Using S132 v7.2, I'm getting a hard fault at PC 0x00015810 (I see the flag set in SEGGER, and the console outputs a SOFTDEVICE ASSERT FAILED error) that I'm working on manually tracing. I'm borrowing some code from another project of ours to get this one set up, and so the problem is likely something to do with initial mesh setup and initialization that is then causing the later hard fault. I'm hoping I can get the actual assert error information to better pinpoint the problem, because it's been a bit of a wild goose chase up to now.
