Replace HAL function (+SPI)
Hello
I am currently porting nRF52833 using SPI communication with other MCU (AD5940).
AD5940 provides an example of porting with stm32, which we are referring to.
Currently, no function is found to replace the Clock Enable used by stm32.
Can I get some help? Related photos are as follows.
----------------------------The code in the example.
 I'm sorry I brought you a question about another MCU..!
Best regards.
  • Is there a code that plays this role in nrf
    Again, the STM32 is an entirely different product from an entirely different manufacturer - so its internal details are entirely different.
    What you need to be looking for are functions that will send & receive stuff over SPI without any concern for the underlying hardware; eg,
     * Platform-independent function to perform an SPI transfer
     * Parameters:
     *   p_tx_buffer - buffer of data to be transmitted;
     *   p_rx_buffer - buffer to receive incoming data;
     *   length      - length of the buffers
     * Returns:
     *   status code indicating success/failure
    status_t spi_transfer( uint8_t *p_tx_buffer, uint8_t *p_rx_buffer, uint8_t length );
    As you can see, that is entirely independent of any of the underlying hardware implementation details.
    You would have a separate implementation for STM32, which does all the STM32-specific stuff, and a separate implantation for nRF, which does all nRF-specific stuff.
    But the code which calls this function remains entirely unaware and independent of the underlying implementation details.
    This is standard software engineering stuff.
    If the code you've got doesn't provide such an isolation of the "General" code from the platform-specific code, then your first step would be to implement such a layer.
    For using nRF's SPI, see the SDK documentation.
    I do not have any experience with STM32, but if it relates to peripheral clock, you do not need to start this explicitly in nRF52. The UART(E) peripheral will automatically request the 16 MHz HFCLK if/when it is needed by the peripheral. It is possible to start the external HF crystal clock to increase the accuracy of the UART(E) communication. This can be done using the clock driver or by accessing the registers directly:
    void clock_driver_init()
        ret_code_tret = nrf_drv_clock_init();
        APP_ERROR_CHECK(ret);
        nrf_drv_clock_hfclk_request(NULL);
        while (!nrf_drv_clock_hfclk_is_running());
    void clock_reg_init()
        while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
    If you are running a softdevice, you need to use the softdevice API (sd_clock_hfclk_request()) to request the HFCLK.
    Jørgen
