Multiple Characteristics and Notifications
Hi Forum,
i've started the development of an custom service on a nrf51822 with s110. The Service contains 4 Characteristics where notifications are enabled.
At the central side i use a nrf51822 with s120. On this Device the multilink_central app is running with modifications to my needs.
I can connect to a peer device and also dicover my characteristics. But when i only can set one characteristic to notify. ( enable_notify)
When i try to run this more than one time the software crashes.
Hope you can help me.
Edit: Ive attached the functions where i am stuck.
The Problem is i can only receive one hvx Notification -> last i discovered
static void notif_enable(client_t * p_client)
  uint32_t                 err_code;
  ble_gattc_write_params_t write_params;
  uint8_t                  buf[BLE_CCCD_VALUE_LEN];
  printf("In Notify Enable \r\n");
  p_client->state = STATE_NOTIF_ENABLE;
  buf[0] = BLE_GATT_HVX_NOTIFICATION;
  buf[1] = 0;
  write_params.write_op = BLE_GATT_OP_WRITE_REQ;
  write_params.handle   = p_client->srv_db.services[0].charateristics[p_client->char_index].cccd_handle;
  write_params.offset   = 0;
  write_params.len      = sizeof(buf);
  write_params.p_value  = buf;
  err_code = sd_ble_gattc_write(p_client->srv_db.conn_handle, &write_params);
  printf("Error Code: %i",err_code);
  //sd_app_evt_wait();
  wait(200000);
static void db_discovery_evt_handler(ble_db_discovery_evt_t * p_evt)
  // Find the client using the connection handle.
  client_t * p_client;
  uint32_t   index;
  bool       is_valid_srv_found = false;
  index = client_find(p_evt->conn_handle);
  p_client = &m_client[index];
  if (p_evt->evt_type == BLE_DB_DISCOVERY_COMPLETE)
    uint8_t i;
    printf("Characteritics found: %i\r\n",p_evt->params.discovered_db.char_count);
    for (i = 0; i <= p_evt->params.discovered_db.char_count; i++)
        ble_db_discovery_char_t * p_characteristic;
        p_characteristic = &(p_evt->params.discovered_db.charateristics[i]);
        printf("UUID: %x ",p_characteristic->characteristic.uuid.uuid);
        if ((p_characteristic->characteristic.uuid.uuid == TEXMESSBOX_PERIPHERAL_CHANNEL_1_UUID)
            (p_characteristic->characteristic.uuid.type == m_base_uuid_type))
            // Characteristic found. Store the information needed and break.
    	printf("Texxmessbox Channel 1\r\n");
            p_client->char_index = i;
            is_valid_srv_found   = true;
            //break;
        if ((p_characteristic->characteristic.uuid.uuid == TEXMESSBOX_PERIPHERAL_CHANNEL_2_UUID)
    	printf("Texxmessbox Channel 2\r\n");
                        //break;
        if ((p_characteristic->characteristic.uuid.uuid == TEXMESSBOX_PERIPHERAL_CHANNEL_3_UUID)
                	printf("Texxmessbox Channel 3\r\n");
                                    //break;
        if ((p_characteristic->characteristic.uuid.uuid == TEXMESSBOX_PERIPHERAL_CHANNEL_4_UUID)
                	printf("Texxmessbox Channel 4\r\n");
                                    //break;
if (is_valid_srv_found)
  // Enable notification.
  printf("Enable Notification\r\n");
  notif_enable(p_client);
    printf("Error\r\n");
    p_client->state = STATE_ERROR;
