NCS change BLE device name during runtime
I'm developing an BLE application with NCS where I want to be able to change the BLE device name during runtime. Therefore I enabled CONFIG_BT_DEVICE_NAME_DYNAMIC in the prj.conf.
It works but I always get this warning message when I change the device name:
<wrn> bt_hci_core: Unable to store name
So I'm curious why this warning says that the name couldn't be stored but it still changes?
Thanks in advance.
    Changing the name, and then storing it persistently in flash are 2 different operations. It tries to save the name persistently since you have CONFIG_BT_SETTINGS=y
    If you set these configs, you might be able to store it successfully
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
  • Hi Sigurd,
    thank you for your answer.
    When I understand you right, I can ignore the warning if I don't need to store the device name in the NVM?
    The strange thing is I actually have the config entries that you mentioned in my proj.conf and still getting this warning.
    My proj.conf:
    CONFIG_DEBUG_OPTIMIZATIONS=y
    CONFIG_CPLUSPLUS=y
    # Enable the UART driver
    CONFIG_UART_ASYNC_API=y
    CONFIG_NRFX_UARTE0=y
    CONFIG_SERIAL=y
    CONFIG_GPIO=y
    # Make sure printk is not printing to the UART console
    CONFIG_CONSOLE=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_UART_CONSOLE=n
    CONFIG_HEAP_MEM_POOL_SIZE=2048
    # Configuration required by Event Manager
    CONFIG_EVENT_MANAGER=y
    CONFIG_LINKER_ORPHAN_SECTION_PLACE=y
    CONFIG_REBOOT=y
    # Configuration BT general
    CONFIG_BT=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_NAME="Test"
    CONFIG_BT_DEVICE_NAME_DYNAMIC=y
    CONFIG_BT_DEVICE_APPEARANCE=0
    CONFIG_BT_MAX_CONN=1
    CONFIG_BT_MAX_PAIRED=1
    CONFIG_BT_DEBUG_LOG=n
    CONFIG_BT_CTLR_PHY_2M=n
    CONFIG_BT_CTLR_PHY_CODED=n
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=12
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=24
    CONFIG_BT_PERIPHERAL_PREF_SLAVE_LATENCY=0
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=400
    CONFIG_BT_GATT_CLIENT=y
    CONFIG_BT_L2CAP_TX_MTU=247
    CONFIG_BT_L2CAP_RX_MTU=247
    # Enable the device information service
    CONFIG_BT_DIS=y
    CONFIG_BT_DIS_PNP=n
    CONFIG_BT_DIS_FW_REV=y
    # Below is setup to let DIS information be read from settings
    CONFIG_BT_GATT_CACHING=n
    CONFIG_SETTINGS_RUNTIME=y
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_NONE=y
    CONFIG_BT_DIS_SETTINGS=y
    CONFIG_BT_DIS_STR_MAX=21
    # Enable the NUS service
    CONFIG_BT_NUS=n
    # Enable bonding
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    # This example requires more workqueue stack
    # Config logger
    CONFIG_LOG=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_ASSERT=y
    Best regards.
  • Could you try to remove CONFIG_SETTINGS_NONE=y , and see if that solves the issue ?
    Yes.
    Here is the code-line where you get the warning: https://github.com/nrfconnect/sdk-zephyr/blob/v2.4.99-ncs1/subsys/bluetooth/host/hci_core.c#L6724
    If removing CONFIG_SETTINGS_NONE does not work, you could try to print the error that is returned
    change
    BT_WARN("Unable to store name");
    to
    BT_WARN("Unable to store name: error %d",err);
  • Setting CONFIG_SETTINGS_NONE=n made the warnings disappear.
    But now I am getting the following zephyr fatal error, every time I call the bt_set_name() function.
    <err> os: ***** MPU FAULT *****
    <err> os:   Data Access Violation
    <err> os:   MMFAR Address: 0x20004354
    <err> os: r0/a1:  0x20004388  r1/a2:  0x00000001  r2/a3:  0x00ffffff
    <err> os: r3/a4:  0x00000000 r12/ip:  0x00000000 r14/lr:  0x00001831
    <err> os:  xpsr:  0x81000000
    <err> os: Faulting instruction address (r15/pc): 0x00000554
    <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
    <err> os: Current thread: 0x20001918 (unknown)
    <err> fatal_error: Resetting system
  • Thank you that solved the problem with the fatal error!
