Advertising Whitelist Difference between hids_keyboard and hids_mouse example
SDK: 17.0.0
Hardware: E-Byte E73-2G4M04S1B module
Chipset: NRF52832 QFAA QFN48
Running the hids examples, I noticed that the hids_mouse example will go from Fast Adv Whitelist → Slow Adv Whitelist → Slow Adv. However, once bonded, the hids_keybaord example never advertises without Whitelist until going through the Delete Bonds process. I can't identify the difference in advertising_init() or advertising_start() functions that would cause the mouse to behave any differently than the keyboard.
Ultimately I'd like to be able to press a button to disconnect from any peers and restart advertising without whitelist, but that may be a separate thread - right now, I'd just like to understand how to properly set up advertising so that I can automatically move from Whitelisted to non-Whitelisted advertising without hardware intervention.
Thanks
    There seems to be a bug in the HID mouse example. The handling of the BLE_ADV_EVT_SLOW_WHITELIST event is like this:
            case BLE_ADV_EVT_SLOW_WHITELIST:
                NRF_LOG_INFO("Slow advertising with whitelist.");
                err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_WHITELIST);
    which is not correct. It should have been the same as the keyboard example (where it does not start advertising without whitelist here):
    In both cases whitelisting can be explicitly turned off by a button press, where ble_advertising_restart_without_whitelist() is called on the BSP_EVENT_WHITELIST_OFF event. This is the correct approach for a HID device, which you only want to advertise without whitelisting when you are specifically trying to connect it to a new central.
  • Got it, thank you! I'll try to implement restart_without_whitelist() then, that seems like exactly what I need.
