Asset Tracker 2 AWS deploy
Hi
Followed all the getting started instructions given here
https://nordicsemiconductor.github.io/asset-tracker-cloud-docs/v1.5.x/docs/aws/GettingStarted.html
and then here
https://nordicsemiconductor.github.io/asset-tracker-cloud-docs/v1.5.x/docs/app/AWS.html#app-aws
went through the entire process, installing all the dependencies,
billy@ubuntu:~/cat-tracker-web-app$ aws cloudfront create-invalidation --distribution-id \
> $REACT_APP_CLOUDFRONT_DISTRIBUTION_ID_WEB_APP --paths /,/index.html
    "Location": "">cloudfront.amazonaws.com/.../I2AQB884MXMK5Y",
    "Invalidation": {
        "Id": "I2AQB884MXMK5Y",
        "Status": "InProgress",
        "CreateTime": "2021-03-14T13:01:11.253Z",
        "InvalidationBatch": {
            "Paths": {
                "Quantity": 1,
                "Items": [
                    "/,/index.html"
            "CallerReference": "cli-1615726870-549900"
billy@ubuntu:~/cat-tracker-web-app$ echo "Done. Now open https://$REACT_APP_WEB_APP_DOMAIN_NAME/ to view the web app."
Done. Now open d12use2b01we2.cloudfront.net/ to view the web app.
But when I open the website, its a blank page with the following HTML
<code>
<!doctype html><html lang="en"><head><meta charset="utf-8"/><link rel="shortcut icon" type="image/svg+xml" href="/NordicSemiconductor/asset-tracker-cloud-app-j/favicon.svg"/><link rel="stylesheet" href="">cdn.jsdelivr.net/.../bootstrap.min.css" integrity="sha384-TX8t27EcRE3e/ihU7zmQxVncDAy5uIKz4rEkgIXeMed4M0jlfIDPvg6uqKI2xXr2" crossorigin="anonymous"/><link rel="stylesheet" href="">cdnjs.cloudflare.com/.../introjs.min.css" integrity="sha512-631ugrjzlQYCOP9P8BOLEMFspr5ooQwY3rgt8SMUa+QqtVMbY/tniEUOcABHDGjK50VExB4CNc61g5oopGqCEw==" crossorigin="anonymous"/><meta name="viewport" content="width=device-width,initial-scale=1,shrink-to-fit=no"/><meta name="theme-color" content="#00A9CE"/><link rel="manifest" href="/NordicSemiconductor/asset-tracker-cloud-app-j/manifest.json"/><meta name="application-name" content="Cat Tracker"/><meta name="msapplication-TileColor" content="#00A9CE"/><title>Cat Tracker</title><link rel="stylesheet" href="">unpkg.com/.../leaflet.css" integrity="sha512-xodZBNTC5n17Xt2atTPuE1HxjVMSvLVW9ocqUKLsCC5CXdbqCmblAshOMAS6/keqq/sMZMZ19scR4PsZChSR7A==" crossorigin=""/><script src="">unpkg.com/.../leaflet.js" integrity="sha512-XQoYMqMTK8LvdxXYG3nZ448hOEQiglfqkJs1NOQV44cWnUrBc8PkAOcXy20w0vlaXaVUearIOBhiXZ5V3ynxwA==" crossorigin=""></script><link rel="stylesheet" href="">rsms.me/.../inter-ui.css" crossorigin=""/></head><body><noscript>You need to enable JavaScript to run this app.</noscript><div id="root"></div><script>!function(e){function t(t){for(var n,o,u=t[0],i=t[1],f=t[2],s=0,d=[];s<u.length;s++)o=u[s],Object.prototype.hasOwnProperty.call(a,o)&&a[o]&&d.push(a[o][0]),a[o]=0;for(n in i)Object.prototype.hasOwnProperty.call(i,n)&&(e[n]=i[n]);for(l&&l(t);d.length;)d.shift()();return c.push.apply(c,f||[]),r()}function r(){for(var e,t=0;t<c.length;t++){for(var r=c[t],n=!0,o=1;o<r.length;o++){var i=r[o];0!==a[i]&&(n=!1)}n&&(c.splice(t--,1),e=u(u.s=r[0]))}return e}var n={},o={3:0},a={3:0},c=[];function u(t){if(n[t])return n[t].exports;var r=n[t]={i:t,l:!1,exports:{}};return e[t].call(r.exports,r,r.exports,u),r.l=!0,r.exports}u.e=function(e){var t=[];o[e]?t.push(o[e]):0!