Loading network core image via Segger Embedded Studio
I'm attempting to download the network core image using the procedure described in "Programming the network sample from SES".     My app prj.conf file includes the following statements:
# Bluetooth configuration
# For nRF5340
CONFIG_BOARD_ENABLE_CPUNET=y
CONFIG_BT_RPMSG_NRF53=y
CONFIG_NRF_802154_SER_HOST=n
My assumption is that loading the "Bluetooth: HCI RPMsg" sample into the network core will provide the BLE "soft device" equivalent for the nRF5340 (network core side).
Step 8 of this sequence produces the following log in the target output window of SES:
Preparing target for download
Executing Reset script TargetInterface.resetAndStop()
Reset: Halt core after reset via DEMCR.VC_CORERESET.
Reset: Reset device via AIRCR.SYSRESETREQ.
Downloading ‘merged.hex’ to J-Link
Programming 126.5 KB of addresses 00000000 — 0001fa4f
J-Link: Flash download: Bank 1 @ 0x00000000: Skipped. Contents already match
Download successful
Connecting ‘J-Link’ using ‘USB’
Connecting to target using SWD
Loaded E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/segger_embedded_studio/bin/JLink_x64.dll
Firmware Version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01
DLL Version: 6.94a
Hardware Version: V1.00
Target Voltage: 3.300
Device "NRF5340_XXAA_NET" selected.
ConfigTargetSettings() start
ConfigTargetSettings() end
InitTarget() start
InitTarget() end
Found SW-DP with ID 0x6BA02477
DPIDR: 0x6BA02477
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[1]: AHB-AP (IDR: Not set)
AP[2]: MEM-AP (IDR: Not set)
AP[3]: MEM-AP (IDR: Not set)
AP[1]: Core found
AP[1]: AHB-AP ROM base: 0xE00FE000
CPUID register: 0x410FD214. Implementer code: 0x41 (ARM)
Found Cortex-M33 r0p4, Little endian.
FPUnit: 8 code (BP) slots and 0 literal slots
Security extension: not implemented
CoreSight components:
ROMTbl[0] @ E00FE000
ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4C9 ROM Table
ROMTbl[1] @ E00FF000
ROMTbl[1][0]: E000E000, CID: B105900D, PID: 000BBD21 Cortex-M33
ROMTbl[1][1]: E0001000, CID: B105900D, PID: 000BBD21 DWT
ROMTbl[1][2]: E0002000, CID: B105900D, PID: 000BBD21 FPB
ROMTbl[1][6]: E0042000, CID: B105900D, PID: 000BBD21 CSS600-CTI
Loading target script file nRF_Target.js
Executing Reset script Reset();
ResetTarget() start
ResetTarget() end
Downloading ‘merged_CPUNET.hex’ to J-Link
Programming 189.1 KB of addresses 01000000 — 0102f47b
T-bit of XPSR is 0 but should be 1. Changed to 1.
Timeout while preparing target, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x00000000, LR = 0x41000003)!
Failed to prepare RAMCode using RAM
Download failed
Failed to download application.
Generic error.
Please check J-Link and target connection.
Illegal value 0x21009658 written to register 67 (PSP_NS) ignored
This appears to indicate that the download failed.   (Note that the J-Link interface works to download the app core image, so J-Link must be OK.    And earlier, I downloaded the .hex files for the HRM example (using the nRF Connect Programmer) to test the nRF5340-DK board. )
If I then make the "app" the active project and use Debug->Go to download the app image and start execution, the app appears to hang when the statement:
err = bt_enable(NULL);
is executed.  The screen capture shows:
Am I doing something wrong?
Thanks...
