Loading network core image via Segger Embedded Studio
I'm attempting to download the network core image using the procedure described in "Programming the network sample from SES".     My app prj.conf file includes the following statements:
# Bluetooth configuration
# For nRF5340
CONFIG_BOARD_ENABLE_CPUNET=y
CONFIG_BT_RPMSG_NRF53=y
CONFIG_NRF_802154_SER_HOST=n
My assumption is that loading the "Bluetooth: HCI RPMsg" sample into the network core will provide the BLE "soft device" equivalent for the nRF5340 (network core side).
Step 8 of this sequence produces the following log in the target output window of SES:
Preparing target for download
Executing Reset script TargetInterface.resetAndStop()
Reset: Halt core after reset via DEMCR.VC_CORERESET.
Reset: Reset device via AIRCR.SYSRESETREQ.
Downloading ‘merged.hex’ to J-Link
Programming 126.5 KB of addresses 00000000 — 0001fa4f
J-Link: Flash download: Bank 1 @ 0x00000000: Skipped. Contents already match
Download successful
Connecting ‘J-Link’ using ‘USB’
Connecting to target using SWD
Loaded E:/AdditionalWindowsTools/Nordic/nRF_Connect_SDK/v1.5.0/toolchain/segger_embedded_studio/bin/JLink_x64.dll
Firmware Version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01
DLL Version: 6.94a
Hardware Version: V1.00
Target Voltage: 3.300
Device "NRF5340_XXAA_NET" selected.
ConfigTargetSettings() start
ConfigTargetSettings() end
InitTarget() start
InitTarget() end
Found SW-DP with ID 0x6BA02477
DPIDR: 0x6BA02477
AP map detection skipped. Manually configured AP map found.
AP[0]: AHB-AP (IDR: Not set)
AP[1]: AHB-AP (IDR: Not set)
AP[2]: MEM-AP (IDR: Not set)
AP[3]: MEM-AP (IDR: Not set)
AP[1]: Core found
AP[1]: AHB-AP ROM base: 0xE00FE000
CPUID register: 0x410FD214. Implementer code: 0x41 (ARM)
Found Cortex-M33 r0p4, Little endian.
FPUnit: 8 code (BP) slots and 0 literal slots
Security extension: not implemented
CoreSight components:
ROMTbl[0] @ E00FE000
ROMTbl[0][0]: E00FF000, CID: B105100D, PID: 000BB4C9 ROM Table
ROMTbl[1] @ E00FF000
ROMTbl[1][0]: E000E000, CID: B105900D, PID: 000BBD21 Cortex-M33
ROMTbl[1][1]: E0001000, CID: B105900D, PID: 000BBD21 DWT
ROMTbl[1][2]: E0002000, CID: B105900D, PID: 000BBD21 FPB
ROMTbl[1][6]: E0042000, CID: B105900D, PID: 000BBD21 CSS600-CTI
Loading target script file nRF_Target.js
Executing Reset script Reset();
ResetTarget() start
ResetTarget() end
Downloading ‘merged_CPUNET.hex’ to J-Link
Programming 189.1 KB of addresses 01000000 — 0102f47b
T-bit of XPSR is 0 but should be 1. Changed to 1.
Timeout while preparing target, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x00000000, LR = 0x41000003)!
Failed to prepare RAMCode using RAM
Download failed
Failed to download application.
Generic error.
Please check J-Link and target connection.
Illegal value 0x21009658 written to register 67 (PSP_NS) ignored
This appears to indicate that the download failed.   (Note that the J-Link interface works to download the app core image, so J-Link must be OK.    And earlier, I downloaded the .hex files for the HRM example (using the nRF Connect Programmer) to test the nRF5340-DK board. )
If I then make the "app" the active project and use Debug->Go to download the app image and start execution, the app appears to hang when the statement:
err = bt_enable(NULL);
is executed.  The screen capture shows:
Am I doing something wrong?
Thanks...
  • Hi!
    Just to confirm that I'm understanding you correctly: you are trying to flash the hci_rpmsg sample to the network core, or have you written your own application for the network core? Anyway, your assumption is more or less correct!
