NCS OTA DFU failed in nrf52832
 I am trying to test and develop the DFU-OTA in nRF CONNECT SDK for nRF52832
I followed these link to develop  i am using NCS v1.4.2
1. I have copied the peripheral_lbs code to my workspace
2. Based on the link i have added few things and here i attached the related files
main.c
 * Copyright (c) 2018 Nordic Semiconductor ASA
 * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
#include <zephyr/types.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <sys/printk.h>
#include <sys/byteorder.h>
#include <zephyr.h>
#include <drivers/gpio.h>
#include <soc.h>
#include <bluetooth/bluetooth.h>
#include <bluetooth/hci.h>
#include <bluetooth/conn.h>
#include <bluetooth/uuid.h>
#include <bluetooth/gatt.h>
#include <bluetooth/services/lbs.h>
#include <settings/settings.h>
#include <dk_buttons_and_leds.h>
// For FOTA
#include <tinycbor/cbor.h>
#include "cborattr/cborattr.h"
#include <mgmt/mgmt.h>
#include <mgmt/mcumgr/smp_bt.h>
#include <mgmt/mcumgr/buf.h>
#include <mgmt/mcumgr/smp.h>
#include "os_mgmt/os_mgmt.h"
#include "os_mgmt/os_mgmt_impl.h"
#include "os_mgmt/os_mgmt_config.h"
#include "img_mgmt/image.h"
#include "img_mgmt/img_mgmt.h"
#include "img_mgmt/img_mgmt_impl.h"
#include "img_mgmt/img_mgmt_config.h"
#define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
#define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
#define RUN_STATUS_LED          DK_LED1
#define CON_STATUS_LED          DK_LED2
#define RUN_LED_BLINK_INTERVAL  1000
#define USER_LED                DK_LED3
#define USER_BUTTON             DK_BTN1_MSK
static bool app_button_state;
static const struct bt_data ad[] = {
	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
static const struct bt_data sd[] = {
	BT_DATA_BYTES(BT_DATA_UUID128_ALL, BT_UUID_LBS_VAL),
static void connected(struct bt_conn *conn, uint8_t err)
	if (err) {
		printk("Connection failed (err %u)\n", err);
		return;
	printk("Connected\n");
	dk_set_led_on(CON_STATUS_LED);
	printk("Disconnected (reason %u)\n", reason);
	dk_set_led_off(CON_STATUS_LED);
#ifdef CONFIG_BT_LBS_SECURITY_ENABLED
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		printk("Security changed: %s level %u\n", addr, level);
	} else {
		printk("Security failed: %s level %u err %d\n", addr, level,
			err);
static struct bt_conn_cb conn_callbacks = {
	.connected        = connected,
	.disconnected     = disconnected,
	.security_changed = security_changed,
#if defined(CONFIG_BT_LBS_SECURITY_ENABLED)
static void auth_passkey_display(struct bt_conn *conn, unsigned int passkey)
	printk("Passkey for %s: %06u\n", addr, passkey);
static void auth_cancel(struct bt_conn *conn)
	printk("Pairing cancelled: %s\n", addr);
static void pairing_confirm(struct bt_conn *conn)
	bt_conn_auth_pairing_confirm(conn);
	printk("Pairing confirmed: %s\n", addr);
static void pairing_complete(struct bt_conn *conn, bool bonded)
	printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	printk("Pairing failed conn: %s, reason %d\n", addr, reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.passkey_display = auth_passkey_display,
	.cancel = auth_cancel,
	.pairing_confirm = pairing_confirm,
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
#else
static struct bt_conn_auth_cb conn_auth_callbacks;
static void app_led_cb(bool led_state)
	dk_set_led(USER_LED, led_state);
static bool app_button_cb(void)
	return app_button_state;
static struct bt_lbs_cb lbs_callbacs = {
	.led_cb    = app_led_cb,
	.button_cb = app_button_cb,
static void button_changed(uint32_t button_state, uint32_t has_changed)
	if (has_changed & USER_BUTTON) {
		bt_lbs_send_button_state(button_state);
		app_button_state = button_state ? true : false;
