Writing to and reading from flash on nRF5340
I am trying to use part of the code from this example https://github.com/zephyrproject-rtos/zephyr/blob/master/samples/subsys/nvs
to write to and read from flash on nRF5340 SoC. However, I am getting the following linking error when building the project in Segger.
I am using Segger v5.34a, NCS v1.5.0-rc1 and Zephyr v2.4.99-ncs1-rc1.
I am including the following header files
#include <zephyr.h>
#include <power/reboot.h>
#include <device.h>
#include <string.h>
#include <drivers/flash.h>
#include <storage/flash_map.h>
#include <fs/nvs.h>
Can you please help ?
1> Linking ‘zephyr_prebuilt.elf’
1> C:\Zypher\v1.5.0-rc1\toolchain\opt/bin/arm-none-eabi-gcc zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj -Wl,-T zephyr/linker.cmd -Wl,-Map=C:/Sandbox/PID4-Firmware/app_core/build_nrf5340pdk_nrf5340_cpuapp_flash/zephyr/zephyr_prebuilt.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/mpu/libarch__arm__core__aarch32__cortex_m__mpu.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/lib/libc/newlib/liblib__libc__newlib.a zephyr/lib/posix/liblib__posix.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/boards/boards/arm/nrf5340pdk_nrf5340_cpuapp/libboards__arm__nrf5340dk_nrf5340.a zephyr/drivers/adc/libdrivers__adc.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/ipm/libdrivers__ipm.a zephyr/drivers/spi/libdrivers__spi.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/hal_nordic/libmodules__hal_nordic.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -Lc:/zypher/v1.5.0-rc1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/thumb/v8-m.main/nofp -LC:/Sandbox/PID4-Firmware/app_core/build_nrf5340pdk_nrf5340_cpuapp_flash/zephyr -lgcc -Wl,--print-memory-usage zephyr/arch/common/libisr_tables.a C:/Zypher/v1.5.0-rc1/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.7.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -no-pie -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -lm -Wl,-lc -LC:/Zypher/v1.5.0-rc1/toolchain/opt/arm-none-eabi/lib/thumb/v8-m.main/nofp -u_printf_float -Wl,-lgcc -lc -specs=nano.specs -o zephyr\zephyr_prebuilt.elf
1> Memory region Used Size Region Size %age Used
1> FLASH: 73512 B 1 MB 7.01%
1> SRAM: 28680 B 448 KB 6.25%
1> c:/zypher/v1.5.0-rc1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(pid4_flash.c.obj): in function `flash_get_page_info_by_offs':
1> C:\Sandbox\PID4-Firmware\app_core\build_nrf5340pdk_nrf5340_cpuapp_flash/zephyr/include/generated/syscalls/flash.h:85: undefined reference to `z_impl_flash_get_page_info_by_offs'
1> c:/zypher/v1.5.0-rc1/toolchain/opt/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: app/libapp.a(pid4_flash.c.obj): in function `flash_init':
1> C:\Sandbox\PID4-Firmware\app_core\build_nrf5340pdk_nrf5340_cpuapp_flash/../src/flash/pid4_flash.c:45: undefined reference to `nvs_init'
1> collect2.exe: error: ld returned 1 exit status
1> IDT_LIST: 104 B 2 KB 5.08%
Build failed
Kind regards
Mohamed
  • <error> fs_nvs: NVS not initialized
    This message is probably returned in response to subsequent NVS function calls. Although I am calling the function flash_get_page_count() after nvs_init() and it is returning page_count = 128 which looks like a valid value.
  • Hi again!
    I think this might be caused by the flash controller already being bound to "flash_dev". NVS binds the flash controller as well and will likely fail if the device is already bound. Could you try to do as in the NVS sample, where they get the page info by referencing DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL directly? This ensures that it's released before nvs_init is called. See the code below.
    int rc = 0,
    struct flash_pages_info info;
    /* define the nvs file system by settings with:
     *	sector_size equal to the pagesize,
     *	3 sectors
     *	starting at FLASH_AREA_OFFSET(storage)
    fs.offset = FLASH_AREA_OFFSET(storage);
    rc = flash_get_page_info_by_offs(
    	device_get_binding(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL),
    	fs.offset, &info);
    if (rc) {
    	printk("Unable to get page info");
    fs.sector_size = info.size;
    fs.sector_count = 3U;
    rc = nvs_init(&fs, DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL);
    if (rc) {
    	printk("Flash Init failed\n");
    Carl Richard
  • Thank you Carl.