    Based on the behavior of your application core code it seems like the network core is not correctly programmed. Have you made sure to follow the instructions in the "Programming the network sample from SES" documentation thoroughly? I suggest trying with one of the official BLE samples, like peripheral_lbs, before writing your own. Then we can make sure that there aren't any issues with the application.
    Carl Richard
  • Yes, I followed the steps of "Programming the network sample from SES".   I have an application that I'm porting from nRF52840/FreeRTOS/nRF5 SDK to nRF5340/Zephyr/NCS.    I added an additional step of first transitioning to nRF52840/Zephyr/NCS and got that part to partially work (still a few things to deal with), but while working on those issues am trying to target nRF5340-DK with the portion of code that is working.   I have a couple of other DevZone issues pending in this step, but can at least get the application image loaded into nRF5340 and can step through the initial part of the code.   From the documentation, I got the impression that using the network image from hci_rpmsg (following the steps of "Programming the network sample from SES" would program the necessary BLE stack into the network core.  But the error shown in the screen capture popped up.    I'm also assuming that the BLE configuration (in prj.conf) and BLE calls used for the nRF52840 version (in the app) should work for the nRF5340 (as all underlying differences are hidden by the driver).
    Thanks for your assistance!
  • Hi!
    Thanks for the additional information. Your assumptions are correct, so there may be some other issue at hand here. Could you try to run the following commands on the command line and then try to download hci_rpmsg to the network core again?
    nrfjprog --recover --coprocessor CP_NETWORK
    nrfjprog --recover
    This will disable the readback protection of the device. You can find more information about this in the Working with nRF53 series documentation.
    Carl Richard
  • Hi Carl,
    Thanks!   I think that may have been it, although it didn't proceed quite as I expected.   However, I can now communicate with the board via BLE!   Here is some additional info:
    Running nrfprog:
    PS C:\Users\hepler> nrfjprog --recover --coprocessor CP_NETWORK
    Recovering device. This operation might take 30s.
    ERROR: Recover failed. Please make sure that the correct device family is given
    ERROR: and try again.
    Failed to enable coprocessor with unknown error.
    ERROR: JLinkARM DLL reported an error. Try again. If error condition
    ERROR: persists, run the same command again with argument --log, contact Nordic
    ERROR: Semiconductor and provide the generated log.log file to them.
    PS C:\Users\hepler> nrfjprog --recover --coprocessor CP_NETWORK --log
    PS C:\Users\hepler>
    As you can see, it reported that error(s) were produced.    So here is the log file  (for some reason the web interface wouldn't let me enter it as "text code":
    2021-Mar-15 14:12:50 --------------------------------------------------------------------------------
    2021-Mar-15 14:12:50 C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.exe --recover --coprocessor CP_NETWORK --log
    2021-Mar-15 14:12:50 nrfjprog version 10.8.0
    2021-Mar-15 14:12:50 nRF_logger_open
    2021-Mar-15 14:12:50 nRF_logger_open: nRFJProg logger opened to callback at address 0X7FF6E5B83410
    2021-Mar-15 14:12:50 nRF_open_dll
    2021-Mar-15 14:12:50 nRF_open_dll: Load library at "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\JLINKARM_UNKNOWN_NRFJPROG.dll".
    2021-Mar-15 14:12:50 . nRFXX_logger_open
    2021-Mar-15 14:12:50 . nRFXX_logger_open: nRFJProg logger opened to callback at address 0X7FFBB252E520
    2021-Mar-15 14:12:50 . . Segger_logger_open
    2021-Mar-15 14:12:50 . . Segger_logger_open: nRFJProg logger opened to callback at address 0X7FFBB156D6D0
    2021-Mar-15 14:12:50 . . Segger_open_dll
    2021-Mar-15 14:12:50 . . Segger_open_dll: Load library at "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink_x64.dll".
