AGPS startup via NB-IoT on nrf9160-DK
I took the APGS example and switched in to NB-IoT as I can't easily test with LTE/M at the moment
2021-03-15T16:25:39.226Z DEBUG modem << I: A-GPS sample has started
2021-03-15T16:25:39.246Z DEBUG modem << I: Connecting to LTE network. This may take minutes.
2021-03-15T16:25:39.249Z DEBUG modem << I: PSM mode requested
2021-03-15T16:25:42.194Z DEBUG modem << +CEREG: 2,"1BE8","00334D15",9,0,0,"11100000","11100000"
2021-03-15T16:25:42.900Z DEBUG modem << +CSCON: 1
2021-03-15T16:25:45.571Z DEBUG modem << +CEREG: 5,"1BE8","00334D15",9,,,"00000010","00011111"
2021-03-15T16:25:45.605Z DEBUG modem << I: Connected to LTE network
2021-03-15T16:25:45.606Z DEBUG modem << D: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1565,1586
2021-03-15T16:25:45.607Z DEBUG modem << D: COEX0 set: AT%XCOEX0=1,1,1565,1586
2021-03-15T16:25:45.610Z DEBUG modem << D: GPS socket created, fd: 1232491587
2021-03-15T16:25:45.611Z DEBUG modem << I: CLOUD_EVT_CONNECTING
2021-03-15T16:25:46.400Z DEBUG modem << I: CLOUD_EVT_CONNECTING
I tried this a few times and waiting several minutes in each case. No more output seen.
Are there other things I need to change? apart from:
#CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
CONFIG_LTE_NETWORK_MODE_NBIOT_GPS=y
Suggestions welcome. Thx.
    Sorry for the delayed answer. I will have a look at your case and get back to you before end of the day.
    Øyvind
  • My sincere apologies. I've had trouble with my setup here as well. I will need some more time.
    Øyvind
    My apologies for the late reply. I have had some issues with my board.
    Can you please provide full log output from when you are trying to connect? How long do you let it run? This may be an issue with the NB-IoT connection, but will need to confirm.
    This is what I get when running the AGPS sample:
    2021-03-23T10:58:45.747Z DEBUG modem << *** Booting Zephyr OS build v2.4.99-ncs1  ***
    2021-03-23T10:58:45.750Z DEBUG modem << I: A-GPS sample has started
    2021-03-23T10:58:45.752Z DEBUG modem << I: Connecting to LTE network. This may take minutes.
    2021-03-23T10:58:45.753Z DEBUG modem << I: PSM mode requested
    2021-03-23T10:58:46.715Z DEBUG modem << +CEREG: 2,"7AA9","01172803",7,0,0,"11100000","11100000"
    2021-03-23T10:58:47.198Z DEBUG modem << +CSCON: 1
    2021-03-23T10:58:48.569Z DEBUG modem << +CEREG: 1,"7AA9","01172803",7,,,"00000010","00011111"
    2021-03-23T10:58:49.030Z DEBUG modem << I: Connected to LTE network
    2021-03-23T10:58:49.032Z DEBUG modem << D: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1565,1586
    2021-03-23T10:58:49.034Z DEBUG modem << D: COEX0 set: AT%XCOEX0=1,1,1565,1586
    2021-03-23T10:58:49.035Z DEBUG modem << D: GPS socket created, fd: 1232491587
    2021-03-23T10:58:49.036Z DEBUG modem << I: CLOUD_EVT_CONNECTING
    2021-03-23T10:58:53.213Z DEBUG modem << I: CLOUD_EVT_CONNECTED
    2021-03-23T10:58:53.888Z DEBUG modem << I: CLOUD_EVT_DATA_RECEIVED
    2021-03-23T10:58:54.438Z DEBUG modem << I: CLOUD_EVT_PAIR_DONE
    2021-03-23T10:58:54.935Z DEBUG modem << E: Failed to save session state: -2
    2021-03-23T10:58:54.937Z DEBUG modem << I: CLOUD_EVT_READY
    2021-03-23T10:58:54.938Z DEBUG modem << I: Service info sent to cloud
    2021-03-23T10:58:54.938Z DEBUG modem << D: GPS mode is enabled
    2021-03-23T10:58:54.939Z DEBUG modem << D: GPS operational
    2021-03-23T10:58:54.940Z DEBUG modem << I: Periodic GPS search started with interval 240 s, timeout 120 s
    2021-03-23T10:58:54.942Z DEBUG modem << I: GPS_EVT_SEARCH_STARTED
    2021-03-23T10:58:54.943Z DEBUG modem << D: A-GPS data update needed
    2021-03-23T10:58:54.943Z DEBUG modem << I: GPS_EVT_AGPS_DATA_NEEDED
    2021-03-23T10:58:54.944Z DEBUG modem << D: Created A-GPS request: {"appId":"AGPS","messageType":"DATA","data":{"mcc":242,"mnc":1,"tac":31401,"eci":18294787,"phycid":0,"types":[1,2,3,4,7,8,9]}}
    2021-03-23T10:58:54.944Z DEBUG modem << D: A-GPS request sent
    2021-03-23T10:58:55.733Z DEBUG modem << D: Waiting for time window to operate
    2021-03-23T10:58:55.736Z DEBUG modem << I: GPS_EVT_OPERATION_BLOCKED
    2021-03-23T10:58:57.135Z DEBUG modem << I: CLOUD_EVT_DATA_RECEIVED
    2021-03-23T10:58:57.580Z DEBUG modem << D: Receievd AGPS data. Schema version: 1, length: 1037
    2021-03-23T10:58:57.582Z DEBUG modem << D: Parsed_len: 35
    2021-03-23T10:58:57.584Z DEBUG modem << D: A-GPS type: NRF_CLOUD_AGPS_ALMANAC
    2021-03-23T10:58:57.585Z DEBUG modem << D: Sent A-GPS data to modem, type: 3
    2021-03-23T10:58:57.586Z DEBUG modem << D: Parsed_len: 66
    2021-03-23T10:58:57.587Z DEBUG modem << D: A-GPS type: NRF_CLOUD_AGPS_ALMANAC
    2021-03-23T10:58:57.587Z DEBUG modem << D: Sent A-GPS data to modem, type: 3
    Øyvind
