Writing to and reading from flash on nRF5340
I am trying to use part of the code from this example https://github.com/zephyrproject-rtos/zephyr/blob/master/samples/subsys/nvs
to write to and read from flash on nRF5340 SoC. However, I am getting the following linking error when building the project in Segger.
I am using Segger v5.34a, NCS v1.5.0-rc1 and Zephyr v2.4.99-ncs1-rc1.
I am including the following header files
#include <zephyr.h>
#include <power/reboot.h>
#include <device.h>
#include <string.h>
#include <drivers/flash.h>
#include <storage/flash_map.h>
#include <fs/nvs.h>
Can you please help ?
1> Linking ‘zephyr_prebuilt.elf’
1> C:\Zypher\v1.5.0-rc1\toolchain\opt/bin/arm-none-eabi-gcc zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -Wl,-T zephyr/linker.cmd -Wl,-Map=C:/Sandbox/PID4-Firmware/app_core/build_nrf5340pdk_nrf5340_cpuapp_flash/zephyr/zephyr_prebuilt.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/libarch__arm__core__aarch32__cortex_m__mpu.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/lib/libc/newlib/liblib__libc__newlib.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/boards/boards/arm/nrf5340pdk_nrf5340_cpuapp/libboards__arm__nrf5340dk_nrf5340.a zephyr/drivers/adc/libdrivers__adc.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/ipm/libdrivers__ipm.a zephyr/drivers/spi/libdrivers__spi.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/hal_nordic/libmodules__hal_nordic.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -Lc:/zypher/v1.5.0-rc1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main/nofp -LC:/Sandbox/PID4-Firmware/app_core/build_nrf5340pdk_nrf5340_cpuapp_flash/zephyr -lgcc -Wl,--print-memory-usage zephyr/arch/common/libisr_tables.a C:/Zypher/v1.5.0-rc1/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.7.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -lm -Wl,-lc -LC:/Zypher/v1.5.0-rc1/toolchain/opt/arm-none-eabi/lib/thumb/v8-m.main/nofp -u_printf_float -Wl,-lgcc -lc -specs=nano.specs -o zephyr\zephyr_prebuilt.elf
1> Memory region Used Size Region Size %age Used
1> FLASH: 73512 B 1 MB 7.01%
1> SRAM: 28680 B 448 KB 6.25%
1> c:/zypher/v1.5.0-rc1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(pid4_flash.c.obj): in function `flash_get_page_info_by_offs':
1> C:\Sandbox\PID4-Firmware\app_core\build_nrf5340pdk_nrf5340_cpuapp_flash/zephyr/include/generated/syscalls/flash.h:85: undefined reference to `z_impl_flash_get_page_info_by_offs'
1> c:/zypher/v1.5.0-rc1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(pid4_flash.c.obj): in function `flash_init':
1> C:\Sandbox\PID4-Firmware\app_core\build_nrf5340pdk_nrf5340_cpuapp_flash/../src/flash/pid4_flash.c:45: undefined reference to `nvs_init'
1> collect2.exe: error: ld returned 1 exit status
1> IDT_LIST: 104 B 2 KB 5.08%
Build failed
Kind regards
Mohamed
    I have just realised what the problem was. I needed to add this to my prj.conf file
    CONFIG_FLASH=y
    CONFIG_NVS=y
    I have also noticed the existence of other APIs flash_read() and flash_write().
    What is the difference between flash_read() and nvs_read() and the corresponding write APIs?
    Kind regards
    Mohamed
  • Hi!
    Great that you managed to fix the issue. The flash API is a more low level API used for interacting directly with the flash peripheral. The NVS API uses the flash API for easier organization and usage of storage. What you chose depends on your application, but NVS is commonly used for storing BLE bonding data for example.
    Carl Richard
  • Thank you Carl.
    I am leaning more towards using flash API.
    Maybe if you can answer the following questions about the code of the example I referred to at the top of the page, it will help me make a better decision.
    Q1/ I can see the line below is setting an offset from the start of the flash area but What is 'storage', I could not find where it is defined. I was expecting to see fs.offset = some_address.
    fs.offset = FLASH_AREA_OFFSET( storage );
    Q2/ What is ADDRESS_ID used for in the line of code below?
    nvs_read( &fs, ADDRESS_ID, &buf, sizeof( buf );
    Q3/ What is meant by 'offset' in
    int flash_read(const struct device *dev, off_t offset, void *data, size_t len)
    int flash_write(const struct device *dev, off_t offset, const void *data, size_t len)
    Is it an offset from the start of the flash area or an offset from a specific page of the flash area?
    How can I specify which page I want to read from or write to?
    An example running Zephyr showing how to use the flash APIs will be very helpful.
    That is all for now. I would appreciate a quick response because I am working to very tight schedule. Thank you.
    Kind regards
    Mohamed
  • Hi!
    Glad to help!
    This refers to the storage partition defined by the device tree structure of the target board. In the case of the nRF5340DK you can find the storage label here. It is indeed an address!
    The NVS API works with id-data pairs, where an id points to a specific address (defined by the user) where data is stored. You can read more about this in the NVS API documentation.
    I believe you will find answers to all of this in the Flash API documentation, but here is a short summary: the offset is from the start of the flash area and you can get page start offset and size through API calls. Then flash write/read can be used to alter or read the page.
    You can have a look at the Flash Shell Sample for reference.
    Hope this answers your questions!
    Carl Richard
  • Thank you Carl for the quick response.
    In the example  https://github.com/zephyrproject-rtos/zephyr/blob/master/samples/subsys/nvs All I can see is
    #define ADDRESS_ID 1
    Then it is used in
    rc = nvs_read(&fs, ADDRESS_ID, &buf, sizeof(buf));
    So, what address is id ADDRESS_ID pointing to?
    I could not see the source code for this example.
    In the nvs_fs structure, data_wra is the address the data is written to but what is ate_wra used for?
    Also, after calling nvs_init( &fs, DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL );
    fs.ate_wra = 0x00000FF0, 0000 meaning sector 0, and 0FF0 is the offset within sector 0.
    Why is the offset within the sector not zero?
    fs.data_wra = 0x00000000
    fs.sector_size = 0x1000
    fs.sector_count = 3
    Is sector 0 at higher address or lower address? sector 0 at 0x000fa000 or at 0x???
    Can you please draw a memory map diagram after the call to nvs_init.
    Thank you.
    Kind regards
    Mohamed
    Please help.
    Kind regards
    Mohamed
