NRF52820 COMP issue
Hello everyone!
I have some issue with the comparator module on the nrf52820 chip.
We need to compare one of external analog signal the 1.8V internal reference source. (But other variants – 1.2V / 2.4V don’t work either)
When I set 0 Volt on the measurement contact – the result of comparison is correct (0).
But as soon as I increase voltage, even on 0.1V - the result immediately becomes incorrect (1).
Moreover, I tried to use differential mode (just for an experiment).
In that mode comparison is performed relative to the reference signal on the external pin.
So, in that mode comparisons are performed perfect.
It seems for me there are some problems with internal reference source.
We develop the software for the nrf52820  mcu but at this moment we haven't received our boards and use the nrf52833 development kit for  debug.
Could the problem be caused by that?
Also I thought that the problem might be with my board and tried to use others. But unfortunetely  the result is the same.
Could you please help me with it?
Many thanks in advance!
All the best!
Ernst
  • Hello Ernst,
    Good work debugging it with differential mode, this is very helpful! I have never heard of this being an issue before - the emulation of the nRF52820 on the nRF52833 is very straight forward, since the nRF52820 is a subset of the nRF52833.
    Are there any errors being generated when your program is running?
    Could you ensure that DEBUG is defined in your preprocessor defines, like shown in the included image?
    Enabling DEBUG in the preprocessor defines will output a detailed error message to your logger backend, in the case that a non-NRF_SUCCESS error is passed to an APP_ERROR_CHECK.
    Could you also tell me how you are measuring / monitoring the voltage you are applying to the chosen compare pin, so that you know that it is exactly 0.1 V?
    It would also be very helpful to see the your code here, particularly for the initiation and configuration of the comp peripheral.
    Please use the "Insert->Code" option when sharing code here on DevZone.
    Looking forward to resolving this issue together!
    Karl
  • Hello, Karl!
    Many thanks for the answer!
    I've tried to do that, but I still don't see any errors.
    I use an oscilloscope connected to the measurement pin and a laboratory power supply's voltmeter.
    Yes, sure.
    I've attached that code bellow.
    void COINCELL_vInit(void)
      nrf_comp_ref_set(NRF_COMP_REF_Int1V8);
      nrf_comp_main_mode_set(NRF_COMP_MAIN_MODE_SE);
      nrf_comp_speed_mode_set(NRF_COMP_SP_MODE_High);
      nrf_comp_hysteresis_set(NRF_COMP_HYST_NoHyst);
      nrf_comp_input_select(NRF_COMP_INPUT_0);
      nrf_comp_enable();
      nrf_comp_task_trigger(NRF_COMP_TASK_START);
      while(!nrf_comp_event_check(NRF_COMP_EVENT_READY));
    void COINCELL_vUpdate(void)
      nrf_comp_task_trigger(NRF_COMP_TASK_SAMPLE);
      //sCoincell.bCellAboveTresshold = (nrf_comp_result_get() > 0) ? bTRUE : bFALSE;
      // Debug only section
      uint32_t a = nrf_comp_result_get();
      if (a)
        a = 1;
        a = 1;
    Many thanks for helping!
    Have a nice day!
    Ernst
  • Hello again Ernst,
    No problem at all, I am happy to help! :)
    Ernst Smirnov said:
    Yes, sure.
    Thank you for clarifying, this is very helpful.
    Are you using the UP, DOWN, and CROSS events in your testing, or are you only checking the value of the result register through the nrf_comp_result_get function?
    Could you explain the intent behind the debug section of your COINCELL_vUpdate function? I am not sure I understand its purpose / what you might be using this for.
    How did you verify/check that the output of the comparison always was 1 when the voltage of the input was higher than 0V?
    Ernst Smirnov said:
    Have a nice day!
    Thank you for saying that - I hope you have a nice day as well!
    Looking forward to resolving this issue together.
    Karl
  • No problem at all, I am happy to help! :)
    I'm glad to see it, thank you)
    Yes, I just checking the value of the result register after starting the NRF_COMP_TASK_SAMPLE task.
    Is it incorrect?
    Sure! I start a debug session and put a break point to one of these lines. After that I adjust of a power source and so I can see comparison result has changed.
    I see it on the debug session. If the voltage of the input is higher than 0V I get the first branch of the debug condition only. However, as soon as I decrease that to zero - I get the second branch immediately.
    Many thanks for your concern, Karl!
    With kind regards
    Ernst
    Is it incorrect?
    No, this is fine. I was just wondering whether you were using the events as well.
    Thank you for clarifying, this makes it a lot clearer, and I now understand how you are using this for debugging with breakpoints only, and not as a way to monitor the value of 'a' - I just had to make sure.
    I see now that you do never set your TH registers - I'm sorry that I missed this the first time I looked through your code. You are currently not setting the TH register, which the VUP and VDOWN is derived from. Their default value is 0, which means your thresholds place at 1.8V/64 = 0.028 V. This could be why you are seeing the change immediately after manually increasing the voltage. If you want the reference level to be at exactly 1.8V with no hysteresis, please change them both to the value 63, so that the threshold is placed at 1.8V.
    You can set your TH register by using the nrf_comp_th_set function.
    Please try this, and let me know if it resolves your issue! :)
    If this does not resolve your issue, could you possibly send me a stripped down version of the project, so I may test this on my end, and see if I am able to reproduce the issue?
    Karl