    I tried your suggestion but the problem is still there.
    I tracked it down in the debugger and it seems the problem is occurring when nvs_startup() is called from nvs_init() it returns rc = -45 (0xffffffd3).
    rc = nvs_startup(fs);
    if (rc) {
    return rc;
    Digging even deeper in the API call tree, in nvs_startup(), I could see that the line of code  closed_sectors++  gets executed three times so, closed_sectors = 3 although the SES debugger did not allow me to set a watch on this variable. I also set two breakpoints at the two lines highlighted in yellow. The first breakpoint was reached but not the second one. This confirms that closed_sectors == fs->sector_count hence the jump to end:. So, it looks like all 3 sectors are closed and therefore there is no sector available NVS can write to.
    Why is this problem seen with nRF52833 (proprietary board) but not on nRF2833DK or on nRF5340 (another proprietary board)?
    static int nvs_startup(struct nvs_fs *fs)
    /* step through the sectors to find a open sector following
    * a closed sector, this is where NVS can to write.
    for (i = 0; i < fs->sector_count; i++) {
    addr = (i << ADDR_SECT_SHIFT) +
    (uint16_t)(fs->sector_size - ate_size);
    rc = nvs_flash_cmp_const(fs, addr, erase_value,
    sizeof(struct nvs_ate));
    if (rc) {
    /* closed sector */
    closed_sectors++;
    nvs_sector_advance(fs, &addr);
    if (!rc) {
    /* open sector */
    /* all sectors are closed, this is not a nvs fs */
    if (closed_sectors == fs->sector_count) {      // This breakpoint is reached
    rc = -EDEADLK;
    goto end;
    if (i == fs->sector_count) {      // This breakpoint is NOT reached
    /* none of the sectors where closed, in most cases we can set
    * the address to the first sector, except when there are only
    * two sectors. Then we can only set it to the first sector if
    * the last sector contains no ate's. So we check this first
    end:
    k_mutex_unlock(&fs->nvs_lock);
    return rc;   // rc = -45
    }//end of nvs_startup()
    Also, in C:\Zypher\v1.5.0-rc1\zephyr\include\devicetree\zephyr.h I see where the macro DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL is defined but it is greyed out meaning it is disabled.
    #if DT_NODE_HAS_PROP(DT_CHOSEN(zephyr_flash_controller), label)
    #define DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL \
    DT_LABEL(DT_CHOSEN(zephyr_flash_controller))
    Thank you for your help.
    Kind regards
    Mohamed
  • Hi again!
    You're getting the EDEADLK error, caused by all sectors being closed and unavailable to NVS. Are you using a custom board definition for the proprietary nRF52833 board?
    Carl Richard
  • Hi Carl,
    As far as I can tell I am not, I am using the generic nRF52833DK board definition.
    This is an extract of ...\build_nrf52833dk_nrf52833\zephyr\zephyr.dts,
    /dts-v1/;
    #address-cells = < 0x1 >;
    #size-cells = < 0x1 >;
    model = "Nordic nRF52833 DK NRF52833";
    compatible = "nordic,nrf52833-dk-nrf52833";
    chosen {
    zephyr,entropy = &rng;
    zephyr,flash-controller = &flash_controller;
    zephyr,console = &uart0;
    zephyr,shell-uart = &uart0;
    zephyr,uart-mcumgr = &uart0;
    zephyr,bt-mon-uart = &uart0;
    zephyr,bt-c2h-uart = &uart0;
    zephyr,sram = &sram0;
    zephyr,flash = &flash0;
    zephyr,code-partition = &slot0_partition;
    aliases {
    My overlay file is called nrf52833dk_nrf52833.overlay.
    I am attaching the device tree file zephyr.dts and yaml file sample.yaml.
    Note, This project was started by a colleague and I am adding the NVS flash functionality to it.
    5684.zephyr.dts
    sample.yaml
    Kind regards
    Mohamed