    2021-Mar-15 14:12:50 . . . Segger_dll_version
    2021-Mar-15 14:12:50 . . Segger_set_core_data
    2021-Mar-15 14:12:50 nRF_enum_emu_snr
    2021-Mar-15 14:12:50 . nRFXX_enum_emu_snr
    2021-Mar-15 14:12:50 . . Segger_enum_emu_snr
    2021-Mar-15 14:12:50 . . . Segger_enum_emu_snr
    2021-Mar-15 14:12:50 . . . . Segger_get_num_emus
    2021-Mar-15 14:12:50 nRF_connect_to_emu_with_snr
    2021-Mar-15 14:12:50 . nRFXX_connect_to_emu_with_snr
    2021-Mar-15 14:12:50 . . Segger_connect_to_emu_with_snr
    2021-Mar-15 14:12:50 . . . Segger_is_connected_to_emu
    2021-Mar-15 14:12:50 . . . Segger_connect_to_emu_with_snr
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: Segger logging enabled with callback at 0x140718988778096.
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:023.176
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO Firmware: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:024.391
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO Decompressing FW timestamp took 182 us
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:043.145
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO Hardware: V1.00
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:043.743
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO S/N: 960146260
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:044.090
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO OEM: SEGGER
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:044.497
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:048.526
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO TELNET listener socket opened on port 19021
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:049.144
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO WEBSRV Starting webserver
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:049.691
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO WEBSRV Webserver running on local port 19080
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:050.005
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 32.140ms returns "O.K."
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:050.298
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:050.570
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO JLINK_GetHWStatus(...)
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:051.524
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 1.124ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:051.840
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:052.120
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:052.395
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.138ms returns 0x01
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:052.655
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:052.902
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO JLINK_ExecCommand("DisableFlashDL", ...).
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:053.155
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.126ms returns 0x00
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:053.401
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:053.655
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:053.908
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.124ms returns 0x00
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:054.152
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:054.397
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO JLINK_SetHookUnsecureDialog
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:054.724
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO JLINK_SetHookUnsecureDialog(...)
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:054.988
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.712ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:055.235
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:055.488
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO JLINK_TIF_Select(JLINKARM_TIF_SWD)
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:059.143
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 3.954ms returns 0x00
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:059.623
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:059.926
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO JLINK_SetSpeed(2000)
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:060.599
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.855ms
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:060.923
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:061.186
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO JLINK_GetSN()
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:061.431
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.369ms returns 960146260
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:061.710
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:062.372
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:062.688
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO - 0.137ms returns 0x00
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:062.950
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:063.198
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO JLINK_ExecCommand("device = Cortex-M4", ...).
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:071.544
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO XML file found at: C:\Program Files (x86)\SEGGER\JLink\JLinkDevices.xml
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:072.807
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO C:\Program Files (x86)\SEGGER\JLink\JLinkDevices.xml evaluated successfully.
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:116.422
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO Device "CORTEX-M4" selected.
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:118.988
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO - 55.733ms returns 0x00
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:119.318
    2021-Mar-15 14:12:50 nRF_read_connected_emu_snr
    2021-Mar-15 14:12:50 . nRFXX_read_connected_emu_snr
    2021-Mar-15 14:12:50 . . Segger_read_connected_emu_snr
    2021-Mar-15 14:12:50 . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:120.037
    2021-Mar-15 14:12:50 . . . Segger_is_connected_to_emu: JLink INFO JLINK_IsOpen()
    2021-Mar-15 14:12:50 . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:120.330
    2021-Mar-15 14:12:50 . . . Segger_is_connected_to_emu: JLink INFO - 0.418ms returns 0x01
    2021-Mar-15 14:12:50 . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:120.582
    2021-Mar-15 14:12:50 . . . Segger_is_connected_to_emu: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 nRF_read_device_family
    2021-Mar-15 14:12:50 . nRFXX_read_device_family
    2021-Mar-15 14:12:50 . . Segger_is_connected_to_emu
    2021-Mar-15 14:12:50 . . Segger_is_connected_to_emu: JLink INFO T41E4 000:121.201
    2021-Mar-15 14:12:50 . . Segger_is_connected_to_emu: JLink INFO JLINK_IsOpen()
    2021-Mar-15 14:12:50 . . Segger_is_connected_to_emu: JLink INFO T41E4 000:121.441
    2021-Mar-15 14:12:50 . . Segger_is_connected_to_emu: JLink INFO - 0.375ms returns 0x01
    2021-Mar-15 14:12:50 . . Segger_is_connected_to_emu: JLink INFO T41E4 000:121.703
    2021-Mar-15 14:12:50 . . Segger_is_connected_to_emu: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . : JLink INFO T41E4 000:121.946
    2021-Mar-15 14:12:50 . . : JLink INFO JLINK_Lock()
    2021-Mar-15 14:12:50 . . Segger_read_debug_port_idr
    2021-Mar-15 14:12:50 . . . Segger_read_debug_port_register
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure: JLink INFO T41E4 000:122.698
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure: JLink INFO JLINK_CORESIGHT_Configure()
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure: JLink INFO T41E4 000:123.803
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure: JLink INFO - 1.872ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure: JLink INFO T41E4 000:125.015
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:125.490
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:126.748
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO Value=0x6BA02477
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:127.177
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO - 1.822ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:127.451
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . Segger_read_access_port_idr
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register
    2021-Mar-15 14:12:50 . . . . . Segger_is_debug_region_powered
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:128.570
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:129.627
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO - 1.648ms returns 0
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:130.777
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:131.191
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:132.055
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO Value=0xF0000040
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:132.568
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO - 1.532ms returns 0
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:132.876
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:133.253
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x000000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:134.239
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.335ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:134.839
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:135.284
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:136.314
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO Value=0x84770001
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:136.943
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.895ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:137.408
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . Segger_read_access_port_register
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:138.027
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:138.976
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.274ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:139.561
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:140.101
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:141.289
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO Value=0x43000002
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:141.690
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.752ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:142.021
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:142.742
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:143.688
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.306ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:144.310
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:144.760
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:145.861
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:146.515
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 2.000ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:146.976
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:147.577
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:148.462
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.234ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:149.103
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:149.543
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:150.622
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:151.371
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 2.052ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:151.750
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:152.459
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x020000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:153.447