static int init_button(void)
	int err;
	err = dk_buttons_init(button_changed);
	if (err) {
		printk("Cannot init buttons (err: %d)\n", err);
	return err;
void main(void)
	int blink_status = 0;
	int err;
	printk("Starting Bluetooth Peripheral LBS example\n");
        printk("Application build time: %s %s \n", __DATE__, __TIME__);
	err = dk_leds_init();
	if (err) {
		printk("LEDs init failed (err %d)\n", err);
		return;
	err = init_button();
	if (err) {
		printk("Button init failed (err %d)\n", err);
		return;
	bt_conn_cb_register(&conn_callbacks);
	if (IS_ENABLED(CONFIG_BT_LBS_SECURITY_ENABLED)) {
		bt_conn_auth_cb_register(&conn_auth_callbacks);
	err = bt_enable(NULL);
	if (err) {
		printk("Bluetooth init failed (err %d)\n", err);
		return;
	printk("Bluetooth initialized\n");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
	err = bt_lbs_init(&lbs_callbacs);
	if (err) {
		printk("Failed to init LBS (err:%d)\n", err);
		return;
	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad),
			      sd, ARRAY_SIZE(sd));
	if (err) {
		printk("Advertising failed to start (err %d)\n", err);
		return;
	printk("Advertising successfully started\n");
        // For FOTA
  os_mgmt_register_group();
  img_mgmt_register_group();
  smp_bt_register();
	for (;;) {
		dk_set_led(RUN_STATUS_LED, (++blink_status) % 2);
		k_sleep(K_MSEC(RUN_LED_BLINK_INTERVAL));
prj.conf
# Copyright (c) 2018 Nordic Semiconductor
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
CONFIG_NCS_SAMPLES_DEFAULTS=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="Nordic_Blinky"
# Enable the LBS service
CONFIG_BT_LBS=y
CONFIG_BT_LBS_POLL_BUTTON=y
CONFIG_DK_LIBRARY=y
# Added for FOTA
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUMGR=y
CONFIG_MCUMGR_CMD_OS_MGMT=y
CONFIG_MCUMGR_CMD_IMG_MGMT=y
CONFIG_MCUMGR_SMP_BT=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
also added full .zip file here
1447.dfu_app.zip
3. After successful compilation of the code uploaded to the Empty nRF52 DK (there is no bootloader separately added before )
4. Successfully showing the services in the nRF connect APP while entering into DFU
5. On the other-side i have just changed the device name to dfu_nrf_blinky
6. taken the build and app_update.bin is taken to mobile device
7. While initialize the DFU it asked for pairing and also paired with the device with valid key.
8. And on entering to start DFU it was disconnected like this and video is linked below with respective log
Log in the serial
*** Booting Zephyr OS build v2.4.0-ncs2  ***
[00:00:00.528,289] [0m<inf> mcuboot: Starting bootloader[0m
[00:00:00.534,576] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[0m
[00:00:00.545,043] [0m<inf> mcuboot: Boot source: none[0m
[00:00:00.550,781] [0m<inf> mcuboot: Swap type: none[0m
[00:00:00.844,512] [0m<inf> mcuboot: Bootloader chainload address offset: 0xc000[0m
[00:00:00.852,508] [0m<inf> mcuboot: Jumping to the first image slot[0m
Application build time: Mar 15 2021 14:36:28
I: 2 Sectors of 4096 bytes
I: alloc wra: 0, ff0
I: data wra: 0, 0
I: SoftDevice Controller build revision:
I: cf 5c 0f 11 88 9c d7 02 |.\......
I: 15 27 c7 c3 ca 60 19 85 |.'...`..
I: b7 c4 50 e3             |..P.
I: No ID address. App must call settings_load()
Connected
Passkey for 7e:2a:18:a3:a2:3c (random): 757200
Security changed: 7e:2a:18:a3:a2:3c (random) level 4
Pairing completed: 7c:78:7e:78:66:b3 (public), bonded: 1
Disconnected (reason 19)
Connected
Security changed: 7c:78:7e:78:66:b3 (public) level 4
Connected
Connected
Log from the nrf connect APP
nRF Connect, 2021-03-15
Nordic_Blinky (FB:B4:FA:11:EB:63)
V	14:54:14.912	Connecting to FB:B4:FA:11:EB:63...
