nrf_serial_write don't work in blocking mode
Hi!
I'm working on the NRF52832. I'm using the function "nrf_serial_write()" to send data over uart. I want it to work in blocking mode. As I can read in the infocenter, if I put a time into the "timeout_ms" parameter, the function should work in blocking mode. But the function seems to work in nonblocking mode because without the delay of 50 ms, the "nrf_serial_uninit()" function stops the data transmission. There is my code:
              //Uart speed is 9600 bps
              //BUF_LEN = 26
              nrf_serial_write(&serial_uart, &buf, BUF_LEN, NULL, 1000); // Send byte over OW
              nrf_delay_ms(50);
              nrf_serial_uninit(&serial_uart);
*I send 26 bytes at 9600 bps. A timeout of 1000 ms should be enough.
I expect the problem is with the timer initialization of the uart timer. There is my code:
    ret_code_t ret;
    ret = nrf_drv_clock_init();
    APP_ERROR_CHECK(ret);
    ret = app_timer_init();
What am I missing?
Thank you!