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.375ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:154.097
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:154.543
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:155.655
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO Value=0x12880000
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:156.263
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.954ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:156.744
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:157.844
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x02000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:158.902
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.470ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:159.481
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:159.875
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:160.834
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO Value=0x00000000
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:161.379
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.728ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:161.763
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:162.484
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x030000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:163.417
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.271ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:164.020
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:164.464
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:165.510
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:166.253
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 2.268ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:166.949
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:167.678
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x03000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:168.455
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.030ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:168.976
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:169.264
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:170.217
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:170.931
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.920ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:171.431
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:172.181
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x040000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:173.043
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.189ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:173.804
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:174.680
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:175.760
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO Value=0x00000000
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:176.198
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.651ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:176.466
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:177.098
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x04000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:177.901
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.131ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:178.395
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:178.678
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:179.505
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:179.848
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.302ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:180.116
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:181.156
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x050000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:182.109
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.399ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:182.923
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:183.428
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:184.280
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:185.696
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 2.492ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:186.126
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:187.119
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x05000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:188.245
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.362ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:188.648
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:188.931
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:189.801
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:190.357
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 2.240ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:191.423
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:193.043
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x060000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:193.923
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.092ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:194.291
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:194.565
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:195.393
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:195.774
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.346ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:196.051
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:196.729
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x06000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:197.488
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 0.954ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:197.830
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:198.093
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:199.029
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:199.437
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.474ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:199.714
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:200.443
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x070000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:201.286
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.065ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:201.664
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:201.965
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:202.740
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:203.057
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.226ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:203.328
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:204.011
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x07000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:204.922
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.202ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:205.460
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:205.780
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:206.737
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:207.737
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 2.138ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:208.056
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:208.897
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x080000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:209.862
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.302ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:210.466
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:211.104
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:212.071
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:212.690
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.786ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:213.036
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:213.640
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x08000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:214.547
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.254ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:215.148
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:215.638
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:216.541
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:217.142
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.743ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:217.609
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:218.356
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x090000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:219.262
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.598ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:220.513
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:220.850
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:221.843
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:222.438
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.884ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:223.004
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:223.775
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x09000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:224.885
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.450ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:225.549
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:225.882
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:226.669
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:226.972
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.221ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:227.237
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:227.987
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0A0000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:228.736
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 0.913ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:229.034
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:229.285
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:230.041
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:230.316
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.159ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:230.602
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:231.307
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0A000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:232.033
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 0.868ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:232.309
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:232.571
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:233.302
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:233.578
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.135ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:233.861
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:234.571
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0B0000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:235.490
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.131ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:235.844
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:236.107
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:236.915
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:237.193
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.218ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:237.461
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:238.182
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0B000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:238.905
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 0.867ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:239.183
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:239.443
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:240.230