D	14:54:14.912	gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, preferred PHY = LE 1M)
D	14:54:15.042	[Broadcast] Action received: android.bluetooth.device.action.ACL_CONNECTED
D	14:54:15.096	[Callback] Connection state changed with status: 0 and new state: CONNECTED (2)
I	14:54:15.097	Connected to FB:B4:FA:11:EB:63
D	14:54:15.099	wait(1600ms)
D	14:54:15.360	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDING (11)
D	14:54:15.421	[Broadcast] Action received: android.bluetooth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_BONDED (12)
I	14:54:15.421	Device bonded
I	14:54:15.616	Connection parameters updated (interval: 7.5ms, latency: 0, timeout: 5000ms)
I	14:54:16.023	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 5000ms)
V	14:54:16.700	Discovering services...
D	14:54:16.700	gatt.discoverServices()
D	14:54:16.713	[Callback] Services discovered with status: 0
I	14:54:16.714	Services discovered
V	14:54:16.737	Generic Attribute (0x1801)
- Service Changed [I] (0x2A05)
   Client Characteristic Configuration (0x2902)
- Client Supported Features [R W] (0x2B29)
- Database Hash [R] (0x2B2A)
Generic Access (0x1800)
- Device Name [R] (0x2A00)
- Appearance [R] (0x2A01)
- Peripheral Preferred Connection Parameters [R] (0x2A04)
Nordic LED Button Service (00001523-1212-efde-1523-785feabcd123)
- Button [N R] (00001524-1212-efde-1523-785feabcd123)
- LED [W] (00001525-1212-efde-1523-785feabcd123)
SMP Service (8d53dc1d-1db7-4cd3-868b-8a527460aa84)
- SMP Characteristic [N WNR] (da2e7828-fbce-4e01-ae9e-261174997c48)
D	14:54:16.738	gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
D	14:54:16.740	gatt.setCharacteristicNotification(00001524-1212-efde-1523-785feabcd123, true)
I	14:54:20.973	Connection parameters updated (interval: 45.0ms, latency: 0, timeout: 420ms)
V	14:54:22.707	[McuMgr] Connecting...
D	14:54:22.720	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D	14:54:22.751	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I	14:54:22.767	[McuMgr] Connected to FB:B4:FA:11:EB:63
D	14:54:22.786	[McuMgr] wait(1600)
V	14:54:24.400	[McuMgr] Discovering services...
D	14:54:24.418	[McuMgr] gatt.discoverServices()
I	14:54:24.472	[McuMgr] Services discovered
V	14:54:24.483	[McuMgr] Primary service found
I	14:54:24.500	[McuMgr] Service Changed characteristic found on a bonded device
D	14:54:24.513	[McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V	14:54:24.550	[McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D	14:54:24.561	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I	14:54:24.662	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I	14:54:24.672	[McuMgr] Service Changed notifications enabled
V	14:54:24.695	[McuMgr] Requesting new MTU...
D	14:54:24.705	[McuMgr] gatt.requestMtu(515)
I	14:54:24.797	[McuMgr] MTU changed to: 65
D	14:54:24.807	[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V	14:54:24.831	[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D	14:54:24.852	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	14:54:24.979	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I	14:54:24.992	[McuMgr] Notifications enabled
V	14:54:25.034	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D	14:54:25.047	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I	14:54:25.066	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
A	14:54:25.106	[McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Command Id: 0 (STATE)
Message: {}" sent
I	14:54:25.124	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-AC-9F-71-AD-D4-4D-30-DB-72-07-FB-55-47-69-4B-33-95
I	14:54:25.161	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 8E-0A-87-5A-57-1A-5A-E0-48-51-DB-E1-28-88-C5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
I	14:54:25.174	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A	14:54:25.209	[McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"rJ9xrdRNMNtyB/tVR2lLM5WOCodaVxpa4EhR2+EoiMU=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
V	14:54:25.227	[McuMgr] Uploading firmware...
I	14:54:46.130	Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 01
A	14:54:46.130	"Button pressed" received
I	14:54:46.488	Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 00
A	14:54:46.488	"Button released" received
I	14:54:47.030	Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 01
A	14:54:47.030	"Button pressed" received
I	14:54:47.431	Notification received from 00001524-1212-efde-1523-785feabcd123, value: (0x) 00
A	14:54:47.431	"Button released" received
V	14:54:55.459	[McuMgr] Connecting...
D	14:54:55.711	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D	14:54:55.828	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I	14:54:55.853	[McuMgr] Connected to FB:B4:FA:11:EB:63
D	14:54:55.887	[McuMgr] wait(1600)
I	14:54:55.906	[McuMgr] MTU changed to: 65
V	14:54:57.503	[McuMgr] Discovering services...
