NCS OTA DFU failed in nrf52832
 I am trying to test and develop the DFU-OTA in nRF CONNECT SDK for nRF52832
I followed these link to develop  i am using NCS v1.4.2
1. I have copied the peripheral_lbs code to my workspace
2. Based on the link i have added few things and here i attached the related files
main.c
 * Copyright (c) 2018 Nordic Semiconductor ASA
 * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <sys/printk.h>
#include <sys/byteorder.h>
#include <zephyr.h>
#include <drivers/gpio.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/hci.h>
#include <bluetooth/conn.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/services/lbs.h>
#include <settings/settings.h>
#include <dk_buttons_and_leds.h>
// For FOTA
#include <tinycbor/cbor.h>
#include "cborattr/cborattr.h"
#include <mgmt/mgmt.h>
#include <mgmt/mcumgr/smp_bt.h>
#include <mgmt/mcumgr/buf.h>
#include <mgmt/mcumgr/smp.h>
#include "os_mgmt/os_mgmt.h"
#include "os_mgmt/os_mgmt_impl.h"
#include "os_mgmt/os_mgmt_config.h"
#include "img_mgmt/image.h"
#include "img_mgmt/img_mgmt.h"
#include "img_mgmt/img_mgmt_impl.h"
#include "img_mgmt/img_mgmt_config.h"
#define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED          DK_LED1
#define CON_STATUS_LED          DK_LED2
#define RUN_LED_BLINK_INTERVAL  1000
#define USER_LED                DK_LED3
#define USER_BUTTON             DK_BTN1_MSK
static bool app_button_state;
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_LBS_VAL),
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err %u)\n", err);
		return;
	printk("Connected\n");
	dk_set_led_on(CON_STATUS_LED);
	printk("Disconnected (reason %u)\n", reason);
	dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_LBS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		printk("Security changed: %s level %u\n", addr, level);
	} else {
		printk("Security failed: %s level %u err %d\n", addr, level,
			err);
static struct bt_conn_cb conn_callbacks = {
	.connected        = connected,
	.disconnected     = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_LBS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n", addr);
static void pairing_confirm(struct bt_conn *conn)
	bt_conn_auth_pairing_confirm(conn);
	printk("Pairing confirmed: %s\n", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	printk("Pairing failed conn: %s, reason %d\n", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.cancel = auth_cancel,
	.pairing_confirm = pairing_confirm,
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void app_led_cb(bool led_state)
	dk_set_led(USER_LED, led_state);
static bool app_button_cb(void)
	return app_button_state;
static struct bt_lbs_cb lbs_callbacs = {
	.led_cb    = app_led_cb,
	.button_cb = app_button_cb,
static void button_changed(uint32_t button_state, uint32_t has_changed)
	if (has_changed & USER_BUTTON) {
		bt_lbs_send_button_state(button_state);
		app_button_state = button_state ? true : false;
static int init_button(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		printk("Cannot init buttons (err: %d)\n", err);
	return err;
void main(void)
	int blink_status = 0;
	int err;
	printk("Starting Bluetooth Peripheral LBS example\n");
        printk("Application build time: %s %s \n", __DATE__, __TIME__);
	err = dk_leds_init();
	if (err) {
		printk("LEDs init failed (err %d)\n", err);
		return;
	err = init_button();
	if (err) {
		printk("Button init failed (err %d)\n", err);
		return;
	bt_conn_cb_register(&conn_callbacks);
	if (IS_ENABLED(CONFIG_BT_LBS_SECURITY_ENABLED)) {
		bt_conn_auth_cb_register(&conn_auth_callbacks);
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Bluetooth initialized\n");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_lbs_init(&lbs_callbacs);
	if (err) {
		printk("Failed to init LBS (err:%d)\n", err);
		return;
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),
			      sd, ARRAY_SIZE(sd));
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return;
	printk("Advertising successfully started\n");
        // For FOTA
  os_mgmt_register_group();
  img_mgmt_register_group();
  smp_bt_register();
	for (;;) {
		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
prj.conf
# Copyright (c) 2018 Nordic Semiconductor
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_Blinky"
# Enable the LBS service
CONFIG_BT_LBS=y
CONFIG_BT_LBS_POLL_BUTTON=y
CONFIG_DK_LIBRARY=y
# Added for FOTA
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUMGR=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_SMP_BT=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
also added full .zip file here
1447.dfu_app.zip
3. After successful compilation of the code uploaded to the Empty nRF52 DK (there is no bootloader separately added before )