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:241.260
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 2.230ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:241.975
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:243.991
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0C0000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:244.838
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.108ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:245.276
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:245.651
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:246.471
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:246.864
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.350ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:247.135
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:247.734
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0C000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:248.460
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 0.892ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:248.765
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:249.032
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:249.736
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:250.092
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.186ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:250.350
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:252.195
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0D0000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:253.474
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.683ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:254.037
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:254.305
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:255.120
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:255.537
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.371ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:255.815
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:256.426
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0D000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:257.167
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.181ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:257.816
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:258.238
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:259.170
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:259.542
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.435ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:259.804
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:260.808
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0E0000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:261.817
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.249ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:262.216
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:262.505
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:263.311
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:263.695
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.319ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:263.955
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:264.577
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0E000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:265.314
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.080ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:265.899
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:266.312
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:267.104
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:267.416
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.242ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:267.694
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:268.473
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0F0000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:269.398
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.279ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:270.052
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:270.498
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:271.343
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:271.674
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.312ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:271.948
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:272.591
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x0F000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:273.283
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:273.702
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:274.266
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:275.093
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:275.489
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.367ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:275.767
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:276.515
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x100000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:277.278
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 0.983ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:277.652
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:277.916
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:278.671
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:279.156
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.514ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:279.678
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:281.373
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x10000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:282.239
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.089ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:282.643
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:283.033
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:284.082
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:284.836
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.935ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:285.105
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:285.867
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x110000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:286.639
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 0.971ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:286.986
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:287.270
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:288.283
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:288.853
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.788ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:289.272
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:290.364
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x11000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:291.810
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 1.779ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:292.632
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:293.598
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:294.510
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:295.030
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.646ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:295.550
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:296.295
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x02000030)
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:297.043
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO - 0.933ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:297.377
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:297.686
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:298.502
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO Value=0x00000007
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:298.851
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 1.304ms returns 0
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:299.135
    2021-Mar-15 14:12:50 . . : JLink INFO T41E4 000:299.469
    2021-Mar-15 14:12:50 . . : JLink INFO - 0.462ms
    2021-Mar-15 14:12:50 . nRFXX_read_device_family: Discovered device from family NRF53.
    2021-Mar-15 14:12:50 nRF_close_dll
    2021-Mar-15 14:12:50 . nRFXX_close_dll
    2021-Mar-15 14:12:50 . . Segger_close
    2021-Mar-15 14:12:50 . . . Segger_disconnect_from_emu
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:300.445
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO JLINK_IsOpen()
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:300.752
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO - 0.432ms returns 0x01
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:301.004
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . Segger_disconnect_from_emu
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device: JLink INFO T41E4 000:301.525
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device: JLink INFO JLINK_IsConnected()
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device: JLink INFO T41E4 000:301.902
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device: JLink INFO - 0.622ms returns FALSE
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device: JLink INFO T41E4 000:302.373
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:303.095
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO JLINK_IsOpen()
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:303.347
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO - 0.374ms returns 0x01
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:303.593
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:303.889
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO JLINK_Lock()
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:304.270
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:304.998
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO - 1.030ms returns 0
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:305.460
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:305.729
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:306.534
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:306.830
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO - 2.370ms returns 0
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:308.492
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:308.907
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO - 0.612ms
    2021-Mar-15 14:12:50 . . . . . Segger_unpower_debug_and_system_regions
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:309.788
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:310.165
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO - 0.554ms returns 0x01
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:310.561
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:311.094
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_Lock()
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:311.614
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:313.072
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO - 1.768ms returns 0
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:313.553
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:313.908
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x00000000)
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:314.763
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO - 1.112ms returns 0
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:315.175
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:315.450
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO - 0.408ms
    2021-Mar-15 14:12:50 . . . . Segger_disconnect_from_emu: JLink INFO T41E4 000:323.727
    2021-Mar-15 14:12:50 . . . . Segger_disconnect_from_emu: JLink INFO JLINK_Close()
    2021-Mar-15 14:12:50 . . Segger_close: Freeing Library.
    2021-Mar-15 14:12:50 nRF_close_dll: Freeing Library.
