Custom board build fails with SDK 1.5.0, works with 1.4.0
We are getting a "No SOURCES given to target: drivers__ipm" error making build fail for our custom board when trying to move to 1.5.0 for official nRF53 production support.
Cmakelists in the sdk's appear identical, and the only change is running west from commandline environment for 1.5.0 instead of 1.4.0.
  • Hi Kyrre,
    Can you please elaborate on where you get the message "No SOURCES given to target: drivers__ipm"? What environment are you using i.e. SES og command line?Can you provide full output?
    Thank you.
    Øyvind
  • SES just failed with little info so I did this to a new build folder on commandline after starting the commandline from the toolchain manager. It is accessing the correct folder at user/<username>/ncs/1.5.0/ equal to the results from 1.4.0 but the build differs when cmake gets to some libraries.
    -- Looking for include file fcntl.h
    -- Looking for include file fcntl.h - found
    CMake Warning at ../../../CMakeLists.txt:1357 (message):
    -- Configuring done
    CMake Error at ../../../cmake/extensions.cmake:416 (add_library):
      ../../../cmake/extensions.cmake:393 (zephyr_library_named)
      ../../../drivers/ipm/CMakeLists.txt:3 (zephyr_library)
    Fow 1.4.0 it looks like this:
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/xxx/Documents/projects/Hy5_AIO/Hy5_AIO_nRF/build/hci_rpmsg
    === child image hci_rpmsg - CPUNET end ===
    I do see multiple warnings in both SDK's but with different "styles":
    CMake Warning (dev) at C:/Users/xxx/ncs/v1.4.0/modules/lib/open-amp/open-amp/cmake/options.cmake:51 (option):
    Policy CMP0077 is not set: option() honors normal variables. Run "cmake
    --help-policy CMP0077" for policy details. Use the cmake_policy command to
    set the policy and suppress this warning.
    For compatibility with older versions of CMake, option is clearing the
    normal variable 'WITH_VIRTIO_MASTER'.
    C:/Users/xxx/ncs/v1.4.0/modules/lib/open-amp/open-amp/CMakeLists.txt:21 (include)
    This warning is for project developers. Use -Wno-dev to suppress it.
  • Have you tried a standard sample to see how that builds? Can you try to remove the build folder, or build in a new build folder?
    If that does not provide any answers, please attach your project for me to replicate.
    Thanks
    Øyvind
  • I have tried new build folders.
    The project and board was based on the bluetooth/peripheral example which builds fine in 1.5.0.
    1.5.0 cannot build the old sample though due to changes in bt_gatt_indicate_func_t.
    I cannot upload source here. Alternative way?
  • Also, what settings are you using in SES under Tools -> Options -> nRF Connect?
