I have update the SDK from version 1.4.2 to 1.5.0.
Suddenly i see that the hci_rpmsg is not build as a child image.
Which defines do i need to set for that now?
Hi!
It should be enough to have CONFIG_BT=y in your prj.conf given that it's supported by the target board. Hence, there could be a problem with the board you're targeting. What version of the nRF5340 are you building for? A DK, PDK or custom board?
Carl Richard
Hi Carl
Thnx for the fast answer. the target is the DK board, i removed completely 1.4.2 and installed a fresh version of 1.5.0.
Now it works. To overlay the hci_rpmsg i have created a "child_image" directory with a .conf file in it.
Hi again!
Glad that you figured it out and thanks for describing your procedure!
Carl Richard
