Programming custom NRF52832 board using SWD interface
Hello NRF,
I have a custom board with NRF52832, and exposed the SWDIO, SWDCLK, GND, VDD, RESET pins for programming the board through the NRF52-DK board.
I started with a sample peripheral_uart, connected the NRF52-DK board to my PC, and managed to BUILD and RUN the sample application.
I verified that the app is working, by connecting to the UART service advertised by this app (on NRF52-DK) through another device that has NRF-TOOLBOX and used the UART service to query the NRF UART (NRF52-DK board) and managed to read write and verified the same over the console.
Now, I want to program my custom board, instead of the NRF52-DK board. Based on some suggestions on this site, I connected the
NRF52-DK        CUSTOM_BOARD
SWDIO             SWDIO
SWDCLK          SWDCLK
GND-DET         GND
VTG                 VDD/3V3
I then powered my board and then tried the BUILD and RUN option on the SEGGER.
It seems like my custom board is not getting programmed.
I would like to know :
1. Do I have to first program a bootloader on to my custom board. If so, please advise a boot loader that I can download from your site (if possible) and the steps to program the same on to my custom board.
2. How to program the compiled/build binary/hex files on to my custom card? Just BUILD and RUN would download the binary on to the connected custom board, instead of the NRF52-DK board? (because my custom board is connected through the SWD port and GND detected?) If BUILD and RUN wouldn't work, where can I find the compiled binary or hex file where I can program the same on to the custom board , perhaps by using command line nrfjprog tool???
3. I believe the peripheral_uart has it's pin definitions, for the RX, TX, LEDs etc. Since my custom board pin assignments might be different from that of the NRF52-DK, where can I find these definitions, so I can go map the pins?
All I need is to demonstrate this peripheral_uart app on my custom nrf52832 board, where I will connect a serial port on to its RX/TX to a putty terminal (on my pc) and then able to rx/tx data back and forth with the other connected device (NRF toolbox -> UART).
I appreciate your help in this regard.
regards,
Dinesh.
  • Hello Simon,
    The reply option is not available for the message you sent me yesterday, so I am replying to a previous message.
    I opened the zephyr -> boards -> arm -> nrf52dk_nrf52832, where I have the following files.
    1. board.cmake
    2. Kconfig
    3. Kconfig (board file)
    4. Kconfig.deconfig
    5. nrf52dk_nrf52832.dts
    6. nrf52dk_nrf52832.yaml
    7. nrf52dk_nrf52832_deconfig
    I checked what was inside the Kconfig, and I DID NOT find any GPIO assignments inside that file, instead I find the GPIO assignments on nrf52dk_nrf52832.dts file.
    Please suggest, it is this file that works as the GPIO mapping file?
    So, what if I change this file to correspond to the Sparkfun board or my custom board, and start a new project based on the nrf52dk_nrf52832 , which will now pull the GPIO configuration based on the Sparkfun board, would that work?
    regards,
    Dinesh.
  • Hi
    We don't have any details as to what this bootloader is, but I assume Sparkfun provides it in the case that this should happen. You can check out this thread on DevZone for an explanation on how to use a Sparkfun board with a DK. I would also assume that recovering the Sparkfun board would be similar to how you recover the nRF52840 Dongle, which is described in the Dongle Programming tutorial.
    As for the board file configuration and GPIO configuration, please check out "The board files" section in part 3 of our NCS tutorial which explains the complete setup of custom board files in NCS, as it is not only the board file deciding GPIO mapping etc. in NCS. It is better explained in that guide than I can do in a single DevZone comment.
    Simon
