I am working on the nrf52832 board with SDK16.
I am using a custom BLE example.
My TWI and BLE code work ok individually but when I integrate them it does not work.
Can anyone please share the working code or any example for this?
How does it not work? Be more specific.
regards
Jared
Hi Jared,
here is my code,
// Main.c //
#include <stdbool.h>
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "fds.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "bsp_btn_ble.h"
#include "sensorsim.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "ble_cus.h"
#define DEVICE_NAME "Cust" /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME "NordicSemiconductor" /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL 300 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 187.5 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.1 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS) /**< Maximum acceptable connection interval (0.2 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 0 /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE /**< No I/O capabilities. */
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define NOTIFICATION_INTERVAL APP_TIMER_TICKS(1000)
/* TWI instance ID. */
#if TWI0_ENABLED
#define TWI_INSTANCE_ID 0
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID 1
APP_TIMER_DEF(m_notification_timer_id);
static uint32_t m_custom_value_1 = 0b00000000000000000000000000000000;
static uint32_t m_custom_value_2 = 0b00000000000000000000000000000001;
static uint32_t m_custom_value_3 = 0b00000000000000000000000000000010;
static uint32_t m_custom_value_4 = 0b00000000000000000000000000000000;
static uint32_t Temperature = 0b00000000000000000000000000000000;
static uint32_t Humidity = 0b00000000000000000000000000000000;
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
BLE_CUS_DEF(m_cus);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifiers. */
{CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN}
static void advertising_start(bool erase_bonds);
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_config = {
.scl = SCL_PIN,
.sda = SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
nrf_drv_twi_enable(&m_twi);
/**@brief Callback function for asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] file_name File name of the failing ASSERT call.
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
advertising_start(false);
/**@brief Function for handling the Battery measurement timer timeout.
* @details This function will be called each time the battery level measurement timer expires.
* @param[in] p_context Pointer used for passing some arbitrary information (context) from the
* app_start_timer() call to the timeout handler.
static void notification_timeout_handler(void * p_context)
UNUSED_PARAMETER(p_context);
m_custom_value_1++;
err_code = ble_cus_custom_value_update_1(&m_cus, m_custom_value_1);
m_custom_value_2++;
err_code = ble_cus_custom_value_update_2(&m_cus, m_custom_value_2);
m_custom_value_3++;
err_code = ble_cus_custom_value_update_3(&m_cus, m_custom_value_3);
// ret_code_t err_code;
uint8_t address = 0X5C;
uint8_t regi = 0X00;
uint8_t sample_data;
uint8_t regi_1 = 0X02;
uint8_t sample_data_1;
bool detected_device = false;
twi_init();
nrf_delay_ms(2000);
err_code = nrf_drv_twi_tx(&m_twi, address,®i, sizeof(regi),true);
nrf_delay_ms(2000);
if(err_code == NRF_SUCCESS)
err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
if (err_code == NRF_SUCCESS)
detected_device = true;
Humidity = (uint32_t)sample_data;
//NRF_LOG_INFO("Humidity_1= %d",Humidity );
//NRF_LOG_FLUSH();
NRF_LOG_INFO("Humidity= %d",sample_data );
NRF_LOG_FLUSH();
NRF_LOG_INFO("failed");
NRF_LOG_FLUSH();
err_code = nrf_drv_twi_tx(&m_twi, address,®i_1, sizeof(regi_1),true);
nrf_delay_ms(2000);
err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data_1, sizeof(sample_data_1));
Temperature = (uint32_t)sample_data_1;
NRF_LOG_INFO("Temprature= %d °C \n",sample_data_1 );
NRF_LOG_FLUSH();
NRF_LOG_INFO("failed_1");
NRF_LOG_FLUSH();
//nrf_delay_ms(2000);
m_custom_value_4 = Humidity | (Temperature << 16) ;
err_code = ble_cus_custom_value_update_4(&m_cus, m_custom_value_4);
/**@brief Function for the Timer initialization.
* @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
// Initialize timer module.
// Create timers.
err_code = app_timer_create(&m_notification_timer_id, APP_TIMER_MODE_REPEATED, notification_timeout_handler);
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
* device including the device name, appearance, and the preferred connection parameters.
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the Custom Service Service events.