D	14:54:57.522	[McuMgr] gatt.discoverServices()
I	14:54:57.542	[McuMgr] Services discovered
V	14:54:57.558	[McuMgr] Primary service found
I	14:54:57.589	[McuMgr] Service Changed characteristic found on a bonded device
D	14:54:57.602	[McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V	14:54:57.643	[McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D	14:54:57.659	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I	14:54:57.739	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I	14:54:57.748	[McuMgr] Service Changed notifications enabled
V	14:54:57.779	[McuMgr] Requesting new MTU...
D	14:54:57.796	[McuMgr] gatt.requestMtu(515)
I	14:54:57.873	[McuMgr] MTU changed to: 65
D	14:54:57.884	[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V	14:54:57.913	[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D	14:54:57.923	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	14:54:58.053	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I	14:54:58.063	[McuMgr] Notifications enabled
V	14:54:58.092	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D	14:54:58.103	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I	14:54:58.118	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
A	14:54:58.132	[McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Message: {}" sent
I	14:54:58.206	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-AC-9F-71-AD-D4-4D-30-DB-72-07-FB-55-47-69-4B-33-95
I	14:54:58.252	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 8E-0A-87-5A-57-1A-5A-E0-48-51-DB-E1-28-88-C5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
I	14:54:58.267	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A	14:54:58.316	[McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"rJ9xrdRNMNtyB/tVR2lLM5WOCodaVxpa4EhR2+EoiMU=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
V	14:54:58.335	[McuMgr] Uploading firmware...
V	14:55:15.765	Disconnecting...
D	14:55:15.765	gatt.disconnect()
D	14:55:15.809	[Callback] Connection state changed with status: 0 and new state: DISCONNECTED (0)
I	14:55:15.809	Disconnected
D	14:55:16.833	[Broadcast] Action received: android.bluetooth.device.action.ACL_DISCONNECTED
V	15:07:18.490	[McuMgr] Connecting...
D	15:07:18.500	[McuMgr] gatt = device.connectGatt(autoConnect = false, TRANSPORT_LE, LE 1M)
D	15:07:18.520	[McuMgr] [Callback] Connection state changed with status: 0 and new state: 2 (CONNECTED)
I	15:07:18.534	[McuMgr] Connected to FB:B4:FA:11:EB:63
D	15:07:18.548	[McuMgr] wait(1600)
V	15:07:20.167	[McuMgr] Discovering services...
D	15:07:20.176	[McuMgr] gatt.discoverServices()
I	15:07:20.198	[McuMgr] Services discovered
V	15:07:20.229	[McuMgr] Primary service found
I	15:07:20.257	[McuMgr] Service Changed characteristic found on a bonded device
D	15:07:20.268	[McuMgr] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
V	15:07:20.290	[McuMgr] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D	15:07:20.299	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I	15:07:20.379	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 02-00
I	15:07:20.390	[McuMgr] Service Changed notifications enabled
V	15:07:20.417	[McuMgr] Requesting new MTU...
D	15:07:20.427	[McuMgr] gatt.requestMtu(515)
I	15:07:20.514	[McuMgr] MTU changed to: 65
D	15:07:20.525	[McuMgr] gatt.setCharacteristicNotification(da2e7828-fbce-4e01-ae9e-261174997c48, true)
V	15:07:20.561	[McuMgr] Enabling notifications for da2e7828-fbce-4e01-ae9e-261174997c48
D	15:07:20.577	[McuMgr] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I	15:07:20.741	[McuMgr] Data written to descr. 00002902-0000-1000-8000-00805f9b34fb, value: (0x) 01-00
I	15:07:20.760	[McuMgr] Notifications enabled
V	15:07:20.816	[McuMgr] Writing characteristic da2e7828-fbce-4e01-ae9e-261174997c48 (WRITE COMMAND)
D	15:07:20.832	[McuMgr] gatt.writeCharacteristic(da2e7828-fbce-4e01-ae9e-261174997c48)
I	15:07:20.853	[McuMgr] Data written to da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 00-00-00-02-00-01-00-00-BF-FF
A	15:07:20.874	[McuMgr] "Operation: READ
Flags: 0
Length: 2
Group Id: 1 (IMAGE)
Sequence Num: 0
Message: {}" sent
I	15:07:20.923	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 01-00-00-86-00-01-00-00-BF-66-69-6D-61-67-65-73-9F-BF-64-73-6C-6F-74-00-67-76-65-72-73-69-6F-6E-65-30-2E-30-2E-30-64-68-61-73-68-58-20-AC-9F-71-AD-D4-4D-30-DB-72-07-FB-55-47-69-4B-33-95
I	15:07:20.938	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 8E-0A-87-5A-57-1A-5A-E0-48-51-DB-E1-28-88-C5-68-62-6F-6F-74-61-62-6C-65-F5-67-70-65-6E-64-69-6E-67-F4-69-63-6F-6E-66-69-72-6D-65-64-F5-66-61-63-74-69-76-65-F5-69-70-65-72-6D-61-6E-65-6E
I	15:07:20.978	[McuMgr] Notification received from da2e7828-fbce-4e01-ae9e-261174997c48, value: (0x) 74-F4-FF-FF-6B-73-70-6C-69-74-53-74-61-74-75-73-00-FF
A	15:07:21.028	[McuMgr] "{"images":[{"slot":0,"version":"0.0.0","hash":"rJ9xrdRNMNtyB/tVR2lLM5WOCodaVxpa4EhR2+EoiMU=","bootable":true,"pending":false,"confirmed":true,"active":true,"permanent":false}],"splitStatus":0}" received
V	15:07:21.044	[McuMgr] Uploading firmware...
