nrfjprog --memwr 10001080 --val 00000700 should fail with a syntax error
What I intended was to write x'700' to x'10001080' i.e. NRF_UICR->CUSTOMER[0] !
When ran my application, which outputs NRF_UICR->CUSTOMER[0] to the log, I was very confused until I realized nrfjprog correctly clobbered  a location in RAM.
1) nrfjprog should not accept the address in decimal (Who does that intentionally??).
2) nrfjprog should not accept a value with a leading 0 (Surely the user meant a hexadecimal value)
3) At an absolute minimum nrfjprog should respond with
writing  00989AB8 = 000002BC
Then I might at least have had a chance to notice the odd values it reported.
Thank you for you consideration.
    Thank you for the report. I can see that your unfortunate series of events can happen, yes.
    The command line interface could be improved, for instance by returning hexadecimal addresses / values as well, when getting decimal or octal values as input. (I am not sure if numbers starting in 0 (zero) will be treated as octal or decimal. This points at need for better documentation as well: The format of <addr> is not specified in nrfjprog --help.)
    I'll bring your points over to the nrfjprog team, along with a comment that the most important item is clear feadback on what address was written to what value (to quickly discover this easy-to-make mistake), as well as fully document what formats <addr> can take.
    Terje