    2021-Mar-15 14:12:50 nRF_open_dll: Load library at "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\JLINKARM_NRF53_NRFJPROG.dll".
    2021-Mar-15 14:12:50 . nRF53_logger_open
    2021-Mar-15 14:12:50 . nRF53_logger_open: nRFJProg logger opened to callback at address 0X7FFBB252E520
    2021-Mar-15 14:12:50 . nRF53_open
    2021-Mar-15 14:12:50 . . Segger_logger_open: nRFJProg logger opened to callback at address 0X7FFBB15566E0
    2021-Mar-15 14:12:50 . nRF53_connect_to_emu_with_snr
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: Segger logging enabled with callback at 0x140718988741776.
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:014.787
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:016.161
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO Decompressing FW timestamp took 263 us
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:034.748
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:035.497
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:036.024
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:036.535
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:040.482
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:041.206
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:041.941
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:042.389
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 33.127ms returns "O.K."
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:042.885
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:043.335
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:044.220
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 1.211ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:044.786
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:045.229
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:045.620
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.155ms returns 0x01
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:045.910
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:046.163
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:046.457
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.222ms returns 0x00
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:046.993
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:047.835
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:048.530
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.539ms returns 0x00
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:049.637
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:050.132
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:050.524
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:050.829
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.824ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:051.085
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:051.337
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:054.710
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 3.624ms returns 0x00
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:055.118
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:055.436
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:056.081
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.842ms
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:056.427
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:056.742
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:056.998
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO - 0.424ms returns 960146260
    2021-Mar-15 14:12:50 . . . . Segger_connect_to_emu_without_snr: JLink INFO T41E4 000:057.313
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:057.746
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:058.034
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO - 0.128ms returns 0x00
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:058.283
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:058.582
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO JLINK_ExecCommand("device = Cortex-M33", ...).
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:069.234
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:070.269
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:122.858
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO Device "CORTEX-M33" selected.
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:125.585
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO - 66.735ms returns 0x00
    2021-Mar-15 14:12:50 . . . . . Segger_load_core_data: JLink INFO T41E4 000:125.900
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:126.466
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:126.691
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO - 0.334ms returns 0x01
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:126.906
    2021-Mar-15 14:12:50 . . . Segger_read_debug_port_register: JLink INFO T41E4 000:127.178
    2021-Mar-15 14:12:50 . . . Segger_read_debug_port_register: JLink INFO JLINK_Lock()
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure: JLink INFO T41E4 000:127.864
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure: JLink INFO T41E4 000:128.841
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure: JLink INFO - 1.257ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_coresight_configure: JLink INFO T41E4 000:129.321
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:129.649
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:130.405
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:131.012
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO - 1.541ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:131.346
    2021-Mar-15 14:12:50 . . . Segger_read_debug_port_register: JLink INFO T41E4 000:131.627
    2021-Mar-15 14:12:50 . . . Segger_read_debug_port_register: JLink INFO - 0.491ms
    2021-Mar-15 14:12:50 . nRF53_enable_coprocessor
    2021-Mar-15 14:12:50 . . nRF53_readback_status
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:132.657
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:133.011
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO - 0.484ms returns 0x01
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:133.257
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:133.478
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO JLINK_Lock()
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:134.075
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:134.746
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO - 0.838ms returns 0
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:135.071
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:135.368
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:136.099
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:136.475
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO - 1.272ms returns 0
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:136.815
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:137.417
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x02000000)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:138.215
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.007ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:138.612
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:138.908
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:139.623
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO Value=0x00000003
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:139.914
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.114ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:140.134
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:140.344
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 0.315ms
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:140.759
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:140.963
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO - 0.431ms returns 0x01
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:141.383
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:141.806
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:142.931
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:143.622
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO - 0.851ms returns 0
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:143.923
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:144.195
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:144.939
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:145.262
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO - 1.198ms returns 0
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:145.565
