System halt right after BLE disconnection associated nrfx_rtc_enable
My BLE peripheral device based on BLE uart example with nrf52832 has an issue.
My device is paired with central device and I turned off the central. My device started advertising as expected. I turned on the central and my device connected but halted right after that with ERROR 3735928559 at nrfx_rtc.c:130
in the situation, LED_1 is on (like it is pconnected) and any button doesn;t work.
00> <info> app: Disconnected. conn_handle: 0x0, reason: 0x15 <<-- This is disconnection by turning off the central
00>
00> <info> app: Connected <<-- connected as soon as central tuning on
00>
00> <error> app: ERROR 3735928559 [Unknown error code] at C:\Users\shuchoi\Dropbox\Dev\nRF52\nRF5_SDK_17.0.2_d674dde\modules\nrfx\drivers\src\nrfx_rtc.c:130
00>
00> PC at: 0x0002F47F
00>
00> <error> app: End of error report
nrfx_rtc.c c:130 is the line of NRFX_ASSERT(m_cb[p_instance->instance_id].state == NRFX_DRV_STATE_INITIALIZED);
void nrfx_rtc_enable(nrfx_rtc_t const * const p_instance)
    nrf_rtc_task_trigger(p_instance->p_reg, NRF_RTC_TASK_START);
    m_cb[p_instance->instance_id].state = NRFX_DRV_STATE_POWERED_ON;
    NRFX_LOG_INFO("Enabled.");
Please advise me where do I start debuging and what is likely to be root cause. Thanks.
  • Found the issue and moved nrf_drv_rtc_enable function under main().
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                //nrf_drv_rtc_enable(&rtc); --> create the disconnection issue