* @details This function will be called for all Custom Service events which are passed to
* the application.
* @param[in] p_cus_service Custom Service structure.
* @param[in] p_evt Event received from the Custom Service.
static void on_cus_evt(ble_cus_t * p_cus_service,
ble_cus_evt_t * p_evt)
switch(p_evt->evt_type)
case BLE_CUS_EVT_NOTIFICATION_ENABLED:
err_code = app_timer_start(m_notification_timer_id, NOTIFICATION_INTERVAL, NULL);
case BLE_CUS_EVT_NOTIFICATION_DISABLED:
err_code = app_timer_stop(m_notification_timer_id);
case BLE_CUS_EVT_CONNECTED:
case BLE_CUS_EVT_DISCONNECTED:
// No implementation needed.
ble_cus_init_t cus_init;
memset(&cus_init, 0, sizeof(cus_init));
// Set the cus event handler
cus_init.evt_handler = on_cus_evt;
err_code = ble_cus_init(&m_cus, &cus_init);
/**@brief Function for handling the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module which
* are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply
* setting the disconnect_on_fail config parameter, but instead we use the event
* handler mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
/**@brief Function for handling a Connection Parameters error.
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
/**@brief Function for starting timers.
static void application_timers_start(void)
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
NRF_LOG_INFO("Fast advertising.");
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ret_code_t err_code = NRF_SUCCESS;
NRF_LOG_INFO("Disconnected.");
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
NRF_LOG_INFO("Erase bonds!");
err_code = pm_peers_delete();
* @param[in] event Event generated when button is pressed.
static void bsp_event_handler(bsp_event_t event)
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
break; // BSP_EVENT_SLEEP
case BSP_EVENT_DISCONNECT:
break; // BSP_EVENT_DISCONNECT
case BSP_EVENT_WHITELIST_OFF:
break; // BSP_EVENT_KEY_0
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.include_appearance = true;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETED_SUCEEDED event
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for application main entry.
bool erase_bonds;
// Initialize.
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
peer_manager_init();
// Start execution.
NRF_LOG_INFO("Template example started.");
application_timers_start();
advertising_start(erase_bonds);
// Enter main loop.
for (;;)
idle_state_handle();
// ble_cus.c //
#include "sdk_common.h"
#include <string.h>
#include "nrf_gpio.h"
#include "boards.h"
#include "boards.h"
/**@brief Function for handling the Connect event.
* @param[in] p_cus Custom Service structure.
* @param[in] p_ble_evt Event received from the BLE stack.
static void on_connect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
p_cus->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
ble_cus_evt_t evt;
evt.evt_type = BLE_CUS_EVT_CONNECTED;
p_cus->evt_handler(p_cus, &evt);
/**@brief Function for handling the Disconnect event.
static void on_disconnect(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
UNUSED_PARAMETER(p_ble_evt);
p_cus->conn_handle = BLE_CONN_HANDLE_INVALID;
/**@brief Function for handling the Write event.
static void on_write(ble_cus_t * p_cus, ble_evt_t const * p_ble_evt)
ble_gatts_evt_write_t * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
// Check if the handle passed with the event matches the Custom Value Characteristic handle.
if (p_evt_write->handle == p_cus->custom_value_handles_1.value_handle)
// Put specific task here.
if (p_evt_write->data[0] == 0x01)
nrf_gpio_pin_clear(RED);
else if (p_evt_write->data[0] == 0x00)
nrf_gpio_pin_set(RED);
// Check if the Custom value CCCD is written to and that the value is the appropriate length, i.e 2 bytes.
if ((p_evt_write->handle == p_cus->custom_value_handles_1.cccd_handle)
&& (p_evt_write->len == 2)
// CCCD written, call application event handler
if (p_cus->evt_handler != NULL)
ble_cus_evt_t evt;
if (ble_srv_is_notification_enabled(p_evt_write->data))
evt.evt_type = BLE_CUS_EVT_NOTIFICATION_ENABLED;
evt.evt_type = BLE_CUS_EVT_NOTIFICATION_DISABLED;
// Call the application event handler.
void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context)
ble_cus_t * p_cus = (ble_cus_t *) p_context;
if (p_cus == NULL || p_ble_evt == NULL)
return;
on_connect(p_cus, p_ble_evt);
on_disconnect(p_cus, p_ble_evt);
case BLE_GATTS_EVT_WRITE:
on_write(p_cus, p_ble_evt);
/**@brief Function for adding the Custom Value characteristic.