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:145.963
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x02000010)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:146.677
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 0.865ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:147.123
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:147.821
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:148.855
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO Value=0x00000001
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:149.337
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.643ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:149.591
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO T41E4 000:149.837
    2021-Mar-15 14:12:50 . . . Segger_read_access_port_register: JLink INFO - 0.369ms
    2021-Mar-15 14:12:50 . . nRF53_readback_status: Protection status read as NONE
    2021-Mar-15 14:12:50 . . nRF53_enable_coprocessor
    2021-Mar-15 14:12:50 . . . nRF53_is_secure_debug_available
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_emu
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:150.649
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_emu: JLink INFO JLINK_IsOpen()
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:150.890
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_emu: JLink INFO - 0.362ms returns 0x01
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:151.138
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_emu: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:151.384
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO JLINK_Lock()
    2021-Mar-15 14:12:50 . . . . . Segger_read_access_port_register
    2021-Mar-15 14:12:50 . . . . . . Segger_is_debug_region_powered
    2021-Mar-15 14:12:50 . . . . . . . Segger_read_debug_port_register
    2021-Mar-15 14:12:50 . . . . . . . . Segger_write_debug_port_register
    2021-Mar-15 14:12:50 . . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:152.111
    2021-Mar-15 14:12:50 . . . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2021-Mar-15 14:12:50 . . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:152.810
    2021-Mar-15 14:12:50 . . . . . . . . Segger_write_debug_port_register: JLink INFO - 0.850ms returns 0
    2021-Mar-15 14:12:50 . . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:153.098
    2021-Mar-15 14:12:50 . . . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:153.362
    2021-Mar-15 14:12:50 . . . . . . . Segger_read_debug_port_register: JLink INFO JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    2021-Mar-15 14:12:50 . . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:154.084
    2021-Mar-15 14:12:50 . . . . . . . Segger_read_debug_port_register: JLink INFO Value=0xF0000040
    2021-Mar-15 14:12:50 . . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:154.380
    2021-Mar-15 14:12:50 . . . . . . . Segger_read_debug_port_register: JLink INFO - 1.148ms returns 0
    2021-Mar-15 14:12:50 . . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:154.638
    2021-Mar-15 14:12:50 . . . . . . . Segger_read_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:155.003
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:155.738
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO - 0.878ms returns 0
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:156.017
    2021-Mar-15 14:12:50 . . . . . Segger_read_access_port_register: JLink INFO T41E4 000:156.281
    2021-Mar-15 14:12:50 . . . . . Segger_read_access_port_register: JLink INFO JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)
    2021-Mar-15 14:12:50 . . . . . Segger_read_access_port_register: JLink INFO T41E4 000:157.040
    2021-Mar-15 14:12:50 . . . . . Segger_read_access_port_register: JLink INFO Value=0x43000002
    2021-Mar-15 14:12:50 . . . . . Segger_read_access_port_register: JLink INFO T41E4 000:157.378
    2021-Mar-15 14:12:50 . . . . . Segger_read_access_port_register: JLink INFO - 1.223ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_read_access_port_register: JLink INFO T41E4 000:157.631
    2021-Mar-15 14:12:50 . . . . . Segger_read_access_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:157.877
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 0.368ms
    2021-Mar-15 14:12:50 . . . nRF53_get_secure_nonsecure_address
    2021-Mar-15 14:12:50 . . . Segger_ahb_write_u32
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:158.579
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:158.820
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO - 0.359ms returns 0x01
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:159.064
    2021-Mar-15 14:12:50 . . . Segger_ahb_write_u32: JLink INFO T41E4 000:159.306
    2021-Mar-15 14:12:50 . . . Segger_ahb_write_u32: JLink INFO JLINK_Lock()
    2021-Mar-15 14:12:50 . . . . . Segger_is_debug_region_powered
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:159.996
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:160.741
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO - 0.890ms returns 0
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:161.022
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:161.313
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:162.049
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO Value=0xF0000040
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:162.328
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO - 1.145ms returns 0
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:162.591
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:163.084
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:164.407
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 1.552ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:164.783
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:165.054
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x00)
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:165.837
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO Value=0x43000002
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:166.131
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO - 1.214ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO T41E4 000:166.397
    2021-Mar-15 14:12:50 . . . . Segger_read_access_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:166.909
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:167.617
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 0.894ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:168.017
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO T41E4 000:168.304
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x43000002)
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO T41E4 000:169.042
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO - 0.918ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO T41E4 000:169.379
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:169.911
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:170.672
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 0.972ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:171.023
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO T41E4 000:171.294
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x40005614)
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO T41E4 000:172.043
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO - 0.896ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO T41E4 000:172.327
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:172.831
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:173.543
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 0.861ms returns 0
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:173.828
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO T41E4 000:174.095
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x03, 0x00000000)
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO T41E4 000:174.810
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO - 0.858ms returns 0
    2021-Mar-15 14:12:50 . . . . Segger_write_access_port_register: JLink INFO T41E4 000:175.087
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:175.601
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x000000F0)
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:176.312
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO - 0.853ms returns -1
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:176.589
    2021-Mar-15 14:12:50 . . . . . Segger_write_debug_port_register: JLinkARM.dll reported "-1", an unknown error.
