AWS Asset Tracker npx issue
Hi
Is it so that the only way to use Asset Tracker 2 is with this AWS? Not even with the nrf cloud?
I am following your instructions here
https://nordicsemiconductor.github.io/asset-tracker-cloud-docs/v1.5.x/docs/aws/GettingStarted.html
git clone github.com/.../asset-tracker-cloud-aws-js.git asset-tracker-aws
cd asset-tracker-aws
npm ci
npx tsc
The last bit, using a fresh install of ubuntu with build-essential installed, then installing npm fails to build
the npx tsc gives me:
usky - Git hooks installed
added 1478 packages in 45.259s
billy@ubuntu:~/asset-tracker-aws$ npx tsc
cdk/resources/CellGeolocation.ts:7:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
7 import * as Lambda from '@aws-cdk/aws-lambda'
cdk/resources/CellGeolocation.ts:12:22 - error TS2307: Cannot find module '@aws-cdk/aws-sqs' or its corresponding type declarations.
12 import * as SQS from '@aws-cdk/aws-sqs'
cdk/resources/CellGeolocationApi.ts:4:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
4 import * as Lambda from '@aws-cdk/aws-lambda'
billy@ubuntu:~/asset-tracker-aws$ lsb_release -a
No LSB modules are available.
Distributor ID:    Ubuntu
Description:    Ubuntu 20.04.2 LTS
Release:    20.04
Codename:    focal
nodejs -v
v10.19.0
billy@ubuntu:~/asset-tracker-aws$ cdk --version
1.93.0 (build c506d3b)
AWS is always fun
Thanks for any help