* @param[in] p_cus_init Information needed to initialize the service.
* @return NRF_SUCCESS on success, otherwise an error code.
static ret_code_t custom_value_char_add(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_t attr_char_value;
ble_uuid_t ble_uuid;
ble_gatts_attr_md_t attr_md;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read = 1;
char_md.char_props.write = 1;
char_md.char_props.notify = 1;
char_md.p_char_user_desc = NULL;
char_md.p_char_pf = NULL;
char_md.p_user_desc_md = NULL;
char_md.p_cccd_md = &cccd_md;
char_md.p_sccd_md = NULL;
memset(&attr_md, 0, sizeof(attr_md));
attr_md.read_perm = p_cus_init->custom_value_char_attr_md.read_perm;
attr_md.write_perm = p_cus_init->custom_value_char_attr_md.write_perm;
attr_md.vloc = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth = 0;
attr_md.wr_auth = 0;
attr_md.vlen = 0;
ble_uuid.type = p_cus->uuid_type;
ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID_1;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len = sizeof(uint8_t);
attr_char_value.init_offs = 0;
attr_char_value.max_len = sizeof(uint32_t);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
memset(&cccd_md, 0, sizeof(cccd_md));
// Read operation on Cccd should be possible without authentication.
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
cccd_md.vloc = BLE_GATTS_VLOC_STACK;
err_code = sd_ble_gatts_characteristic_add(p_cus->service_handle, &char_md,
&attr_char_value,
&p_cus->custom_value_handles_1);
if (err_code != NRF_SUCCESS)
return err_code;
//Char 2
attr_md.vlen = 0;
ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID_2;
&attr_char_value,
&p_cus->custom_value_handles_2);
return err_code;
//Char 3
attr_md.vlen = 0;
ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID_3;
&attr_char_value,
&p_cus->custom_value_handles_3);
return err_code;
//Char 4
attr_md.vlen = 0;
ble_uuid.uuid = CUSTOM_VALUE_CHAR_UUID_4;
&attr_char_value,
&p_cus->custom_value_handles_4);
return err_code;
return NRF_SUCCESS;
ret_code_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init)
if (p_cus == NULL || p_cus_init == NULL)
return NRF_ERROR_NULL;
// Initialize the service structure
p_cus->evt_handler = p_cus_init->evt_handler;
// Add Custom Service UUID
ble_uuid128_t base_uuid = {CUSTOM_SERVICE_UUID_BASE};
err_code = sd_ble_uuid_vs_add(&base_uuid, &p_cus->uuid_type);
VERIFY_SUCCESS(err_code);
ble_uuid.uuid = CUSTOM_SERVICE_UUID;
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_cus->service_handle);
return err_code;
// Add Custom Value charracteristic
return custom_value_char_add(p_cus, p_cus_init);
ret_code_t ble_cus_custom_value_update_1(ble_cus_t * p_cus, uint32_t custom_value)
if (p_cus == NULL)
ble_gatts_value_t gatts_value;
// Initialize value struct.
memset(&gatts_value, 0, sizeof(gatts_value));
gatts_value.len = sizeof(uint32_t);
gatts_value.offset = 0;
gatts_value.p_value = &custom_value;
// Update database.
err_code = sd_ble_gatts_value_set(p_cus->conn_handle,
p_cus->custom_value_handles_1.value_handle,
&gatts_value);
return err_code;
// Send value if connected
if ((p_cus->conn_handle != BLE_CONN_HANDLE_INVALID))
ble_gatts_hvx_params_t hvx_params;
memset(&hvx_params, 0, sizeof(hvx_params));
hvx_params.handle = p_cus->custom_value_handles_1.value_handle;
hvx_params.type = BLE_GATT_HVX_NOTIFICATION;
hvx_params.offset = gatts_value.offset;
hvx_params.p_len = &gatts_value.len;
hvx_params.p_data = gatts_value.p_value;
err_code = sd_ble_gatts_hvx(p_cus->conn_handle, &hvx_params);
err_code = NRF_ERROR_INVALID_STATE;
return err_code;
ret_code_t ble_cus_custom_value_update_2(ble_cus_t * p_cus, uint32_t custom_value)
if (p_cus == NULL)
// Update database.