    2021-Mar-15 14:12:50 . . . . . . Segger_abort_debug_action
    2021-Mar-15 14:12:50 . . . . . . Segger_abort_debug_action: Attempting to clear any configuration errors in debug port before closing connection.
    2021-Mar-15 14:12:50 . . . . . . Segger_abort_debug_action: JLink INFO T41E4 000:177.316
    2021-Mar-15 14:12:50 . . . . . . Segger_abort_debug_action: JLink INFO JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    2021-Mar-15 14:12:50 . . . . . . Segger_abort_debug_action: JLink INFO T41E4 000:178.051
    2021-Mar-15 14:12:50 . . . . . . Segger_abort_debug_action: JLink INFO - 0.885ms returns 0
    2021-Mar-15 14:12:50 . . . . . . Segger_abort_debug_action: JLink INFO T41E4 000:178.337
    2021-Mar-15 14:12:50 . . . . . . Segger_abort_debug_action: JLink INFO JLINK_HasError()
    2021-Mar-15 14:12:50 . . . Segger_ahb_write_u32: JLink INFO T41E4 000:178.598
    2021-Mar-15 14:12:50 . . . Segger_ahb_write_u32: JLink INFO - 0.412ms
    2021-Mar-15 14:12:50 . nRF53_enable_coprocessor: Failed to enable coprocessor.
    2021-Mar-15 14:12:50 . nRF53_close
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:180.323
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:181.254
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO - 1.277ms returns 0x01
    2021-Mar-15 14:12:50 . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:181.827
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device: JLink INFO T41E4 000:182.691
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device: JLink INFO T41E4 000:183.171
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device: JLink INFO - 0.604ms returns FALSE
    2021-Mar-15 14:12:50 . . . . . Segger_is_connected_to_device: JLink INFO T41E4 000:183.423
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:184.010
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:184.264
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO - 0.373ms returns 0x01
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:184.511
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:184.756
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:185.116
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:185.733
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO - 0.810ms returns 0
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:186.080
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:186.361
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:187.196
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:187.508
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO - 1.269ms returns 0
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:187.756
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO T41E4 000:188.026
    2021-Mar-15 14:12:50 . . . . . . Segger_read_debug_port_register: JLink INFO - 0.394ms
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:188.620
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:188.861
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO - 0.360ms returns 0x01
    2021-Mar-15 14:12:50 . . . . . . . Segger_is_connected_to_emu: JLink INFO T41E4 000:189.108
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:189.396
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:189.754
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:190.376
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO - 0.781ms returns 0
    2021-Mar-15 14:12:50 . . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:190.677
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:190.983
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:191.668
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO - 0.829ms returns 0
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:191.949
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO T41E4 000:192.280
    2021-Mar-15 14:12:50 . . . . . . Segger_write_debug_port_register: JLink INFO - 0.464ms
    2021-Mar-15 14:12:50 . . . . Segger_disconnect_from_emu: JLink INFO T41E4 000:204.205
    Nevertheless, I tried selecting the hci_rpmsg_nrf5340_netcore project and downloading.   After warning me that the device was protected and giving me the option to go anyway (which I took), the netcore image downloaded successfully!   So I switched my app to be the active project and downloaded it.   Again it  warned me that it was protected and I allowed the download to proceed.   It worked.
    So it looks like I'm past this hurdle!
    Thanks again!
  • Great to hear that it works now! However, the error you saw with nrfjprog is interesting. What version of the tool are you using?
    Carl Richard