==o[e]&&{5:1}[e]&&t.push(o[e]=new Promise((function(t,r){for(var n="static/css/"+({4:"xlsx"}[e]||e)+"."+{0:"31d6cfe0",1:"31d6cfe0",4:"31d6cfe0",5:"10907ed6",6:"31d6cfe0",7:"31d6cfe0",9:"31d6cfe0",10:"31d6cfe0",11:"31d6cfe0",12:"31d6cfe0"}[e]+".chunk.css",a=u.p+n,c=document.getElementsByTagName("link"),i=0;i<c.length;i++){var f=(l=c[i]).getAttribute("data-href")||l.getAttribute("href");if("stylesheet"===l.rel&&(f===n||f===a))return t()}var s=document.getElementsByTagName("style");for(i=0;i<s.length;i++){var l;if((f=(l=s[i]).getAttribute("data-href"))===n||f===a)return t()}var d=document.createElement("link");d.rel="stylesheet",d.type="text/css",d.onload=t,d.onerror=function(t){var n=t&&t.target&&t.target.src||a,c=new Error("Loading CSS chunk "+e+" failed.\n("+n+")");c.code="CSS_CHUNK_LOAD_FAILED",c.request=n,delete o[e],d.parentNode.removeChild(d),r(c)},d.href=a,document.getElementsByTagName("head")[0].appendChild(d)})).then((function(){o[e]=0})));var r=a[e];if(0!==r)if(r)t.push(r[2]);else{var n=new Promise((function(t,n){r=a[e]=[t,n]}));t.push(r[2]=n);var c,i=document.createElement("script");i.charset="utf-8",i.timeout=120,u.nc&&i.setAttribute("nonce",u.nc),i.src=function(e){return u.p+"static/js/"+({4:"xlsx"}[e]||e)+"."+{0:"f9aa918b",1:"11e8b403",4:"29a82ef0",5:"de48f44f",6:"bcff8023",7:"664d6b66",9:"d3198298",10:"affcc60b",11:"aa93e34a",12:"be587fd1"}[e]+".chunk.js"}(e);var f=new Error;c=function(t){i.onerror=i.onload=null,clearTimeout(s);var r=a[e];if(0!==r){if(r){var n=t&&("load"===t.type?"missing":t.type),o=t&&t.target&&t.target.src;f.message="Loading chunk "+e+" failed.\n("+n+": "+o+")",f.name="ChunkLoadError",f.type=n,f.request=o,r[1](f)}a[e]=void 0}};var s=setTimeout((function(){c({type:"timeout",target:i})}),12e4);i.onerror=i.onload=c,document.head.appendChild(i)}return Promise.all(t)},u.m=e,u.c=n,u.d=function(e,t,r){u.o(e,t)||Object.defineProperty(e,t,{enumerable:!0,get:r})},u.r=function(e){"undefined"!=typeof Symbol&&Symbol.toStringTag&&Object.defineProperty(e,Symbol.toStringTag,{value:"Module"}),Object.defineProperty(e,"__esModule",{value:!0})},u.t=function(e,t){if(1&t&&(e=u(e)),8&t)return e;if(4&t&&"object"==typeof e&&e&&e.__esModule)return e;var r=Object.create(null);if(u.r(r),Object.defineProperty(r,"default",{enumerable:!0,value:e}),2&t&&"string"!=typeof e)for(var n in e)u.d(r,n,function(t){return e[t]}.bind(null,n));return r},u.n=function(e){var t=e&&e.__esModule?function(){return e.default}:function(){return e};return u.d(t,"a",t),t},u.o=function(e,t){return Object.prototype.hasOwnProperty.call(e,t)},u.p="/NordicSemiconductor/asset-tracker-cloud-app-js",u.oe=function(e){throw console.error(e),e};var i=this["webpackJsonp@nordicsemiconductor/asset-tracker-cloud-app"]=this["webpackJsonp@nordicsemiconductor/asset-tracker-cloud-app"]||[],f=i.push.bind(i);i.push=t,i=i.slice();for(var s=0;s<i.length;s++)t(i[s]);var l=f;r()}([])</script><script src="/NordicSemiconductor/asset-tracker-cloud-app-js/static/js/8.a3e87996.chunk.js"></script><script src="/NordicSemiconductor/asset-tracker-cloud-app-js/static/js/main.41a50ec8.chunk.js"></script></body></html>
</code>
The page is completely blank
Thanks