p_cus->custom_value_handles_2.value_handle,
&gatts_value);
return err_code;
hvx_params.handle = p_cus->custom_value_handles_2.value_handle;
return err_code;
ret_code_t ble_cus_custom_value_update_3(ble_cus_t * p_cus, uint32_t custom_value)
if (p_cus == NULL)
// Update database.
p_cus->custom_value_handles_3.value_handle,
&gatts_value);
return err_code;
hvx_params.handle = p_cus->custom_value_handles_3.value_handle;
return err_code;
ret_code_t ble_cus_custom_value_update_4(ble_cus_t * p_cus, uint32_t custom_value)
if (p_cus == NULL)
// Update database.
p_cus->custom_value_handles_4.value_handle,
&gatts_value);
return err_code;
hvx_params.handle = p_cus->custom_value_handles_4.value_handle;
return err_code;
}// ble_cus.h //
#ifndef BLE_CUS_H__
#define BLE_CUS_H__
#include <stdint.h>
#include "ble.h"
#define CUSTOM_SERVICE_UUID_BASE {0xd9, 0xb2, 0xa6, 0xa3, 0x0a, 0x8c, 0xa4, 0x89, \
0xd7, 0x4a, 0x3d, 0xd6, 0xd7, 0x77, 0x1a, 0xf9}
#define CUSTOM_SERVICE_UUID 0x77d7
#define CUSTOM_VALUE_CHAR_UUID_1 0x77d8
#define CUSTOM_VALUE_CHAR_UUID_2 0x77d9
#define CUSTOM_VALUE_CHAR_UUID_3 0x77da
#define CUSTOM_VALUE_CHAR_UUID_4 0x77db
// Forward declaration of the ble_cus_t type.
typedef struct ble_cus_s ble_cus_t;
/**@brief Macro for defining a ble_cus instance.
* @param _name Name of the instance.
* @hideinitializer
#define BLE_CUS_DEF(_name) \
static ble_cus_t _name; \
NRF_SDH_BLE_OBSERVER(_name ## _obs, \
BLE_HRS_BLE_OBSERVER_PRIO, \
ble_cus_on_ble_evt, &_name)
/**@brief Custom Service event type. */
typedef enum
BLE_CUS_EVT_NOTIFICATION_ENABLED, /**< Custom value notification enabled event. */
BLE_CUS_EVT_NOTIFICATION_DISABLED, /**< Custom value notification disabled event. */
BLE_CUS_EVT_DISCONNECTED,
} ble_cus_evt_type_t;
/**@brief Custom Service event. */
typedef struct
ble_cus_evt_type_t evt_type; /**< Type of event. */
} ble_cus_evt_t;
/**@brief Custom Service event handler type. */
typedef void (* ble_cus_evt_handler_t) (ble_cus_t * p_cus, ble_cus_evt_t * p_evt);
/**@brief Custom Service init structure. This contains all options and data needed for
* initialization of the service.*/
typedef struct
ble_cus_evt_handler_t evt_handler; /**< Event handler to be called for handling events in the Custom Service. */
uint8_t initial_custom_value; /**< Initial custom value */
ble_srv_cccd_security_mode_t custom_value_char_attr_md; /**< Initial security level for Custom characteristics attribute */
} ble_cus_init_t;
/**@brief Custom Service structure. This contains various status information for the service. */
struct ble_cus_s
uint16_t service_handle; /**< Handle of Custom Service (as provided by the BLE stack). */
ble_gatts_char_handles_t custom_value_handles_1; /**< Handles related to the Custom Value characteristic. */
ble_gatts_char_handles_t custom_value_handles_2; /**< Handles related to the Custom Value characteristic. */
ble_gatts_char_handles_t custom_value_handles_3; /**< Handles related to the Custom Value characteristic. */
ble_gatts_char_handles_t custom_value_handles_4; /**< Handles related to the Custom Value characteristic. */
uint16_t conn_handle; /**< Handle of the current connection (as provided by the BLE stack, is BLE_CONN_HANDLE_INVALID if not in a connection). */
uint8_t uuid_type;
/**@brief Function for initializing the Custom Service.