4. Successfully showing the services in the nRF connect APP while entering into DFU
5. On the other-side i have just changed the device name to dfu_nrf_blinky
6. taken the build and app_update.bin is taken to mobile device
7. While initialize the DFU it asked for pairing and also paired with the device with valid key.
8. And on entering to start DFU it was disconnected like this and video is linked below with respective log
Log in the serial
*** Booting Zephyr OS build v2.4.0-ncs2  ***
[00:00:00.528,289] [0m<inf> mcuboot: Starting bootloader[0m
[00:00:00.534,576] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[0m
[00:00:00.545,043] [0m<inf> mcuboot: Boot source: none[0m
[00:00:00.550,781] [0m<inf> mcuboot: Swap type: none[0m
[00:00:00.844,512] [0m<inf> mcuboot: Bootloader chainload address offset: 0xc000[0m
[00:00:00.852,508] [0m<inf> mcuboot: Jumping to the first image slot[0m
Application build time: Mar 15 2021 14:36:28
I: 2 Sectors of 4096 bytes
I: alloc wra: 0, ff0
I: data wra: 0, 0
I: SoftDevice Controller build revision:
I: cf 5c 0f 11 88 9c d7 02 |.\......
I: 15 27 c7 c3 ca 60 19 85 |.'...`..
I: b7 c4 50 e3             |..P.
I: No ID address. App must call settings_load()
Connected
Passkey for 7e:2a:18:a3:a2:3c (random): 757200
Security changed: 7e:2a:18:a3:a2:3c (random) level 4
Pairing completed: 7c:78:7e:78:66:b3 (public), bonded: 1
Disconnected (reason 19)
Connected
Security changed: 7c:78:7e:78:66:b3 (public) level 4
Connected
Connected
Log from the nrf connect APP
nRF Connect, 2021-03-15
Nordic_Blinky (FB:B4:FA:11:EB:63)
V	14:54:14.912	Connecting to FB:B4:FA:11:EB:63...
D	14:54:14.912	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D	14:54:15.042	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D	14:54:15.096	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	14:54:15.097	Connected to FB:B4:FA:11:EB:63
D	14:54:15.099	wait(1600ms)
D	14:54:15.360	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
D	14:54:15.421	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
I	14:54:15.421	Device bonded
I	14:54:15.616	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
I	14:54:16.023	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
V	14:54:16.700	Discovering services...
D	14:54:16.700	gatt.discoverServices()
D	14:54:16.713	[Callback] Services discovered with status: 0
I	14:54:16.714	Services discovered
V	14:54:16.737	Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
   Client Characteristic Configuration (0x2902)
- Client Supported Features [R W] (0x2B29)
- Database Hash [R] (0x2B2A)
Generic Access (0x1800)
- Device Name [R] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
Nordic LED Button Service (00001523-1212-efde-1523-785feabcd123)
- Button [N R] (00001524-1212-efde-1523-785feabcd123)
- LED [W] (00001525-1212-efde-1523-785feabcd123)
SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
- SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
D	14:54:16.738	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
D	14:54:16.740	gatt.setCharacteristicNotification(00001524-1212-efde-1523-785feabcd123, true)
I	14:54:20.973	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
V	14:54:22.707	[McuMgr] Connecting...
D	14:54:22.720	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D	14:54:22.751	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I	14:54:22.767	[McuMgr] Connected to FB:B4:FA:11:EB:63
D	14:54:22.786	[McuMgr] wait(1600)
V	14:54:24.400	[McuMgr] Discovering services...
D	14:54:24.418	[McuMgr] gatt.discoverServices()
I	14:54:24.472	[McuMgr] Services discovered
V	14:54:24.483	[McuMgr] Primary service found
I	14:54:24.500	[McuMgr] Service Changed characteristic found on a bonded device
D	14:54:24.513	[McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V	14:54:24.550	[McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D	14:54:24.561	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I	14:54:24.662	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I	14:54:24.672	[McuMgr] Service Changed notifications enabled
V	14:54:24.695	[McuMgr] Requesting new MTU...
D	14:54:24.705	[McuMgr] gatt.requestMtu(515)
I	14:54:24.797	[McuMgr] MTU changed to: 65
D	14:54:24.807	[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V	14:54:24.831	[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D	14:54:24.852	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	14:54:24.979	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I	14:54:24.992	[McuMgr] Notifications enabled
V	14:54:25.034	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D	14:54:25.047	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I	14:54:25.066	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
A	14:54:25.106	[McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Command Id: 0 (STATE)
Message: {}" sent
I	14:54:25.124	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-AC-9F-71-AD-D4-4D-30-DB-72-07-FB-55-47-69-4B-33-95
I	14:54:25.161	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 8E-0A-87-5A-57-1A-5A-E0-48-51-DB-E1-28-88-C5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
I	14:54:25.174	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A	14:54:25.209	[McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"rJ9xrdRNMNtyB/tVR2lLM5WOCodaVxpa4EhR2+EoiMU=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
V	14:54:25.227	[McuMgr] Uploading firmware...
