Errors when modifying the multirole example into serialized connection mode
I modified the example: nRF5_SDK_17.0.2_d674dde\examples\ble_central_and_peripheral\experimental\ble_app_multirole_lesc to run on a serialized connection mode with two PCA10040 boards.
The code can be built without any issues after removing software device and adding serialization lib etc.
When run it, it has connection issues with a peripheral (PCA10056, running a HRS example). When tried to connect a mobile (central), it also has problems.
I put the code on through the debugger to sure the memory is erased.
Any help I can get?
The logging is attached:
<info> app: Scanning
<info> peer_manager_handler: Peer data updated in flash: peer_id: 1, data_id: Peer rank, action: Update, no change
<info> app: CENTRAL: Connected, handle: 0.
<info> app: CENTRAL: Searching for HRS on conn_handle 0x0
<info> peer_manager_handler: Connection security failed: role: Central, conn_handle: 0x0, procedure: Encryption, error: 4102
<warning> peer_manager_handler: Disconnecting conn_handle 0.
<info> app: CENTRAL: Disconnected, handle: 0, reason: 0x16
<info> app_timer: RTC: initialized.
<info> app: LE Secure Connections example started.
<info> app: Advertising
<info> app: PERIPHERAL: Connected, handle 1.
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update
<info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x1, procedure: Encryption, error: 4157
<warning> peer_manager_handler: Disconnecting conn_handle 1.
<info> app: PERIPHERAL: Disconnected, handle 1, reason 0x3D.
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
<info> app: PERIPHERAL: BLE_GAP_EVT_SEC_PARAMS_REQUEST
<info> peer_manager_handler: Connection security failed: role: Peripheral, conn_handle: 0x1, procedure: Bonding, error: 133
<info> app: PERIPHERAL: BLE_GAP_EVT_AUTH_STATUS: status=0x85 bond=0x0 lv4: 0 kdist_own:0x0 kdist_peer:0x0
<info> app: PERIPHERAL: Disconnected, handle 1, reason 0x16.