* @param[out] p_cus Custom Service structure. This structure will have to be supplied by
* the application. It will be initialized by this function, and will later
* be used to identify this particular service instance.
* @return NRF_SUCCESS on successful initialization of service, otherwise an error code.
ret_code_t ble_cus_init(ble_cus_t * p_cus, const ble_cus_init_t * p_cus_init);
void ble_cus_on_ble_evt( ble_evt_t const * p_ble_evt, void * p_context);
/**@brief Function for updating the custom value.
* @details The application calls this function when the cutom value should be updated. If
* notification has been enabled, the custom value characteristic is sent to the client.
* @note
* @param[in] Custom value
ret_code_t ble_cus_custom_value_update_1(ble_cus_t * p_cus, uint32_t custom_value);
ret_code_t ble_cus_custom_value_update_2(ble_cus_t * p_cus, uint32_t custom_value);
ret_code_t ble_cus_custom_value_update_3(ble_cus_t * p_cus, uint32_t custom_value);
ret_code_t ble_cus_custom_value_update_4(ble_cus_t * p_cus, uint32_t custom_value);
#endif // BLE_CUS_H__
I am using four characteristics in one service all characteristics having 32bit data.
I am able to send the digital sensors data.
Now I am trying to send temperature and humidity data to the nrf connect app but unable to send it. ( I have used the DHT12 Temperature and humidity sensor )
for transmitting the data I have used the " notification_timeout_handler " function.
So in this function, the data prints continuously on the nrf connect app. when comment the lines from 182 to 244 in main.c file. (which is the TWI code of the temp and humidity sensor).
if I uncomment those lines then all data prints only once except " m_custom_value_4 " data (into the app). when I check on the terminal emulator window the " humidity " is printed once and nothing will happen.
So I took a look at your code and there is a couple of things that can be problematic and should be improved:
You mentioned that most of the data is sent over BLE except for the m_custom_value_4 which probably indicates that the program asserts before that. Try to set a breakpoint at line 248 and see if the program reaches that far.
regards
Jared
Hi Jared,
Thanks for the reply.
Actually, I have managed to print TWI sensor data over BLE.
I am also getting the values into the nrf connect app. but there is an issue if I disconnect the device from the app I am getting the following error into the terminal emulator,
<error> app: ERROR 8 [NRF_ERROR_INVALID_STATE] at :0
PC at: 0x00000000
<error> app: End of error report
and the device stops working ( means like it will hang up to the reset button is not pressed )
after resetting the device, it works fine and updates the values but again if disconnect it throws an error into the terminal emulator.
can you please look into it?
here is my updated code,
// main.c //
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "ble.h"
#include "fds.h"
#if TWI0_ENABLED
#elif TWI1_ENABLED
APP_TIMER_DEF(m_our_char_timer_id);
static uint8_t Temperature = 0x00;
static uint8_t Humidity = 0x00;
BLE_CUS_DEF(m_cus);
/* TWI instance. */
.scl = SCL_PIN,
.sda = SDA_PIN,
// ALREADY_DONE_FOR_YOU: This is a timer event handler
static void timer_timeout_handler(void * p_context)
//Humidity
nrf_delay_ms(200);
Humidity = sample_data;
NRF_LOG_FLUSH();
// Temperature
nrf_delay_ms(200);
Temperature = sample_data_1;
NRF_LOG_FLUSH();
m_custom_value_1++;
m_custom_value_2++;
m_custom_value_3++;
// Create timers.
err_code = app_timer_create(&m_our_char_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
* the application.
err_code = app_timer_start(m_our_char_timer_id, NOTIFICATION_INTERVAL, NULL);
err_code = app_timer_stop(m_our_char_timer_id);
sleep_mode_enter();
} break;
switch (event)
sleep_mode_enter();
nrf_pwr_mgmt_run();
delete_bonds();
bool erase_bonds;
// Initialize.
twi_init();
nrf_delay_ms(2000);
log_init();
timers_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
// Enter main loop.
for (;;)
*/Hi,
You need to debug your application and check what function that is returning the error. You should also address the points I shared in my previous reply.
regards
Jared