I	14:54:46.130	Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 01
A	14:54:46.130	"Button pressed" received
I	14:54:46.488	Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 00
A	14:54:46.488	"Button released" received
I	14:54:47.030	Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 01
A	14:54:47.030	"Button pressed" received
I	14:54:47.431	Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 00
A	14:54:47.431	"Button released" received
V	14:54:55.459	[McuMgr] Connecting...
D	14:54:55.711	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D	14:54:55.828	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I	14:54:55.853	[McuMgr] Connected to FB:B4:FA:11:EB:63
D	14:54:55.887	[McuMgr] wait(1600)
I	14:54:55.906	[McuMgr] MTU changed to: 65
V	14:54:57.503	[McuMgr] Discovering services...
D	14:54:57.522	[McuMgr] gatt.discoverServices()
I	14:54:57.542	[McuMgr] Services discovered
V	14:54:57.558	[McuMgr] Primary service found
I	14:54:57.589	[McuMgr] Service Changed characteristic found on a bonded device
D	14:54:57.602	[McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V	14:54:57.643	[McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D	14:54:57.659	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I	14:54:57.739	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I	14:54:57.748	[McuMgr] Service Changed notifications enabled
V	14:54:57.779	[McuMgr] Requesting new MTU...
D	14:54:57.796	[McuMgr] gatt.requestMtu(515)
I	14:54:57.873	[McuMgr] MTU changed to: 65
D	14:54:57.884	[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V	14:54:57.913	[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D	14:54:57.923	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	14:54:58.053	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I	14:54:58.063	[McuMgr] Notifications enabled
V	14:54:58.092	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D	14:54:58.103	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I	14:54:58.118	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
A	14:54:58.132	[McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Message: {}" sent
I	14:54:58.206	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-AC-9F-71-AD-D4-4D-30-DB-72-07-FB-55-47-69-4B-33-95
I	14:54:58.252	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 8E-0A-87-5A-57-1A-5A-E0-48-51-DB-E1-28-88-C5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
I	14:54:58.267	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A	14:54:58.316	[McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"rJ9xrdRNMNtyB/tVR2lLM5WOCodaVxpa4EhR2+EoiMU=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
V	14:54:58.335	[McuMgr] Uploading firmware...
V	14:55:15.765	Disconnecting...
D	14:55:15.765	gatt.disconnect()
D	14:55:15.809	[Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I	14:55:15.809	Disconnected
D	14:55:16.833	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
V	15:07:18.490	[McuMgr] Connecting...
D	15:07:18.500	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D	15:07:18.520	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I	15:07:18.534	[McuMgr] Connected to FB:B4:FA:11:EB:63
D	15:07:18.548	[McuMgr] wait(1600)
V	15:07:20.167	[McuMgr] Discovering services...
D	15:07:20.176	[McuMgr] gatt.discoverServices()
I	15:07:20.198	[McuMgr] Services discovered
V	15:07:20.229	[McuMgr] Primary service found
I	15:07:20.257	[McuMgr] Service Changed characteristic found on a bonded device
D	15:07:20.268	[McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V	15:07:20.290	[McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D	15:07:20.299	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I	15:07:20.379	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I	15:07:20.390	[McuMgr] Service Changed notifications enabled
V	15:07:20.417	[McuMgr] Requesting new MTU...
D	15:07:20.427	[McuMgr] gatt.requestMtu(515)
I	15:07:20.514	[McuMgr] MTU changed to: 65
D	15:07:20.525	[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V	15:07:20.561	[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D	15:07:20.577	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	15:07:20.741	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I	15:07:20.760	[McuMgr] Notifications enabled
V	15:07:20.816	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D	15:07:20.832	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I	15:07:20.853	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
A	15:07:20.874	[McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Message: {}" sent
I	15:07:20.923	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-AC-9F-71-AD-D4-4D-30-DB-72-07-FB-55-47-69-4B-33-95
I	15:07:20.938	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 8E-0A-87-5A-57-1A-5A-E0-48-51-DB-E1-28-88-C5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
I	15:07:20.978	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A	15:07:21.028	[McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"rJ9xrdRNMNtyB/tVR2lLM5WOCodaVxpa4EhR2+EoiMU=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
V	15:07:21.044	[McuMgr] Uploading firmware...
