORTC_MDAY << 16)
    #else
    #define GET_FATTIME() get_fattime()
    ffconf.h
    #define _FS_NORTC 1
    #define _NORTC_MON 1
    #define _NORTC_MDAY 1
    #define _NORTC_YEAR 2016
    So, I changed and made new get_fattime() in main.c  like following:
    main.c
    DWORD get_fattime(void)
    DWORD date_value;
    DWORD year;
    DWORD month;
    DWORD day;
    year = (DWORD)mRTC_Timer.tm_year;
    month = (DWORD)mRTC_Timer.tm_mon;
    day = (DWORD)mRTC_Timer.tm_mday;
    if (year < 1980 || year > 2107 || month < 1 || month > 12 || day < 1 || day > 31 )
          month = 1;
          day = 1;
          year = 2021;
          printf("Time data is broken, set to default value!!!\r\n");
    date_value = ((DWORD)(year - 1980) << 25 | (DWORD)month << 21 | day << 16);
    return date_value;
    It's working successfully by updating to new RTC date for opened file whenever it opens  and write file using f_open() and f_write().
    But, the time of modified file is always 12:00 AM like following:
    temper.csv 2021-03-29 AM 12:00
    I appreciate if you let me know how to set time value other than date for Timestamp:
    I'm sure we could use and add time value for this function
    Thanks in advance
    Michael Jang