  • Hi Einar,
    Happy Easter.
    OK, Is it possible to disable printk
    and enabling printf "uart print"
    I am not sure you will save any space on that unless you remove loggign alltogether. That said, you can disable printk by putting CONFIG_PRINTK=n in your prj.conf.
  • Hi Einar, I have tried to put CONFIG_PRINTK=n    in proj.conf
    Eventhough it show in the console
    CONFIG_BT=y
    CONFIG_BT_LBS=y
    CONFIG_DK_LIBRARY=y
    # Added for FOTA
    CONFIG_MCUMGR=y
    CONFIG_DEBUG_OPTIMIZATIONS=y
    CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    CONFIG_LOG=n
    CONFIG_PRINTK=n
    CONFIG_BT_L2CAP_TX_MTU=252
    CONFIG_BT_L2CAP_RX_MTU=252
    CONFIG_BT_RX_BUF_LEN=260
    CONFIG_BT_CTLR_TX_BUFFER_SIZE=251
    CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
    I have just check in the configure file inside the project
    can't able to deselect this send printk() to console
    I just want to limit the thing to be print in console
  • In most cases you can disable printouts using CONFIG_SERIAL=n, but you can also use CONFIG_UART_CONSOLE=n and CONFIG_PRINTK=n if needed.
  • When i keep Only
    CONFIG_PRINTK=n
    output file is
    [00:00:00.258,361] [0m<inf> mcuboot: Starting bootloader[0m
    [00:00:00.264,678] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[0m
    [00:00:00.275,146] [0m<inf> mcuboot: Boot source: none[0m
    [00:00:00.280,883] [0m<inf> mcuboot: Swap type: none[0m
    [00:00:00.605,682] [0m<inf> mcuboot: Bootloader chainload address offset: 0xc000[0m
    [00:00:00.613,708] [0m<inf> mcuboot: Jumping to the first image slot[0m
    Application build time: Apr  7 2021 23:27:31
    I: alloc wra: 0, f70
    I: data wra: 0, e9
    printing : both printf and printk and where
    these files are locating
    I: data wra: 0, e9
    what denoting "I"
    when I use both
    CONFIG_PRINTK=n
    output file in console is
    [00:00:00.284,973] [0m<inf> mcuboot: Starting bootloader[0m
    [00:00:00.291,259] [0m<inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3[0m
    [00:00:00.301,757] [0m<inf> mcuboot: Boot source: none[0m
    [00:00:00.307,464] [0m<inf> mcuboot: Swap type: none[0m
    [00:00:00.632,019] [0m<inf> mcuboot: Bootloader chainload address offset: 0xc000[0m
    [00:00:00.640,014] [0m<inf> mcuboot: Jumping to the first image slot[0m
    only dfu file message is printing
    1. My query is i need to control to print only my printf() data
    2. Is printf() and printk() same?
    3. How to control to print only the blue lines
    Application build time: Apr  7 2021 23:33:17
    I: alloc wra: 0, f60
    I: data wra: 0, 109
    4. These below line are printing by myself using printf(), and printk()
    5.where this line exist