  • After built and upload it shows
    But i can't able to see in the SEGGER
  • For peripheral_lbs default code
    For dfu_lbs (default peripheral_lbs + DFU enabled)
    Still receiving log as
    [00:00:00.258,361] [0m<inf> mcuboot: Starting bootloader[0m
    [00:00:00.264,709] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[0m
    [00:00:00.275,207] [0m<inf> mcuboot: Boot source: none[0m
    [00:00:00.280,944] [0m<inf> mcuboot: Swap type: none[0m
    [00:00:00.601,928] [0m<inf> mcuboot: Bootloader chainload address offset: 0xc000[0m
    [00:00:00.609,954] [0m<inf> mcuboot: Jumping to the first image slot[0m
    Application build time: Mar 24 2021 23:25:54
    I: alloc wra: 0, fb0
    I: data wra: 0, 69
    Connected
    W: Ignoring data for unknown CID 0x003a
    I: Erasing page at offset 0x00045000
    I: Erasing page at offset 0x00046000
    I: Erasing page at offset 0x00047000
    I: Erasing page at offset 0x00048000
    I: Erasing page at offset 0x00049000
    I: Erasing page at offset 0x0004a000
    I: Erasing page at offset 0x0004b000
    I: Erasing page at offset 0x0004c000
    I: Erasing page at offset 0x0004d000
    I: Erasing page at offset 0x0004e000
    I: Erasing page at offset 0x0004f000
    I: Erasing page at offset 0x00050000
    I: Erasing page at offset 0x00051000
    I: Erasing page at offset 0x00052000
    I: Erasing page at offset 0x00053000
    I: Erasing page at offset 0x00054000
    I: Erasing page at offset 0x00055000
    I: Erasing page at offset 0x00056000
    I: Erasing page at offset 0x00057000
    I: Erasing page at offset 0x00058000
    I: Erasing page at offset 0x00059000
    I: Erasing page at offset 0x0005a000
    I: Erasing page at offset 0x0005b000
    I: Erasing page at offset 0x0005c000
    I: Erasing page at offset 0x0005d000
    I: Erasing page at offset 0x0005e000
    I: Erasing page at offset 0x0005f000
    I: Erasing page at offset 0x00060000
    I: Erasing page at offset 0x00061000
    I: Erasing page at offset 0x00062000
    I: Erasing page at offset 0x00063000
    I: Erasing page at offset 0x00064000
    I: Erasing page at offset 0x00065000
    I: Erasing page at offset 0x00066000
    I: Erasing page at offset 0x00067000
    I: Erasing page at offset 0x00068000
    I: Erasing page at offset 0x00069000
    I: Erasing page at offset 0x0006a000
    I: Erasing page at offset 0x0006b000
    I: Erasing page at offset 0x0006c000
    I: Erasing page at offset 0x0006d000
    I: Erasing page at offset 0x0006e000
    I: Erasing page at offset 0x0006f000
    I: Erasing page at offset 0x00070000
    I: Erasing page at offset 0x00071000
    I: Erasing page at offset 0x00072000
    I: Erasing page at offset 0x00073000
    I: Erasing page at offset 0x00074000
    I: Erasing page at offset 0x00075000
    I: Erasing page at offset 0x00076000
    I: Erasing page at offset 0x00077000
    I: Erasing page at offset 0x00078000
    I: Erasing page at offset 0x00079000
    I: Erasing page at offset 0x0007a000
    I: Erasing page at offset 0x0007b000
    I: Erasing page at offset 0x0007c000
    I: Erasing page at offset 0x0007d000
    [00:00:00.258,392] [0m<inf> mcuboot: Starting bootloader[0m
    [00:00:00.275,177] [0m<inf> mcuboot: Boot source: none[0m
    [00:00:00.280,944] [0m<inf> mcuboot: Swap type: test[0m
    [00:00:00.601,898] [1;33m<wrn> mcuboot: Not enough free space to run swap upgrade[0m
    [00:00:00.925,537] [0m<inf> mcuboot: Bootloader chainload address offset: 0xc000[0m
    [00:00:00.933,563] [0m<inf> mcuboot: Jumping to the first image slot[0m
    I: alloc wra: 0, fa0
    I: data wra: 0, 89
    Connected
  • I should note that the sizes from my last answer was with unmodified sample, so not including mcu_mgr which you need.
    The point remains that your slots must be equally sized and the application most fit in the slot. If it does not this will not work, no matter how much you try. If you are unable to make the application fit then you need to either not include DFU support (typically a bad idea for real products) or use a nRF device with more internal flash or use an external flash memory for slot 1.
  •  Hi Einar,
     How do i manage the memory in NCS DFU example for nrf52832.
    Does NCS DFU support have any limitation ?
    The only thing you need to consider is that slot o and slot 1 must be of equal size, and your application must fit in one of the slots. If it does not you must try to shrink the application. If not possible, you must use a device with larger internal flash or use external flash for slot 1.
    Einar
